Author Topic: Model Blocks (Small Scale) For Model Boat Halyards  (Read 25204 times)
Pat-K
« on: May 06, 2025, 03:07:58 pm »
Hi Guy's
After a number of model blocks for signal halyards on model boat (please see attached pictures) - been trawling the internet but cant find any small enough - can anyone help with a supplier please
Thank you as always in anticipation of your help.
Pat
Re: Model Blocks (Small Scale) For Model Boat Halyards
« Reply #1 on: May 06, 2025, 03:27:05 pm »
You don't say what size you want. There are some 4mm single blocks:
https://www.cornwallmodelboats.co.uk/acatalog/Occre-Block-Single-Natural-4mm-OC17000.html
and plastic  5mm single blocks with a loop which I have used for signal halyards:
https://www.cornwallmodelboats.co.uk/acatalog/F64-1-Rigging-Block-Single-5mm-BF64_1.html#SID=133
Double block versions are also available.
Pat-K
« Reply #2 on: May 06, 2025, 03:29:21 pm »
Thank you so much for that Colin, had seen them already - a bit big for what I need - I think 5mm is as big as I need and don't mind if there are 3D printed
Pat-K
« Reply #3 on: May 06, 2025, 03:50:33 pm »
Does this give you all a better idea of the scale needed
chas
« Reply #4 on: May 06, 2025, 03:58:40 pm »
Would the boxwood blocks that Amati make be any use, maybe with a slight modification?  Sizes down to 2mm.
« Reply #5 on: May 06, 2025, 04:45:00 pm »
Check here http://www.squirestools.com/files/12-19b.pdf   Page 351
I Think the prices are well out of date. Give them a call
Pat-K
« Reply #6 on: May 06, 2025, 05:21:04 pm »
Thank you for all your replies guys - much appreaciated
Page created in 0.307 seconds with 21 queries.
