Author Topic: Visby Corvette 1/72 build  (Read 1323 times)
T888
« on: April 19, 2025, 09:01:25 am »
As I’ve parked my Type 26 build, I’ve always wanted to building the Visby corvette. After digging out the plans I had in store I found a pair of Graupner small jet drivers.
So last week I ordered some sheets of plastic card which I got Thursday. I’ve already cut out the bulk head patterns and started to transfer them to the card.
Regards David
philk
Re: Visby Corvette 1/72 build
« Reply #1 on: April 19, 2025, 10:25:56 am »
Love this boat mNy years ago a former treasurer of the cygnets club built one looked great on the water
« Reply #2 on: April 19, 2025, 03:33:11 pm »
        :-))   O0
T888
« Reply #3 on: April 22, 2025, 09:48:56 am »
Over the week end I’ve cut out the bulk heads and started the hull construction.
I installed the jet drives and have found I need the modify the reversing buckets as they clashed.
Regards David
« Reply #4 on: April 22, 2025, 04:41:24 pm »
are they handed ?, and if so, what would be the consequence of reversing the handing as it looks like the buckets are not symetrical, assuming the sorter side is not outside i.e. pic 951 is the port side
T888
« Reply #5 on: April 22, 2025, 06:21:32 pm »
Hi warspite,
The buckets are handed, but the props are not. The modified sides face inwards to the centre line, so the wash will I hope run under the hull and give reverse flow.
From what I’ve found on previous jet drive projects is the buckets are only used at slow speeds (can steer in rever using the buckets) or emergency stop.
Regards David
« Reply #6 on: April 22, 2025, 10:55:27 pm »
I see now pic 951 is the bucket modified by cutting it.  :-))
T888
« Reply #7 on: Yesterday at 04:02:42 pm »
Hull nearly completed, just need to fill and sand ready for priming also need to add spray rails.
Once I’m happy with the finish I’ll add the hull openings and the main intake vents. The opening as there flush on the actual ship I’ll do by using solar film. This is very very thin and once topcoat is applied they will just be visible.
Regards David
frogman3
« Reply #8 on: Yesterday at 06:08:04 pm »
HI Dave what happened to the belfast you was building ?
chrisb :-))
T888
« Reply #9 on: Yesterday at 07:44:50 pm »
Hi Chris,
I’ve put it on hold as I was finding the base draw info I was using was way off and after seeing actual photos of the T26 I was having to do to many major mods
Regards David
frogman3
« Reply #10 on: Today at 09:00:51 am »
HI Dave yes i see your point no good buildin the part if on the real ship they go an alter it is it  so makes a lot of work for nothing but i'll be followin  as im goin for a sail sunday up at norwich pond with my norfolk first time this yr just got to hope she still works  okas she hasnt been powered up for a yr or so just hope for nice wheather
ATB SIR
chrisb
Page created in 0.108 seconds with 22 queries.
