Pages: 1 2 [3]   Go Down
Author Topic: 1/96 HMS Alacrity Type 21  (Read 6585 times)
T888
Re: 1/96 HMS Alacrity Type 21
« Reply #50 on: November 05, 2025, 08:31:02 am »
Hi Ray,
So true  :-))
Regards David
T888
« Reply #51 on: November 08, 2025, 11:19:22 am »
Some more progress
Regards David
T888
« Reply #52 on: November 12, 2025, 07:06:42 pm »
Hi All,
Currently working on the main mast, still trying to work out the best way to have the mast lights working. Options are to use the 0.5 LEDs or fibre optics Also I’ve need to make a master for the Abbey Hill UAA-1 radar base. (Photo 3)
Regards David
T888
« Reply #53 on: November 17, 2025, 12:43:02 pm »
Slow going, I’ve got to do some casting of fitting but it’s a bit cold.
Regards David
T888
« Reply #54 on: November 19, 2025, 09:04:03 am »
 casting fittings today,
Regards David
Detomo
  • Model Boat Mayhem Forum is Great!
« Reply #55 on: November 19, 2025, 03:17:39 pm »
Hi, following with interest, what type of railings will you use. As i used brass etching , but some people may use cast three hole stanchions, keep the pic's coming  :-))
T888
« Reply #56 on: November 19, 2025, 03:48:51 pm »
Hi Detomo,
I’ll be using Scalelink RN Photo etched stanchions.
Regards David
T888
« Reply #57 on: November 22, 2025, 03:26:53 pm »
Detailing the bridge section
Regards David
T888
« Reply #58 on: November 22, 2025, 03:29:55 pm »
Making the main nav light housing on the bridge wings, just need to mark up the light slots add the LEDs plus lenses
Regards David
T888
« Reply #59 on: November 23, 2025, 04:20:26 pm »
Installing the LED bus bar for Nav, Bridge and mast lights. Doing this before to much detail is added.
The LEDs can and will be removed to allow painting.
Regards David
« Reply #60 on: November 23, 2025, 10:23:26 pm »
I love the way you deal with all the electricals on all your models David - just so neat & tidy, a crackin job O0
Cheers,
T888
« Reply #61 on: November 24, 2025, 08:52:48 am »
Thanks Ray,
Yep I do like to have the wiring tidy. Over the years I learnt to plan out and number the cables so they can be easily identified. So any faults can be traced.
Regards David
Detomo
« Reply #62 on: November 24, 2025, 09:18:29 am »
Hi, please can you tell me where you got the lighting bar from, very interested in getting one. Doing a great job  :-))
T888
« Reply #63 on: November 24, 2025, 09:44:34 am »
Hi Detomo,
I got them from Scalewarships, they are not no there Forge Electronic section as yet, but if you contact them and ask for LED Bus Bar they will know what your asking for.
Regards David
Detomo
« Reply #64 on: November 24, 2025, 10:20:39 am »
T888
« Reply #65 on: November 24, 2025, 12:22:14 pm »
Hi Detomo,
I’ve just spoken with Scalewarships via email, FYI There phone line is down, so best to email them
Regards David
Rob47
« Reply #66 on: November 25, 2025, 04:06:12 pm »
Also Kyle’s Lights about £4.50
I will finish this model
minimariner
« Reply #67 on: November 25, 2025, 09:56:42 pm »
                                                             Its    Kyteslights.com
T888
« Reply #68 on: November 26, 2025, 11:02:38 am »
Ha, found my detail sheet for the ABBEY HILL UUA1, so can start making a master.
Regards David
T888
« Reply #69 on: November 27, 2025, 10:44:03 am »
Master made, next making the mould.
Regards David
T888
« Reply #70 on: November 27, 2025, 06:02:42 pm »
Mould made and casting taken.
Regards David
T888
« Reply #71 on: Yesterday at 10:39:29 am »
Update working on the main mast lights,
By using 2.5mm O/D plastic tube and filling a slot in the tube I’m able to feed the 0.5mm LEDs in to the tube.
Regards David
« Reply #72 on: Yesterday at 10:56:42 am »
Dave,
Could you not cast a brass tube inside the Abbey Hill as these are a known weak part and vert easily damaged.
T888
« Reply #73 on: Yesterday at 11:24:51 am »
Hi Bob,
Short answer is yes, however the casting resin I’m using has a good tensile properties.
Regards David
Pages: 1 2 [3]   Go Up
Page created in 0.02 seconds with 18 queries.
