Author Topic: My Cygnus Seafish 33 :D  (Read 6114 times)
kingfisher
« on: June 16, 2006, 01:32:36 pm »
Hi There This Is My Cygnus Seafish 33 Which I Made From Scratch Bar The Hull Which Was Made By Andy Of Models By Design Who Now Has The Cygnus Moulds In Stock..
There are a few pictures here from when i was first building it to how she sits now still a work in progress really. Needing Net Drums Etc. Lemme Know Your Feedback
Cheers :D
Dave Leishman
Re: My Cygnus Seafish 33 :D
« Reply #1 on: June 16, 2006, 02:07:30 pm »
Looks good Kingfisher :-)
I was at Andy's on Wednesday and picked up my Cygnus too. Identical to yours, except mine's blue.
I'm looking for a real boat to base the model on now (preferably a lobster boat).
kingfisher
« Reply #2 on: June 16, 2006, 03:38:31 pm »
thanks i am happy with it just need to find time to finish it.will make a good crabber potter just bought cygnus 38 off andy going to make a potter with it next project .i also have the cygnus cyclone fast netter just needs a small amount of finishing. good luck with the build they are exellent boats cheers.
andywright
« Reply #3 on: September 29, 2006, 10:27:28 pm »
Have Models by Design got a  website?
Navigational Aids vessel Master. Old Conway 70-72
Voyager
« Reply #4 on: September 29, 2006, 11:19:18 pm »
That's a fine looking boat there shipmate! ;)
DaveB
« Reply #5 on: April 09, 2007, 12:03:11 pm »
DavieTait
« Reply #6 on: April 09, 2007, 03:00:44 pm »
We have well over 200 photo's of this size and style of fishing boat on the trawlerphotos website
http://www.trawlerphotos.co.uk/gallery/showgallery.php/cat/525
I have close up photo's of a 1 year old GM33 rigged for potting to put up shortly ( Sorry Dave just found them on a disk !!! lol )
Click inside the thumbnail to take you to the main photo
Davie Tait
Davie Tait,
Scotland
Tug Man
« Reply #7 on: April 13, 2007, 03:22:04 pm »
KingFisher Did plans come with the hull? I think Andy does a terrific job moulding these models.
Don
Guy Bagley
« Reply #8 on: June 23, 2007, 02:34:53 pm »
hey kingfisher, nice use of the cap maquette fittings... are the fenders also cap maquettes ? if so be carefull i found mine perished split and dropped off - plus being solid silicon they sink!
DaveB
« Reply #9 on: June 24, 2007, 09:39:45 pm »
Sorry forgot to resize the photo's i called mine Rosalie and she is still not finished i should have done so but wanted to make a start on Phantom.
Dave B
portside II
  • tugs at rest
« Reply #10 on: June 25, 2007, 05:11:57 pm »
hi i have the gm33 from dave at mods by design the early one with the forward wheel house do you lad's have any photos of motor instalation and what size prop shaft and motor to use .
daz
Tom Eccles
« Reply #11 on: June 25, 2007, 06:00:11 pm »
Hi Kingfisher
Good looking model!
What is the secret of that finish on the hull? It looks excellent to me.
Cheers Tom
portside II
  • tugs at rest
« Reply #12 on: June 25, 2007, 09:56:30 pm »
exsquse me it's Andy from models by design
DaveB
« Reply #13 on: June 26, 2007, 05:35:40 pm »
Portside i used my last type 6 motor from mobile marine and a 50mm prop no photo's as yet i may be able to do some at the weekend.
Dave B
portside II
  • tugs at rest
« Reply #14 on: June 26, 2007, 05:45:46 pm »
thanks DaveB i have just started on the hulland trimming the deck as a start what is the prefered method to fit it down and how far down the inside should the deck be .
I have the timber capping strip ,beech i think and i dont want to fit the deck too high or low.
I have not seen too many pic's of that type apart from whats on Andy's web site did you cut free-ports ,what size and how many.
so many questions sorry :).
daz
DaveB
« Reply #15 on: June 27, 2007, 06:29:38 pm »
Portside i fitted the deck level with the bottom of the rubbing strake and only put in a couple of freeing ports there does'nt seem to be any set amount, it may be worth having a look on the cygnus website. I bought the teak capping from Andy and used several coats of oil instead of varnish. Andy now does a deck with a watertight hatch as i had an older model i built a normal hatch with coaming but big enough to take a 12v 7amp battery. When you fit the deck be careful that its not to tight a fit or the wheelhouse will be too tight.
kingfisher
« Reply #16 on: June 30, 2007, 03:02:18 pm »
Hi the hull is the orignal gel coat out the mould gunwhales are sprayed with two pack paint.She is now finished need to get some photos up on here now but not sure how to do it i run a 65mm prop and an mfa 850 motor belt drive 2.1 reduction i have gone bigger on the prop but seems better on this setup an 800 would be better as less revs .
portside II
  • tugs at rest
« Reply #17 on: June 30, 2007, 11:23:45 pm »
had some info from Andy the other day ,he recomends the largest prop you can fit , so it's a 80mm 4 blade raboche .
and the torquiest motor ,i intend to fit a metro fan motor as it's slow and torquy .
the only other thing is the shaft ,if i fit the motor to the prop then the shaft will be about 15" long  if thats the case then i will prob fit two shafts and two universal coupling's .
daz
Page created in 1.201 seconds with 22 queries.
