Author Topic: 3D Modeled Parts and Guns  (Read 15960 times)
JerryTodd
  • Scale Sailor
    • Modeling Projects
« on: February 01, 2025, 10:26:41 pm »
I got into 3D resin printing specifically to make parts for my models; wheels, casks, crew, blocks, fairleads, guns, etcI work mostly in 1:36 scale and 1:20 scale, but the 3D models are usually scalable and anything not too specific to my models, or that other may find of use, I share on Thingiverse, especially American Naval Guns from 1850-1870.
I got a request a while ago for an Armstrong 110# Breech-Loading-Rifle and made it because it was interesting.  I've been revisiting this model to make the breech functional (actually screw in/out).It's still a work-in-progress, and I think I'll have to make separate models for smaller scales than 1:36, like 1:96, 1:72, etc.  When complete, with carriage and slide like the reproductions on HMS Warrior, it'll be posted on Thingiverse as well.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: 3D Modeled Parts and Guns
« Reply #1 on: February 12, 2025, 12:13:14 am »
The scale threads on the breech-screw/breech were too fine when printed, and took a lot of hand-work to make functional; I also didn't thing they'd work at all if scaled down from the 1:36 scale I built it in.  I gave it coarser threads, and printed it again.  This time it worked great.  The separate "lever" (part with the pawn-shop balls) needed the keeper-pin holed drilled out, and I haven't looked for wire to use as pins yet.  I printed the carriage and slide, but gremlins chewed a corner of the slide during the print.
Feeling I was fairly done with this, I went and started the 40# Armstrong BLR.  I don't know why.  This one went relatively quickly as I could repurpose the breech and breech-screw with a little work.  Again, I mainly referenced the gun on Warrior for details, and the measured drawings and 3D sight masses were supplied by Carlo, a 19th century Artillery junkie in Italy.  The print had some issues, and I realized I left out some details, like the "tray" on top of the breech to rest the vent-piece on.  I fixed the issues and fattened some parts to print better.  It's all posted on Thingiverse now.While I'm fixated on Warrior's armament for some reason, she had 110's mounted on 2-truck carriages, and I think 68# shell guns, also on 2-truck carriages, so I guess I should get on doing those as well.
Trucker
« Reply #2 on: February 12, 2025, 05:35:51 pm »
Thats really nice, is the actual model as smooth as it looks, i got my self a printer too for the same reason as you, but, i got the filament type but its a bit disappointing as the final results go, though my models are modern day working boat , but small parts are still required, so thinking of a resin printer now.
Trucker
JerryTodd
  • Scale Sailor
    • Modeling Projects
3D Print Quality
« Reply #3 on: February 12, 2025, 08:12:57 pm »
Resin printer surfaces are much smoother than what filament printers produce.  Filament printers are like cake-piping machines, stacking up beads to build a surface.  Some can be pretty fine, but I doubt they can match resin in any sort of consistently reliable way.  Resin parts are relatively finely layered and have a sort of silky, or butterfly wing appearance and feel to them.  The thickness of the layers can be adjusted, but too thick or too thin will cause problems in printing.  Antialiasing will fuzzy the edges of the layers and can make the part more smooth, but it can also cause issues with tiny openings, akin to flash in injection molding.There are processes people use to get a more polished surface on their prints, like brushing on resin and hardening it to fill in the the tiny stair-stepping the layers cause, or even sanding.  People that print figures typically do this to get smoothness on the skin parts of their half-naked fantasy figures or anime girls, which isn't an issue for me.  I don't have shelf space for all those figures, it's taken up with little cannons.  I do find the texture of resin printed parts is excellent tooth for painting, and after cleaning with alcohol, are perfectly ready to paint.
On that note...  Since my parts are going on RC working models and will therefore be outside, it's very important to prime, paint, and clear-coat them to protect them from UV as much as possible.  Being made with UV light makes them very susceptible to UV over exposure; an issue with filament printed parts, but nowhere near as much so.
The other form of 3D printing involves fusing a powder with a laser in layers like resin printing.  If this makes it to home use as resin printers did, I think the durability matched with the fine detail of resin will be great for for RC modelers and half-naked figure makers as well.  ;)
JerryTodd
  • Scale Sailor
    • Modeling Projects
« Reply #4 on: March 10, 2025, 11:21:20 pm »
Warrior has some 110 BLRs on different style of carriage, but I haven't been able to find data to make accurate models for these guns as yet.  Obviously I already have the 110# gun itself modeled, and the 68# MLS was easy enough.  I have an inquiry in with the folks at HMS Warrior to see if they'll share the data I need, but I'm continuing my search just-the-same.
In the meantime, I decided to give in and finally make the iron Marsilly style carriage the US Navy adopted to replace the wooden Marsilly carriages.  Oddly enough, I haven't found any proper drawings for this one either.  I found one drawing from someone making a fire-able model and scaled that to the diameter of the trunnions of my IX inch Dahlgren, and used photos of some existing gun and carriages to "eyeball" the details.  In regards to my "Gun of Constellation" project, I don't know if the IX Dahlgrens she carried through the 1870's were on wooden or iron carriages.  I'm leaning towards the iron as she was a training vessel, and that was the "standard" for that gun at that time.  Note: that supposition is called "logic" and when it come to the US Military of the 19th century, logic seldom applies.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Printing again
« Reply #5 on: May 26, 2025, 11:08:11 pm »
Printing was held up some because a resin leak in the Mars 3 printer.  I though it was worst than it was, and got a Mars 4 before the "Stable Genius's" tariffs kick in - they are made in China after all.  While the Mars 3's screen had failed, I replaced it and that fixed it.So now there's two print humming along as I type this.Modeling some more included blocks for Constellation, cradles for her boats, and reworking her Night Life Buoy, a 50# Dahlgren Rifle, the tube for the XV inch Dahlgren gun (a request from someone building a Monitor ironclad model.
I finally got around to printing another gun in my Guns of Constellation project, the XI Dahlgren on an iron pivot carriage.  Someone beat me to it by printing it with a filament printer.  The next gun in this set is on a printer now; the 100# Parrot Rifle on a wooden pivot carriage. (the other printers doing a stack-able tray for my Testors paint bottle)
JerryTodd
  • Scale Sailor
    • Modeling Projects
French Guns
« Reply #6 on: August 04, 2025, 12:00:23 am »
A modeler building a 1:100 scale static model of the French steam frigate L'Orenoque wanted more accurate guns than the kit supplied.  Since I made the guns for his Harriett Lane, he came to me for this.He knew the tube he wanted, but the carriage was an unknown (as is often the case).
He sent me a drawing of a carriage, with no scale, and didn't seem right, then someone in yet another forum hooked me up with a French reference, that had another carriage for this gun, that was lower, and seemed more stable: Aide-mémoire d'artillerie navale : imprimé avec autorisation du ministre de la Marine et des colonies
I modeled and printed 7 of this gun in his scale and sent them to him. (pic of them sitting on his model below)The STLs for both guns are available on my Thingiverse page.
Page created in 0.03 seconds with 22 queries.
