Author Topic: Operating Engine Room roof vent made from Brass sheet  (Read 8654 times)
HS93 (RIP)
  • I cannot spell , tough
« on: December 03, 2007, 02:09:46 am »
When I decided to re vamp the superstructure on the HS Tug I decided to make a new sky light as the one I had made several years ago had been modified several times during the build.
Having decided what mods where required from the original a Piece of 0.015 brass was used for the build I had decided that I would build it slightly different from the original in that the main structure would be bolted together, this would make it easier to clean up and enable any mods.A brass sheet was marked out and on this one I had the advantage of a min mill to cut the holes out saves hours of filling.  Pictures  Roof 1-2-3-4
HS93 (RIP)
Re: Operating Engine Room roof vent made from Brass sheet
« Reply #1 on: December 03, 2007, 02:11:22 am »
Picture Roof 5 shows it bent to shape. picture 6 shows the end panels marked out picture 7 shows it checking fit, picture 8 shows it with a piece of plastics card to space it in from the edge so it can be drilled
HS93 (RIP)
« Reply #2 on: December 03, 2007, 02:12:31 am »
Picture 9 shows it drilled and 12 ba c/s bolts used to hold it together picture 10 shows the angle bolted on picture 11 has different bolts to see what looked best I decided to go with the c/s   picture12 shows the angle finished.
HS93 (RIP)
« Reply #3 on: December 03, 2007, 02:14:08 am »
On the original I made the hatches then tried to cut the holes out for the portholes (they did not look very nice) so on this one I cut the holes and this enabled me to make a small jig to bend the edges and keep the hole central Pictures 13 -14. Picture 15 shows the first bends I put it in the vice and taped it over I then notched the corners out and bent the othere ends Picture 16 shows it ready to silver solder the corners Picture 17 shows them ready to clean up and  trim to thickness.
HS93 (RIP)
« Reply #4 on: December 03, 2007, 02:15:58 am »
Hinges on the original the hinges where made from strips with the ends bent round a rod , on this one I decided to mill hinges out of solid picture 18 -19 -20 -21 Picture 22 shows the hinges fixed on to the lids I used rivets to hold them in place then soft soldered them from below. I only soldered  three of the rivets as the forth would be used to hold the angle that the operating rod would attach to later . I used handrail stations for the other part of the hinge and some .75 brass rod picture 23 shows it after a quick brush with a brass wire brush
HS93 (RIP)
« Reply #5 on: December 03, 2007, 02:18:24 am »
Operating mechanism two pieces of brass 6mm x 3mm was used at either end to form the
Supports for the mechanism  the problem is that they booth had to turn in overset directions picture 25 -26 shows the mechanism in position , it still has temper operating rods that I used to get the correct length. Pictures 27 -28 -29 shows it ready to fit
HS93 (RIP)
« Reply #7 on: December 03, 2007, 04:37:14 am »
Well done. That's a wee beauty.
Bob Ferguson,
New Zealand.
Captain Povey
« Reply #8 on: December 03, 2007, 12:06:40 pm »
Wow, What a work of art. I wish I had half your talent and skill. Graham.
Bunkerbarge
« Reply #9 on: December 03, 2007, 12:31:06 pm »
That is absolutely beautifully designed and made.  Modelling at this level is not seen very often and it is just as enjoyable to watch your manufacturing process as it is to see the completed item.
Watching it in real life operation would be amazing!
« Reply #10 on: December 03, 2007, 04:29:07 pm »
I'll get my coat...
Green with envy
Wonderful job O0
« Reply #11 on: December 03, 2007, 10:48:22 pm »
What an excellent thread keep up the good work I am really jealous of your tallent
« Reply #12 on: December 04, 2007, 08:37:05 am »
Superb job, just seems a shame to paint it!!
« Reply #13 on: December 04, 2007, 01:48:26 pm »
I thought we had lost all the masters, but far from it, perfection at its best.  KEEP UP THE GOOD WORK Peter.   It sets a high standard for us all to work too.  O0
aye
john e
bluebird
HS93 (RIP)
« Reply #14 on: December 04, 2007, 10:14:17 pm »
      Thank's Chaps , now its time for the bit I cannot do as I have no patience  paint !   :'(
bigfella
« Reply #15 on: December 04, 2007, 11:19:32 pm »
WOW, thats all I can say. I have trouble folding a bit of cardboard. Truly a craftsman at work. O0 O0 O0
Regards David
bigford
« Reply #16 on: December 18, 2007, 03:48:06 am »
i just got the movie to play  O0 O0 O0 WOW!!!!
 what is the thing blinking 2&5 ??
Umi_Ryuzuki
« Reply #17 on: December 18, 2007, 04:42:40 am »
Well dang,...
Great work....
Now I have to build a steam ship.... or something....
That is just some of the slickest brass work I have seen...
 8)
HS93 (RIP)
« Reply #18 on: December 18, 2007, 08:33:49 am »
 Bigford  Iits actually 5+2   5.2volts, its a small voltage read out that I use , its handy to see if the servo is working to hard.
 Umi_Ryuzuki  I recently looked at your web site and was so impressed with the modeling (especially the church) really nice bit of work
 Peter
Umi_Ryuzuki
« Reply #19 on: December 18, 2007, 07:49:54 pm »
Sort of have to ask, ... "Which Church?...  :D
Not much brass work in those models, and most of my brass work has been stick assembly for
masts, stuffing tubes, and the odd rudder or railing...
To see a simple superstructure and then the hatch built and then made operable is inspiring to say the least.
bigford
« Reply #20 on: December 19, 2007, 12:36:25 am »
hey peter
   how about a how to on making a superstructure  in brass, as you some of us have no clue ;)
HS93 (RIP)
« Reply #21 on: December 19, 2007, 01:28:46 am »
Sorry I cannot help there , But I have just covered a superstructure in ultra thin fiberglass that makes it ultra smooth and takes paint very well, I am trying and have been for some time been trying to get some plans /drawrings of a US Jeep around the ww2/ Korean war so I can build one in brass at 12th scale I just don't seem to be able to get any.
bigford
« Reply #22 on: December 19, 2007, 02:58:44 am »
might be what you need e-bay #190181229042  O0
i was thinking more along these lines
way beyond my skill
Voyager
« Reply #23 on: December 19, 2007, 03:25:56 pm »
simply stunning..... O0
Well done HS93 your a master of brass alright!!!
Page created in 0.206 seconds with 21 queries.
