Author Topic: My nervous breakdown due to electronoics HELP  (Read 2829 times)
« on: July 03, 2006, 11:25:26 pm »
Right simple one this I have got a Futaba 6 channel set that supports 3 different models.Now can I use say a 2 channel reciever on one and a 4 channel on another and obviously the full 6 on teh 3rd.Reason I ask is I cant seem to get the 4 channel nor the 2 channel to work with the set or is ita case that I havve to dig deep and but 3x 6 channel recievers put me out of my misery cheers Stavros
Doc
Re: My nervous breakdown due to electronoics HELP
« Reply #1 on: July 04, 2006, 05:05:27 am »
Stavros,
Hmm, really shouldn't be a problem assuming all receivers are the same (AM/FM/PCM/whatever).  The 'other' thing to check is to see which of the six transmitter channels is received by which receiver channel.  Channel 1 on the receiver may not be channel 1 on the transmitter, so see if any of the other channels make the receiver's channel 1 respond.  (Don't ask me why, I have no idea, but I've had it happen before.)
 - 'Doc
PS - Banging the @#$ thing with a hammer sometimes helps...  ... on second thought, don't do that.
A Model World
  • Model Boat Mayhem does what it says on the tin
    • A Model World
« Reply #2 on: July 04, 2006, 06:34:30 am »
Nervous breakdown no you?ll be fine? ?first of all the two channel you cannot get an FM receiver on 2 channel (your 6EXA is FM) so you will have to go to at least 4 which is the minimum FM Futaba do there are 3channel FM receivers but they are not reliable with Futaba and as such it might be better and cheaper to install an entire 2 channel set on AM or there are some good Futaba compatible receivers on the market. The 4 channel operation you need well that is simply either a Futaba 4 or one of the compatible ones and then with either swapping crystals from receiver to receiver or having extra you will be away it should be as simple as that so not to sure whty you cannot get the 4 working at least may be more than an email post required to work out ? ?
Mark
Daily flogging?of the ships crew will continue until morale improves
« Reply #3 on: July 04, 2006, 11:14:00 pm »
Thanks for thta A Model World would it make a difference if I was using a Acoms 4 channel reciever wiht the futaba set up also the 2 channel is Acoms cheers
A Model World
    • A Model World
« Reply #4 on: July 05, 2006, 06:49:45 am »
Yes that woiuld explain your problem ACOMS/ Futaba. The 2 channel is not going to work full stop. The acoms RX (even if the 4 is FM) is not very comapatible with Futaba
« Reply #5 on: July 05, 2006, 10:45:41 pm »
Thanks a lot for that it explains my nervous breakdown it seems that I will have to bite the bullet and buy some proper gear!!!.You have sorted that little problem out now I wonder where I can get 6 channel recievers from ;)
Page created in 0.231 seconds with 21 queries.
