Technical, Techniques, Hints, and Tips > Radio Equipment
flysky fs 6ix problem
(1/1)
MadMax:
i have flysky fs 6ix and 4 recievers all 6 channel
i want to put them on one tranny as the fs 6ix as 10 model memory
how do i get the tranny to accept a recieiver on each channel if any body can help i would be gratefull
madmax ,,,,,,clifford
mbm999:
Not sure I've quite understood the question but here goes .....
The transmitter can store 20 model names and each model name will be bound to a single receiver.Each channel on the receiver can go to a servo.
So, I don't think you can do what you want in the way you describe.
Cheers,Mark
modboat:
Hi
I think you may mean, you have a transmitter and four receivers.
What you want to do is have each of those receivers in a model so you will then have four different models with a receiver in each.
How do you get the four models with receivers on to your transmitter.
You have to bind each receiver to the transmitter.
Then set up your model preferences for each model/receiver. Servo travel, Motor left right turn, servo reverse to name but a few.
This is explained on page 10 and 14 in the manual which you can download for free off the net.
Hope the above helps, if not PM me as I have a FS-i6
Good Luck
JonC:
Modboat is correct, there are a number of videos on YouTube which explains this.
As default these are model- flysky01-flysky02 -flysky03 ect ect.
Each receiver needs to be bound to a seperate model number on the transmitter, (number the receivers). You can rename these models to registration numbers on your boats, or their names.
The binding process is quite simple, bind key plugged in to bind port, power 4.8-6v battery pack ready to be plugged into any other channel. Switch transmitter on while holding down the bind button on transmitter. Then plug in power to the receiver, after a few moments you'll see the red led on receiver stop flashing and go solid red. These are now bound. Unplug bind key power everything off, power up transmitter then receiver. Test with a servo.
Select a new model on transmitter, (press and hold cancel to save change). Then repeat above process.
Jon
Navigation
[0] Message Index
Go to full version
