So a lot of work. for what does not seem like a lot of progress.
1) the teak capping to the plank tops has been installed. The four laser cut pieces to do this were pretty accurate with just a bit of careful trimming to ensure they butt up to each other at bow and stern. The whole laser cut sheet these were attached to was stained at the outset of the build with the supplied stain. - a powder you mix with water. It was then given a few cots of clear varnish. To be honest, if starting again I would have opted for a different, lighter stain.
2) the stern rail, again teak capped and mounted on supplied wooden balustrades. Each balustrade had to be drilled top and bottom to accommodate a short length of 1mm brass rod at the bottom and 0.8mm top for brass nails. A bit fiddly but not as difficult as I first imagined.
3) the forward brass railing was created from the coiled brass rod supplied with the kit. Straightening that was a bit of a challenge involving locking one end in a mole wrench, standing on the wrench and pulling up as hard as my elderly bones will allow the other end caught in a pair of pliers. With a suitable length straightened the pulpit was formed by finding a suitably radiused shape - in my case a screwdriver handle to form the forward pulpit then roughly curving the long lengths to fit the hull shape.
4) the supplied propellers are 35mm two blade with a very coarse pitch and both the same hand and therefore not contra rotating. I decided to replace these with brass three blades. I also found that I had mounted the prop tubes too far into the hull and so did not have clearance for 35mm props so sourced a pair of 30mm three blades, one right handed and one left handed.
5) I started to seriously address the radio installation. I have opted for the same system I have used before on a Smit Rotterdam to get full independent motor control. Each motor has its own esc and battery with the red (power supply) cable to the receiver connector disconnected on one esc as only one esc should power the receiver. This gives forward/stop/reverse on vertical movement on right and left sticks. I have opted for a couple of cheap 20amp Chinese escs (?6 a throw) but these seem to work ok. I will mount these and the receiver in my normal way via Velcro. I will wait until any ballast is sorted out first before mounting them.
I centrally mounted the steering servo but found that the rudder tube is quite close to the aft bulkhead and so the tiller has to be mounted about 45 degrees from parallel to the bulkhead. The supplied tiller I found was too short and came close to being at 90 degrees to the bulkhead and in danger of locking up at hard over. I therefore made a larger tiller from hard plastic which copes with the servo movement easily.
Finally, I have gone for 2x 2s 3ah Li-ion batteries on offer from Amazon complete with charger for 14 quid! I anticipate that the 385 motors will not draw much more than 2 amps so these should give a comfortable hour sailing time.
Next step is a bath test to check for leaks and also what ballast is required.
6 I have started preparing for mounting the masts, yards and rigging. Cast metal jack screws are supplied and these are attached to the deck by brass eyelets. The quality of the castings is poor and the was a lot of flash which required trimming off. Also, all of the holes required to be drilled out to accept the .8mm eyelets. As I write, I will have to enlarge the holes at the other end to accept 1mm diameter rope.
On a related topic, the mainmast boom is very close to the removable cabin. Once the running rigging is in place removing the cabin for access to machinery might be difficult so some thought will be required. Maybe raising the position of the booms is required?
7 Finally, I have spent quite a lot of time building and painting small parts.
Onwards and upwards!
