Author Topic: Running on compressed air - lunrication?  (Read 1710 times)
Tim Logan
  • Lifeboats & Tugs
« on: October 14, 2024, 05:38:24 pm »
I am just now learning about steam. I see many references to testing engines by running on compressed air. How is the engine lubricated without steam bringing in steam oil? Thank you.
rhavrane
  • Steam passionate collector
Re: Running on compressed air - lunrication?
« Reply #1 on: October 14, 2024, 08:35:06 pm »
Bonjour Tim,
Personally, I always fill at first my steam machines with a lot of thin oil (not necessarily steam oil) when I try them on air. Furthermore, I run them just a few minutes at low speed to check how they run then I operate them only on steam.
Thanks to this way of doing, I see this oil going out of the exhaust pipe, proof she made the expected lubricating job  :-))
I say it during my tests, the last one at 1'20" : https://youtu.be/oUcGz2JH4OY
If you have no thin oil, WD40 can be an alternative, I would like to point out that for steam operation I use a thick 430 grade oil.
Raphaël
1967Brutus
« Reply #2 on: October 14, 2024, 09:18:52 pm »
Pretty much ANY oil will do when testing with air. Just squeeze a liberal amount of oil in the inlet of the engine before connecting.
Alternative, if you have access to a workshop where airdriven tools are used, they have "air lubricators there and using such a device in the air supply, there's nothing to worry about.
Tim Logan
  • Lifeboats & Tugs
« Reply #3 on: October 14, 2024, 10:34:06 pm »
Gentlemen / that clears that up! One more step on the learning ladder. Thank you very much for taking the time to respond!
1967Brutus
« Reply #4 on: October 14, 2024, 10:45:17 pm »
Don't hesitate to ask... The only question I cannot answer is: "how many steps are there on that ladder?", because I haven't reached the top yet...
rhavrane
« Reply #5 on: October 15, 2024, 07:20:37 am »
Raphaël
1967Brutus
« Reply #6 on: October 15, 2024, 08:26:14 am »
Bonjour,
https://www.amazon.fr/T%C3%A9lescopique-t%C3%A9lescopique-Extensible-Telescopique-R%C3%A9sistance/dp/B09P119L18?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=AXTGEDE7X1BOJ4
 ok2 :} :-))
Tim, there are no bad questions, only bad answers has said Albert Einstein and I fully agree with him !
My personal favourite expression: "The ONLY stupid question, is the one you are shy to ask"...
Page created in 0.014 seconds with 22 queries.
