Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Quick Hints & Tips!  (Read 229708 times)
Brian60
Re: Quick Hints & Tips!
« Reply #75 on: July 29, 2015, 09:16:58 am »
Also with the airbrush. Only flush through with a reputable cleaner between paints, do not use a heavy solvent. The airbrush body contains a minute O ring that can be damaged by some solvents. After use strip and clean each part with solvent if needed (if you have sprayed enamels/cellulose etc) But the body should just be flushed with a decent airbrush cleaner.
« Reply #76 on: July 29, 2015, 09:48:31 am »
Just a repeat of a tip from Bryan Young. When choosing adhesives, think laterally sometimes and consider using double sided tape, it can often give a very neat and permanent job where conventional adhesives are difficult or messy to use.
sparkey
« Reply #77 on: July 29, 2015, 01:35:06 pm »
 :-)) Draft excluding tape can be used to seal hatches,and be very handy for protecting hull in stand,cost about £2.50 a roll and lasts for ages,Ray. :-)) :-)) :-)) :-)) :-))
Terry
« Reply #78 on: July 30, 2015, 03:36:43 pm »
If you have an old video recorder kicking around waiting to go to the tip, strip out the recording head, ( Ali. drum about 50mm dia.) You will find some high precision bearings inside.
Cheers, Terry.
Nemo
« Reply #79 on: July 30, 2015, 08:45:05 pm »
Just a repeat of a tip from Bryan Young. When choosing adhesives, think laterally sometimes and consider using double sided tape, it can often give a very neat and permanent job where conventional adhesives are difficult or messy to use.Colin
Absolutely Colin, I do this a lot. The best and strongest/permanent I have yet found is the 'NO-NAILS' doublesided tape - it takes some shifting! I stuck down the rubbing-strakes on my yacht 3 years ago and it hasn't moved -yet! Be careful though - it has instant 'grab'.
Bob.
Brian60
« Reply #80 on: August 01, 2015, 08:52:15 pm »
I can't take credit for this one, it was passed to me on a Facebook group page. Don't buy one of the expensive bilge pumps advertised, look out at the local car boot sales or cheapy shops like Poundland for those table top water features. They can be picked up for a couple of pounds, just extract the water pump from them and throw away/recycle the rest of it.
tattooed
« Reply #81 on: August 02, 2015, 04:31:46 pm »
if any of you guys need brass/copper/aluminium/phosphorus bronze don't pay the prices on flea bay go down you local scrap yard and ask what they have in stock i pay £4-00 a kilo for brass bar and the good thing is when the price of scrap goes down so does the cost to you  :-))
if it looks right and your happy with it then it is right
Brian60
« Reply #82 on: August 19, 2015, 09:16:44 pm »
Buy a box of cheap disposable plastic gloves ( or grab handfuls off the garage forecourt next to the pumps %) ) Wear them when holding small parts and spraying paint, then throw away. It saves getting paint all over your hand. Also useful when doing grp work or using body filler.
Don't use rubber surgical gloves they are too expensive for this.
Brian60
« Reply #83 on: August 20, 2015, 08:49:58 pm »
This tip from the plastic model world. If you want to apply a tiny amount of superglue/instant glue, take a sewing needle and grind off the tip from the eye end. This will leave a little fork shape that holds just enough glue to apply carefully.
I put mine in a microdrill handle to get more control, it also prevents you spearing yourself on the pointy end. If they eye becomes overloaded with dry glue just hold in a naked flame for a few seconds to burn it away.
CAUTION IF USING A NAKED FLAME, REMEMBER THE BASE OF SUPERGLUE'S IS A CYANIDE PRODUCT AND IT IS BEST NOT TO BREATHE IN THE FUMES FROM THE BURNING GLUE!!!
« Reply #84 on: August 20, 2015, 10:13:39 pm »
Some very cheap 12v LEDs available from Amazon (posted from China). They also work well on 6v. No need to bother with resistors for many model boat lighting applications.
http://www.amazon.co.uk/White-Lamp-Light-20cm-Wired/dp/B00H98OS2W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1440104922&sr=1-1&keywords=20+x+White+LED+Lamp+Light+Set+20cm+Pre+Wired+5mm+12V+DC
These are the larger 5mm variety and I am using them for general internal lighting rather than navigation lamps.
Seaspray
« Reply #85 on: September 02, 2015, 07:49:06 pm »
« Reply #86 on: September 03, 2015, 12:03:02 am »
Topics merged.   :-)
Murph
  • Sláinté
« Reply #87 on: October 15, 2015, 06:56:15 pm »
Don't know if it's already been posted but never peel and chop scotch bonnet chilli's then go to the little boys room without washin yer hands , Lord Mary and Joseph it stings  %% %% %%
Beagán a rá agus é a rá go maith
« Reply #88 on: October 15, 2015, 11:03:37 pm »
Ouch!    {-)
Nemo
« Reply #89 on: October 23, 2015, 11:48:09 am »
When you have a broken/redundant Tx or radio with a telescopic aerial, snip off the top section. Many come in handy for flag-staffs.  :-))
Brian60
« Reply #90 on: October 23, 2015, 12:22:56 pm »
I stopped posting to this topic as I suggested it as hints and tips that would be related to model building. Quite clearly a lot of what was posted under Seasprays topic that was merged with mine were not model related and could come under the general heading of 'humour' which is why I have not posted since that date. So as the topic has become confused and obfuscated - especially to those that want model building tips, I'll confine my hints and tips to my own build threads.
RAAArtyGunner
« Reply #91 on: October 23, 2015, 12:42:43 pm »
Seems a demerger (uncoupling etc) would be in order  O0 O0
« Reply #92 on: October 23, 2015, 12:51:54 pm »
Yes, needs some tidying up, the original intention of useful hints and tips is an excellent one. Plenty of room for witty stuff elsewhere.
david48
« Reply #93 on: October 23, 2015, 07:57:52 pm »
I suppose this has been done before, but I've just tried it , I mix a bit of paint in my epoxy glue  so when I am fixing my deck fittings I do not get a glue mark. Anyway it works for me . The paint I use is Humbrol enamel.
David
Nemo
« Reply #94 on: October 23, 2015, 08:04:39 pm »
I suppose this has been done before, but I've just tried it , I mix a bit of paint in my epoxy glue  so when I am fixing my deck fittings I do not get a glue mark. Anyway it works for me . The paint I use is Humbrol enamel.David
Now why didn't I, another genius, and one who has prepared many a sheeps heid, never think of that David. Thanks  :-))
david48
« Reply #95 on: October 24, 2015, 12:45:16 am »
I have been using old computer castings as a good source of ABS  to make gear boxes and PCB enclosures , I use plastic weld from EMA also bought a dropper ,i Pin Flow
Availability: In stock.
£8.33Code: DM54.     This is good because it lets you put 1 drop leaves a clean joint
David
« Reply #96 on: December 13, 2015, 05:16:33 pm »
Used Lipos make good handwarmers
down at the lake this time of year {-)
Just let them cook a little before removing %)
Andyn
« Reply #97 on: December 14, 2015, 10:28:41 pm »
From the bench of someone who uses a Dremel and superglue 9 hours every day:
Don't drill your fingers
Don't glue your fingers
Don't glue your fingers to the drill
Don't glue your drill to your fingers
Cutting wheels hurt
Don't wrap the drill into your shirt
Don't be tempted to superglue scalpel / dremel wounds together
DO NOT POUR KICKER ONTO SUPERGLUE REPAIRED WOUNDS
Don't blow superglue into eyes
Don't blow superglue and kicker mix into eyes
Stop drilling your fingers..
The list goes on..
« Reply #98 on: December 14, 2015, 10:35:50 pm »
But not for much longer obviously.....
boatmadman
« Reply #99 on: December 16, 2015, 08:35:32 am »
Dont throw away that old printer, strip it down and you will find accurately ground lengths of steel bar, bushes, gear wheels, maybe a gearbox. maybe a motor or two, drive belts......
Pages: 1 2 3 [4] 5 6 7   Go Up
Page created in 0.03 seconds with 22 queries.
