Author Topic: Hydromite plan.  (Read 7645 times)
explorer750
Hydromite plan.
« on: February 03, 2008, 02:48:37 pm »
Found this on the net the other day.
http://www.rumrunnerracing.com/plans/hydromite.htm
It looks like it could be a fun build in any size, possible with a small nitro engine in a large one.
Has any one built one?  ;D
w3bby
Re: Hydromite plan.
« Reply #1 on: February 04, 2008, 12:06:56 am »
explorer750
Re: Hydromite plan.
« Reply #2 on: February 04, 2008, 05:40:14 pm »
Heres a video I found.
http://video.google.co.uk/videoplay?docid=-2796233146728792079&q=hydromite&total=6&start=0&num=10&so=0&type=search&plindex=0
Not much info on it but at a guess a brushless motor in a std size hull.
explorer750
Re: Hydromite plan.
« Reply #3 on: February 06, 2008, 06:45:45 pm »
This is probably  a silly question but does this type of boat have to be driven semi-submered or can it be driven submered? If so would it be possible to create a F1 tunnel type model from this hull running a outboard like the kyosho wavemaster.
boatmadman
Re: Hydromite plan.
« Reply #4 on: February 06, 2008, 08:06:25 pm »
Here is my hydromite.
Only been on the water once, I made the mistake of being too easy on the throttle - result - made like a submarine and went 6 inches under before i let go the stick. Now awaiting a new speed controller.
Ian
explorer750
Re: Hydromite plan.
« Reply #5 on: February 07, 2008, 05:34:26 pm »
Does this style of boat would like a tunnel hull by forcing air under it self. If so a outboard could be used to power one.
boatmadman
Re: Hydromite plan.
« Reply #6 on: February 07, 2008, 06:23:43 pm »
The theory is that it sits on the water on the trailing edge of the sponsons and the surface peircing prop, so, maybe an outboard with a suitable prop would be worth a try.
Ian
explorer750
Re: Hydromite plan.
« Reply #7 on: February 07, 2008, 06:49:38 pm »
I plan to use a Graupner GTX 500 outboard.
boatmadman
Re: Hydromite plan.
« Reply #8 on: February 07, 2008, 09:43:25 pm »
have to say, I have no idea how it will perform with an outboard, but give it a go and share some pics with us.
You will have to be careful to adjust the c of g, as the conventional set up with an internal motor puts some weight at just the right place. The outboard will shift weight to the stern which will need compensating for by positioning the batteries differently.
Ian
explorer750
Re: Hydromite plan.
« Reply #9 on: February 08, 2008, 05:08:05 pm »
Don't plan to build any more boats at the moment to busy trying to sort out my shg Shadow. If you would like to see progress see http://www.modelboatmayhem.co.uk/forum/index.php?topic=7763.0
explorer750
Re: Hydromite plan.
« Reply #10 on: February 10, 2008, 07:00:48 pm »
I can now see while they are called hydroplanes now. ;)
explorer750
Re: Hydromite plan.
« Reply #11 on: February 14, 2008, 06:08:42 pm »
 Just some more plans that I found all Hydro's and some shovel noses.
http://www.astecmodels.co.uk/plans.htm
I like them because they are in different scales so no more messing with a photocopier.
explorer750
Re: Hydromite plan.
« Reply #12 on: March 01, 2008, 12:01:31 pm »
Found this on the net. Looks like a RTR hydromite with a brushless motor.
http://www.offshoreelectrics.com/proddetail.php?prod=mcr-hydro
At the price: $299.00 it is still cheaper to build one.
boatmadman
Re: Hydromite plan.
« Reply #13 on: March 01, 2008, 01:32:27 pm »
Fast little b****r.
I have to wonder if the producers have bought the rights to build and sell. I have read somewhere that the free plans were being withdrawn due to being used commercially. hmmm
Ian
explorer750
Re: Hydromite plan.
« Reply #14 on: March 01, 2008, 04:14:46 pm »
Copy right of plan
STATEMENT OF COPYRIGHT
This plan is copyright protected by Forresterace Designs, 2001
TERMS OF USE
This plan is published for the free non-commercial use by individual modelers.
All commercial rights are reserved. All unauthorized commercial reproduction or useage of this plan or design is prohibited by law. Forresterace Designs, 2001.
However the RTR boat you can buy all the hardware separately, this could be used
At $49.00 its still not cheap but saying that if you buy it here in the UK separately it about the same price
