Author Topic: STEAM ENGINES AND ACCESSORIES FOR SALE  (Read 214 times)
Dean's Marine
    • Dean's Marine
« on: December 05, 2025, 12:46:21 pm »
  FOR SALE
 These items are from the DEANS MARINE workshop and are surplus to requirements as we will no longer be carrying steam related products. Deans Marine / Mamod steam accessories
These parts have only been used as display units, lubricated  and run on compressed air.
  These items will remain on sale until the open days on the 20th Dec  unless purchased beforehand  and will then go on general sale / auction
  This is a brand new item  1 only
Inline twin cylinder double acting engine with r/c operating control valve for fine control in fwd & reverse with a geared  down transverse drive to swing big props at hi torque or cross drive to paddles  This unit was being developed as a complete unit to drop in to a future range of  steam powered models.
 £95.00
Ceramic burner, gas tank, pipes and fittings Re-fillable butane gas tank with adjustable burner and control valve
 £85.00
INLINE LUBRICATOR  2 off
Precision designed displacement lubricator for steam oil feed in to your engine. contents 1x reservoir 2 x 1/8" olives 2 x compression nuts
 £18.00 each
Single cylinder slide valve engine geared drive and heavy duty flywheel for smooth running
 £85.00
PRESSURE GAUGE.
 Screw in pressure gauge for constant reading of boiler pressure
 £19.00
 contact us at deansmarine@yahoo,co.uk for interest in these products.These items are not in our online shop more clear out items to follow
 Regards Deans Marine
Dean's Marine
    • Dean's Marine
Re: STEAM ENGINES AND ACCESSORIES FOR SALE
« Reply #1 on: December 06, 2025, 12:20:57 pm »
FOR SALE
 These items are from the DEANS MARINE museum and collection and are surplus to requirements as we need more space, time for a clear out of all the "use full things " we keep
  These items will remain on sale until the open days on the 20th Dec  unless purchased beforehand  and will then go on general sale / auction.
Very rare
 Archer miniature gas torch with spare bottles and instructions, a collectable item sold as seen.
£25.00
Davies Charlton diesel engine with quick start and instructions
£25.00
Ripmax RMA RADIO SET
Receiver double actuator and  steering unit, possible working but more for the collector
 £30.00
OHLSSON & RICE
3/4 HP 4 stoke engine with silencer, heavy duty coupling and fuek tank & reocil start
turns very freely and was ruuning when removed for the model 15 years ago, stored in the dry
  sold as seem    £95.00
 D/C
Diesel engine with exhaust and water cooled head
does not turn very easily possibly needs a good clean  sold as seen
 £20..00
M-E snipe
Diesel engine
 £20..00
M-E snipe
Diesel engine
 £20..00
20mm TWIN OERLIKON  approx 1/24 scale
 Display item  not to exact scale
Made from brass with elevating guns and sights turned ali base plate and brass base cone
 £35.00
TEXACO FIRE CHIEF
Display presentation model
approx 22cm long this is made from metal so is not a sailing model
£45.00
  more to come from the clear out Regards Deans marine
Page created in 0.017 seconds with 18 queries.
