This is pretty straightforward. I bought a steam tug a few months ago and it has a pair of water tanks either side of the hull with a manual pump to fill the boiler. I've had to remove the tanks because the water feed pipes are blocked so kettle descaler and boiling water is required and one is now clear, but I discovered a water leak (fill with water, put finger over end of feed outlet and mouth around filler and blow - that soon shows leaks!)
I have two soldering irons, a little 5 W jobbie for electronic work and a 40W Weller with a chisel tip. I've tried with the Weller to re-solder the point where the leak is but the soldering iron isn't hot enough so I ended up sealing the leak but the propagation of the heat has caused another leak and so it goes. I know that I just need to get it hot locally and the iron off quickly and then to cool the tank down.
So my question is what soldering iron should I get ? I'm using electrical cored solder so should I use a different solder and a separate flux? Basically I would appreciate being told to buy 'Product X, Y and Z' and know that they would be up to the job. The tanks are not that large and I think using a gas torch of some sort would just deconstruct the entire tank! I have seen a 100W soldering iron on eBay, not expensive but I'd prefer to ask for advice first rather than just buy something that may not do the job.
Any advice much appreciated and I don't get emails telling me that someone has replied to a post so please accept my apologies if I don't reply to you straight away.
Thank you,
Simon
