Author Topic: Schnellboot torpedoes firing system  (Read 19596 times)
tassie48
  • bikes birds and burnups
« on: March 11, 2025, 11:44:27 am »
Hi crew looking for ideas on how to get the torpedoes to fire out of the torpedo tubes ,have the torpedo doors on the Schnellboot working correctly port then std open close , I  looked at a spring loaded solenoid, high speed actuator, even tried a rubber band on a servo release  system from a spear gun  as it is 1/12 scale some room for equipment, air release was a disaster both in cost and ability to fire the torpedo out so if anyone has achieved firing torpedoes keen to learn more tassie48
tassie48
Torpedo launching
« Reply #1 on: March 18, 2025, 10:12:32 pm »
Hi Crew do any of you sub guys launch torpedoes from your subs if so what or how do you launch the torpedoes from the torpedo tubes trying to figure out how to launch torpedoes from a schnellboot torpedoe tubes any all help much appreciated tassie48
chas
Re: Schnellboot torpedoes firing system
« Reply #2 on: March 21, 2025, 09:01:28 am »
Hi Tassie, the next issue of model boats, out soon, has an article about fireing torpedoes from an mtb. It should be an interesting read.
Akira
Re: Torpedo launching
« Reply #3 on: March 21, 2025, 12:28:11 pm »
Tassie, You might want to look at The SubCommittee website for launching ideas and systems. Also, check out Bob Martin's site. he sells complete systems, here: https://www.rc-submarine.com/
philk
« Reply #4 on: March 21, 2025, 01:45:23 pm »
Just reread your post you quote 1/12 scale that's a lovely big boat. Any pictures
philk
« Reply #5 on: March 21, 2025, 08:48:11 pm »
Difference with a sub is that the tubes are always flooded and underwater so torpedo can swim out. Not so easy with tubes above the waterline
« Reply #6 on: March 22, 2025, 10:27:30 am »
MK148 ADCAP GAS TORPEDO: Design, Build, & Test Validation - YouTube
  You''re going to have to blow the torpedo out of the tube but you won't be able to scale nature, it's s**t or bust. Full size torps don't swim out, the bubbles give it away.
philk
« Reply #7 on: March 23, 2025, 08:31:34 pm »
The new improved mk 48's have a swim out capability
rhavrane
  • Steam passionate collector
« Reply #8 on: March 23, 2025, 08:51:18 pm »
Bonjour,
I don't know if that will help, I found this video I did 10 years ago : https://youtu.be/EJAdDqz3LxM
(I French but with subtitles)
Raphaël
« Reply #9 on: March 23, 2025, 09:43:04 pm »
Haven't seen any Schnellboots launching Mk 48s
tassie48
« Reply #10 on: March 24, 2025, 01:34:23 am »
Thanks crew still trying to figure out just how to launch them out of the tubes to get themflying my torpedoes are rc so some fun to be  had with them G7 models from memory tassie48
« Reply #11 on: March 24, 2025, 07:46:24 pm »
   https://www.reddit.com/r/WW2GermanMilitaryTech/comments/1ixz49a/schnellboot_torpedo_launch_in_1944/
 Bearing in mind  the boats are fast it looks like they just open the tube and stop the boat
« Reply #12 on: March 24, 2025, 08:44:58 pm »
as mentioned earlier, there is an article in the latest (April) issue of Model Boats magazine on this although I found it a bit difficult to understand. Apparently the torpedoes are discharged using a spring and air gun trigger mechanism. On the way out of the tube there are magnets which trigger reed switches in the torpedoes to start the miniature torpedo motors running so they can be retrieved from the pondside. It all seems to work but a bit more explanation would have been useful
tassie48
« Reply #13 on: March 25, 2025, 06:10:22 am »
Colin many thanks will follow it up now have a couple of ideas will build a working model to see how it works then refine it much appreciated tassie48
ddmckee54
« Reply #14 on: March 30, 2025, 04:58:06 am »
Tiver21 on his YouTube channel a couple of weeks ago had a video of building working 1/72 scale torpedoes for his 1/72 scale Kilo class RC sub.  He used a small solenoid for his launching system.
https://www.youtube.com/watch?v=24oU48JS8RU
Too many irons, not enough fire.
tassie48
« Reply #15 on: March 30, 2025, 05:06:50 am »
Absolutely fantastic good starting point just enlarge many many thanks tassie48
« Reply #16 on: March 30, 2025, 09:52:47 am »
"You're gona need a stronger spring." It needs to chuck the torpedo out of the tube, UNLESS you're making a submersible e-boat?
 Regards  Ian
« Reply #17 on: March 30, 2025, 12:14:29 pm »
I'll say Ian,on that video on my post it looks like the boat has slammed on full astern to help
« Reply #18 on: March 31, 2025, 09:14:58 am »
Sorry jaymac, Reddit is yet another link i'm not prepared to use. No matter how many submarine launch systems are shown, a torpedo propeller will never be big enough to 'Bite' enough air to push it out of the tube of a surface vessel and by the same token, a spring or waft of a compressed gas will not have the control to realistically eject a 'slug' of plastic from said tubes. I reiterate, yer can't scale nature'
tassie48
« Reply #19 on: April 04, 2025, 09:16:27 pm »
Hi crew currently working on plan B system A high speed actuator fires the torpedo down the tube a miniature air bottle fires a burst of air to simulate the noise of firing,  the first actuators threw them about 3 .8 meters fwd so I tried a smaller type it was too far so number three I got about 2 meter throw ,the torpedo tube is made of  copper a light Grease of castor oil allows it to both slide and fly still some more trial-and-error work to get it right but pretty happy so far , getting the correct angle is a tad hard , finally got the weight balance to a manageable level the rc in the torpedo is fine both travel and correct line first ones were very wonky lol,trying to simulate the trail of bubbles first attempt was a bath bomb just to bubbly second was a co2 cylinder too short a run ,third attempt is a small air cylinder with servo valve to allow bubbles trail had some laughs with the torpedo missed so I backed up and steered it to the target so wrong but so funny, the rc battery slipped and well it was looking like a total disaster nose up out of the water then nose down trying to bury itself still we learn as we go tassie48
« Reply #20 on: April 04, 2025, 11:01:44 pm »
Topic merged  :-))
Page created in 0.107 seconds with 21 queries.
