Pages: 1 2 3 [4]   Go Down
Author Topic: Advice required - how to build a very complicated shaped boat?  (Read 25213 times)
Arrow5
Re: Advice required - how to build a very complicated shaped boat?
« Reply #75 on: December 24, 2007, 09:42:31 am »
I`ve been playing with the editing on my pics of the Earthrace boat. Some details emerged that may be of interest when it comes to the final finishing.  Top of fore-deck and top of wings have anti-slip panels, hatches, rails ,also shows cooling water outlets in hull etc.  Have a look on www.flickr.com search for Arrow5 pics.
..well can you land on this?
RipSlider
« Reply #76 on: December 24, 2007, 03:19:59 pm »
Argh!
A wee bit of a problem has just come up.
Following on from a discussion with one of the 1:1 scale earthrace group, I reworked by calculations on how much force the outriggers will need to take. The real boat spent £500,000 PER RIGGER just for the carbon cloth and resin for those riggers they have to be that strong
I get an approx total of 200lb of upward, torsional and lateral force at 25 knots in my 1:24 sized model......
From a construction point of view the forces should be fine from the point of view of the rigger actually being able to support it, although I might play it safe and bind the riggers with a high IM carbon ribbon under tension to really keep it together.
What it does mean though is that it won't be possible to have the outriggers detachable, they will have to be bound solidly into the main hull as a monocoque construction. That means that I'll have to go in via the back of the boat.
Damn damn damn. What a pain in the backside..
More money and time needed now.
Arrow5:
Thanks for the flickr pictures. I'm in a grump at the moment, so will have a better look at them later.
Many thanks
Steve
« Reply #77 on: December 24, 2007, 03:36:39 pm »
I'll bet your 1/24th scale model doesn't weigh 1/24th of the original? Scaling nature Steve?
    Ian
Sean
« Reply #78 on: December 25, 2007, 12:45:21 am »
Hello,
I wondered about the forces on the outer hulls. You could still have the top removable above the outrigger and design a "cage" in the main hull to hold the forces of the outer hull forces. If there is not a sufficient structure to hold the outer hulls out they will crush the main hull. You could still design the top for access with a internal structure to hold the forces. Maybe a aluminum cage instead of pricey carbon? Great build. Are you going to sell some after your design is complete and tested? Race circuit of earthracers around the world.
Best Regards,
Sean
« Reply #79 on: December 25, 2007, 02:18:17 am »
Hi Ripslider Merry Xmas,
I think it is still do-able in two halves. Like I said, I am not an engineer but I have a few immediate thoughts.
1/
I tend to agree with Circlip,
200lbs seems to be wrong by an order of magnitude.
How did you arrive at your figures?
Did you square root your scale figures or cube root them?
And a scale speed of 25 knots will not be 25 Knots.
But reduced by your scale factor.
And the figure for the real boat will be max theroetical stress the boat may experience, plus a wide safety factor.
At what point in a boats performance will she be under max stress? Submerged in a 100 year wave? And is the model likely to experinece this?
I don't know what the safety margins are for marine engineers, but they are wide because lives are at stake.
so have another glass of mulled wine and redo the calcs. And get someone else to check them.
After Christmas try and find out how the real boat arrived at those figures, and what will not apply to you.
2/
I also agree with Hastings. If the largest stresses are within the outrgger arms/wings, then the two outriggers and the wings as one piece should still work.
3/
If you are correct 200lb is manageable.
You could build a subframe/assy in to the hull with four vertical bolts.
The top half is lowereed vertically onto the hull and bolted into place.
4/
Don't let it spoil yer xmas dinner.
Have some extra turkey and brandy for me.
« Reply #80 on: December 25, 2007, 07:11:05 am »
If you go back a few replies Steve, rigidity of  the sponson wings was ALWAYS going to be a problem, an Tiger and I had sorted independently that a rigid centre section and going in from the back appeared to be the most logical solution. How about a casting for support? Hope you can manage to read this before the outlaws alcohol induced stupor and Mrs Steve's' hands on hip bit. Have a good one, best regards Ian
FullLeatherJacket
« Reply #81 on: December 25, 2007, 11:44:55 am »
Steve
I've been pondering how you're going to "mix" the rudder servos with the throttle so that they deflect less as the speed increases. I've hit a blank, except to remind you that you DO have a proportional Tx so just don't push the sticks over so far, maybe?  ;) Anyway, I think the Futaba tranny has exponential adjustment so you can "soften" the stick movement around neutral; that should do the trick.
On the other tack i.e. the bit about moving the inboard rudder less than the outboard one in a turn, you can do this mechanically by connecting the pushrods "off-centre". We used to do this to get differential ailerons on moggle hairyplanes before the introduction of computerised radios. Sketch thus:
If you muck about with the radial position of the pushrod connection on the servo disc then you can vary the relative forwards/backwards travel of the pushrod from neutral. The values shown are just how they fell out of AutoCAD. The total amount of throw/deflection is done by adjusting the "length" of the tiller arm connection (further away from the pivot = less movement and vice versa).
Suit yourself, but have a good 'un!
FLJ
RipSlider
« Reply #82 on: December 26, 2007, 01:54:52 am »
Ok,
This is going to be a long post, but I'll try to break it up into bits.
Had a bit of a breakthrough today, and one of Santa's presents has been a huge multi-part e-mail with a ton of attachments from my mole within the EarthRace group. Can't discuss the full contents, as I'm under an NDA for parts of it, but will discuss what I can.
OK, working through your posts in some from of order:
Pressure on the outriggers:
This is interesting. The 1:1 sized boat takes a different approach than we have been discussing. They have an amazingly complex piece of bent carbon "tube", roughly circular in cross section, which forms am "M" shape. Around this, they have built up a lightweight structure with carbon rods and sheet, and then clad it in carbon to give the outside shape.
To give you some idea of the engineering that they have had to use, the inner tube is designed to support stresses of up to 72.5 GIGA pascals - which my maths works out to be approximately 4000 ton-yards ( rather than foot lb's). This is obviously over-engenieered, but remember that they don't have an unlimited budget and only spend where they have to.
OK, to explain my 200lb figure first.
I'm reckoning on my model being able to hit 25knots. ( which has become realistic given new information about power systems - of which more below ).
I reckon that each outrigger will be placed under the following forces at this speed:
lateral force ( i.e forward motion pots pressure on the floats, and they want to band backwards) : 15lb
Torsional force (i.e floats want to bend upwards or outward/inwards - a twisting force ) 45lb
lift when submerged (as the outriggers are lifting planes - they're essentially funny shaped wings ) 40lb ( ish - assuming running fully submerged at this speed through a wave that is at least 1.5x length of boat )
approx 100lb per outrigger - 200lb in total.
All these figures have NOT been scaled from the full sized boat, but are based on a model a friend of mine pulled up for me based on information available from the area race web site, some calc's from the general arragement diagrams on there, and some back of the envelope calcs from me.
Currently I have a REALLY rough (becuase it's the first I've ever done ) CFD ( computational fluid dynamics ) model to cross check my friends model, and I'm satisfied that we're definately within an order of Mag. and probably 1/4 an order of mag. of accuracy, as the numbers do sort of relate to each other.
2) having a detachable top section:
As above, the outriggers are designed to act as "wings". When the boat is submerged as it travels through a wave, it's tendency is to dive. The "wings" apply a lot of upward force. This is the same force, when used in conjuntion with the dynamic ballasting, as the diving force. The result is that the boat stays on a level, and goes in one side of the wave, and out of the other at the same vertical height.
The force needed to do this is considerable, although totally dependant on speed ( just like a planes wing - apart from stall speed = 0). If the boat hits a wave at it's designed 25knot speed, it will produce approx a lift approx 5x the displacement of water from the outrigger arm and the float + half the hull. ( rough figures - found a roughly similar NACA areofoil and made some back of envelope calcs ).
As you can see, there will be a significant upwards force acting on the top section when the boat is submerged and at speed ( and remember it's specifically designed to run through waves of any height, so I can't really avoid it ( and wouldn't want to either)
This comes back to Tigers point about "am I trying to design out the 100 year wave. The answer is "maybe". I'm certainly being very cautious, becuase this is going to be horribly expensive to build, so I want it to survive intact, and would rather pay to over-engineer than not pay and under-engineer.
But, there is a "but". It's important, when thinking about this kind of hull, when we talk about waves, not to think about the "Height" of the wave, but the "length" of it. This boat goes straight through waves, and, at scale sizes, this means it will be submerged fully by any wave more than about 6" high, and that is height from peak to trough, rather than peak to average height, so really if you think about a 3" wave causing pretty much full submersion, your on the right track.
The bigger issue is how long, or deep the wave is. if it's a wave from a pebble being thrown in, you might have relatively high waves but each wave is very thin. However, I will be regularly sailing this boat on a tidal river when the waves aren't very high, but are usually at least a meter in length ( peak to peak distance).
If I pierce a thin wave, I am carrying the weight of, and generating lift against, a small total volume of water. When I pierce a LONG wave, I'm displacing the entire volume of the boat in water, and generating a lift between 3x and 5x that in the outriggers. In all this could easily amount to 1/3 tonne ( metric ) of water, so you can see why I'm being careful.
Therefore, this is the debate I'm having with myself at the moment:
On the one hand I *want* a detachable top section, as it makes transport and fitting of the electrics that much easier. However, there is no point in having it if it will be forced off when it goes through a wave.
If I can come up with a way of having it VERY strongly attached to the hull, but still be detachable, I will jump at that option, but, what ever that answer is, it can't compromise the scale appearance of the model, so no bolts etc are allowed.
I LIKE the sound of Hasting's idea of the sub-assembly in the main hull which can be bolted onto. I guess it comes down to finding a way to hide the bolts from the outside. Current idea is to have the bolts built into the bottom of the detachable section permantly, and then drop them through the sub assembly, and bolt them up using wing nuts. Might be a bit fiddly, and would still mean having a removable "back door" section, but I can live with that.
Rudders: I have "come accross" the proper designs for the rudders. Tiger was partly right, they are tilted, but they are not really a balanced rudder design. They are effectively 2 rectangles, with an aerofoil shape, and the tiller tube is sent into the rudders at a 10 degrees off centre. They look similar to tigers design on page 4, but not quite. There is a very slight balancing action, but it is only a few pounds on the full sized boat.
Power train: The boat has two props!!!!! This makes me happy, as I can apply a lot more power to it now and will be able to get it to a good speed. diagrams to follow when I've converted them into something I can post.
Props: We guessed a two blade cleaver prop. Actual boat initially used 2x 3-blade sumberged cleavers, 1x left handed, and 1x right handed. The prop blades kept tearing off the bosses reasons un-known. They went through a series of makes and models with the same effect, often with a couple of miles of sailing. Supposition is that something to do with the boats hydrodymanics or design of stern places a massive amount of  back pressure on the prop blades. They changed to a less agressively pitched 4 bladed semi-cleaver, and, while there have been a big drop in performance, they can actually keep the blades on the bosses now.
Having had a look tonight, I can't find a source of 4 bladed cleaver props, so will use a 4 bladed "warship" prop for displace, and will probably use a 1 ( one) bladed cleaver for running about. If there IS a hydrodynamic issue, it will scale, as water is self similar at scale. A 1 bladed prop should avoid any issues as there is less area for a pressure wave to build against. Scale size will be 35mm.
Mixing props: Long way from this yet, but will probably use my JJC prop/rudder mixer for different levels of deflection for each side ( will just wire it backwards - instead of having motors change speed and rudder deflection as standard, I'llkeep the engine speed standard and vary the rudder deflections.
However, this IS another point of failure, of which I seem to have a lot of already. I'm very tempted to take Circlip's lower tech, more fiddly but ultimately more reliable approach on this.
For the "deflect less at speed" - I can do this with my 9 chan Multiplex aero radio, but never seen a similar feature on a marine Tx ( or the Spektrum 2.4Ghz set that will control this boat. . MTroniks do stand alone hardware mixers, so might use one of those.
Attached you should see a picture that has been a swine to get hold of, bu is finally in my grubby mitts - a rear view of the EarthRace out of the water. Note that this is an old picture showing three bladed props. The rudders are also an older design ( or at least are not the same as the diagrams that I was sent )
once again guys, thank you SO much for all you help.
I've said it before, and I've said it again, without you chaps, this thing just wouldn't be being build.
Hope you've had a great christmas.
Steve
« Reply #83 on: December 26, 2007, 02:41:30 am »
Hi Ripslider, I have more questions than anything this time.
could you tell us again the scale and overall dimension sof your model please? It will help me see things better.
... to explain my 200lb figure first.
Is this 25Knots actual or 25knots scale speed? If 25 Knots actual, what is the scale speed?
I cannot remember if you said what scale the model will be.
Have you considered which forces will cancel each other out? I think  some of these forces are mutually exclusive, i.e. can you have an upthrust and downward force, on the same outrigger at the same time? If not then the two should not be added for that outrigger. And unless you can see that there will be forces in opposite directions for each outrigger, that is anothre possible reduction in force.
Can you do a sketch of this, please?  I am having trouble seeing this.
In displacing the 1/3 of a tonne not all will be lift as forces will go in every direction outwards. Upthrust, down thrust etc. There will be sideways moments for each force as well and these will act on the faces of the 'wedge'.
Bolts can be hidden. I was thinking of using a standard nut, deep recess holes (use a box spanner to tighten). Then a small cover for the hole.
The bolts would be just long enogh. The bolts would be in a sub-assy like Hastings suggested.
Rudders: ... they are tilted, but they are not really a balanced rudder design. They are effectively 2 rectangles, with an aerofoil shape, and the tiller tube is sent into the rudders at a 10 degrees off centre.
Althoguh not exactly to scale, of you do solder directly on to the servo, for the sake of the servos you may still need to consider a balanced rudder.
Great picture
Sean
« Reply #84 on: July 12, 2008, 12:13:12 am »
Hello,
Anything new on this build??
Thanks,
Sean
Arrow5
« Reply #85 on: July 12, 2008, 08:05:03 pm »
..and on the full-size`s activity ?
hopeitfloats
« Reply #86 on: July 14, 2008, 11:33:19 am »
i know it completed its round the world trip and broke the record by i think 30 days or something like that. dont quote me there. the design on the front maybe be a moko.  but is nz maori anyway.  the boat was  diesel/biofuel powered  and had a lot of mechanical woes on its first attempt around the world but reasonably trouble free on the second attempt
« Reply #87 on: July 14, 2008, 07:12:49 pm »
Just had a re-read of this thread, and one or two bits didn't quite add up, or I mis-read them.
It is to be a 1:24 scale operational model of a prototype intemded to do 25 kt.  There is much mention of piercing waves at 20 mph, and the stresses set up by this.  My figuring of scale speed is that top speed should be about 5 kt, reducing the forces enormously, and at the same time increasing the feasibility.
andyn
« Reply #88 on: July 14, 2008, 07:36:40 pm »
Personally I would get on to one of the model aircraft manufacturers, such as West London Models, who make the all-carbon Toplight gliders, and see if they could mould you one in carbon fibre.
The hatch could be held on by some inset nylon screws with rubber plugs over them.
Pages: 1 2 3 [4]   Go Up
