Pages: 1 2 3 [4] 5 6 7 8 9 10 11   Go Down
Author Topic: Q & A - Swordsman A PLAN FOR BEGINNERS by Bluebird  (Read 172435 times)
Re: Q & A - Swordsman A PLAN FOR BEGINNERS by Bluebird
« Reply #75 on: December 11, 2010, 07:12:19 am »
Try PM'ing ACTion
gwa84
Re: swordsman plan
« Reply #76 on: December 11, 2010, 11:21:43 pm »
it seems thease plans are no longer available is ther enybody out ther that would part with a coppy ? for a price of course  :-))
rolfman2000
« Reply #77 on: December 15, 2010, 09:15:39 am »
I would like to get a set of these drawings, as I do like the Swordsman design.  May even try to do the one from the Bond movie.
Cheers,
rolfman2000
Re: swordsman plan
« Reply #78 on: December 15, 2010, 09:16:18 am »
it seems thease plans are no longer available is ther enybody out ther that would part with a copy ? for a price of course  :-))
And another one pleeeeease ???
Even a scan file which I could get printed myself
Cheers,
HS93 (RIP)
  • I cannot spell , tough
« Reply #79 on: December 15, 2010, 09:20:51 am »
Cheers,
that was not a Swordsman but a Huntress
what size are you building ?
Peter
rolfman2000
« Reply #80 on: December 15, 2010, 09:26:48 am »
Peter
Ah well, me age shows again...Doh !!!
Just the Smaller one... I would like something around the 24 to 36 inch size please... The wife gets Irate if my modles take up more room than her in the car.  %)
Cheers,
HS93 (RIP)
« Reply #81 on: December 15, 2010, 09:50:47 am »
This is the best Plan I have seen , if you want a smaller boat do what I did and go to my local plans shop and get them reduced by the amount you want, I think it is the most accurate plan available, if you want a huntress you just trim the overall huntsman by chopping the rear, read the full size boats info http://www.faireyownersclub.co.uk/default.asp?content=boats&type=huntress
the best plan I think
http://www.myhobbystore.co.uk/product/16697/fairey-huntsman-mm680
Have a look at the build of the Huntsman
http://www.modelboatmayhem.co.uk/forum/index.php?topic=14357.0
peter
John W E
  • I see no ships !!
« Reply #82 on: December 15, 2010, 09:57:05 am »
Hi if you email this gent at ACTion and ask nicely you may get the plans for free as a download
[email protected]
 AYE
BLOOBS
Knowledge begins with respect
HS93 (RIP)
« Reply #83 on: December 15, 2010, 10:32:18 am »
[email protected]
 AYE
BLOOBS
Why don't you use your normal Nom-de-plume
Peter HS93
ACTion
« Reply #84 on: December 15, 2010, 01:40:46 pm »
These plans are not available from ACTion.
DM
gwa84
« Reply #85 on: December 23, 2010, 04:31:36 pm »
thanks for all the help getting plans extra the parts have arrived along with the wood from slek so building has commenced today  :-))
« Reply #86 on: December 23, 2010, 04:43:08 pm »
Where did you get the plans from in the end?
rolfman2000
« Reply #87 on: December 23, 2010, 05:38:51 pm »
Plus 1
Cheers,
Dave  :-))
gwa84
« Reply #88 on: December 24, 2010, 12:12:14 pm »
hi all martin got a set of original plans from the mag from The long Build along with another mag with a plan i will be doing in the future it would be nice if there was a readily available supply for these so pleasant to build i have the hull almost done already wondering weather FLJ would give permission fr people to copy and send them out as i assume theirs a copyright issue
gwa84
« Reply #89 on: December 28, 2010, 11:44:41 pm »
making good progress with this build cant believe haw fast it goas together  :}
time for paint soon :-))
LarryW
« Reply #90 on: December 29, 2010, 05:10:33 pm »
looks good so far ,trick bit i found was the cockpit screen , and trim, but the pool runs are great .
   so good i have just scaled up plans to 32 ins length , for next build with twin motors , modeled on off shore racer.
John W E
  • I see no ships !!
« Reply #91 on: December 29, 2010, 07:19:07 pm »
hi ya there, what we will have to do is come up with another plan for a different model - this one seems to be pretty popular, but the plan now seems difficult to sources apart from paying over the top on ebay
looking good - mate.
Ive been looking at the plan for an easy build pilot boat from My Hobbies Store Plans - or it may have been Marine Modelling plans.......another plan for beginners maybe....
aye
john e
bluebird
gwa84
« Reply #92 on: December 29, 2010, 07:32:26 pm »
would definitely be interested in something similar to the lasro sprite been wanting the model for ages but cant justify 60 quid for the kit just like the look of it
also a quick question haw did you attach the cockpit wind screen to the wood
John W E
  • I see no ships !!
« Reply #93 on: December 29, 2010, 07:40:29 pm »
I stuck it with flour and water....nay nay and thrice nay
Really. First of all I attempted to glue the acrylic sheet with superglue, but did it bond, IT DID NOT.   Anyhow, I ended up using UHU, glue contact adhesive which is still, to this day, sticking very well
aye
john e
John W E
  • I see no ships !!
« Reply #94 on: December 29, 2010, 08:22:20 pm »
http://www.cornwallmodelboats.co.uk/acatalog/mar3062.html
Hi this is the plan maybe....for the pilot boat  %)
aye
john
triumphjon
« Reply #95 on: December 29, 2010, 09:03:16 pm »
re windscreen , although my fairey huntsmen are larger at 1/12th scale , ive warmed up my screen halves oveer a heated peice of pre shaped steel , then shaped the plastic over the steel , removing it and holding it to the required shape , having a longer lower sides than normal allows me to screw them into the inner faces of the cockpit ! to join the two halves of screen ive used a 2" long section of brass channel 1/4" x 1/8" which has been cut , angled in the centre and resoldered , then the screen joints are glued to both the top and bottom of the screen .
John W E
  • I see no ships !!
« Reply #96 on: December 29, 2010, 09:11:58 pm »
gwa84 hi there
Just having a look at the actual plans for the build regarding the windscreen - and it has just jogged my memory - the windscreen has tabs on the edge of it which actually locate and slots which one has to cut in the cabin roof/cabin sides to which these tabs locate and then glue.  I seem to recall making these tabs slightly 'longer' and also making the windscreen in 2 halves - split down the centre line & I used the mast in the centre of the windscreen as a joining point.  Doing it this way I found made it a lot easier for assembly.
Hope this is of some help.
aye
john e
bluebird
gwa84
« Reply #97 on: December 29, 2010, 11:32:06 pm »
thanks bud will try it that way hope it works  :-))
triumphjon
« Reply #98 on: December 29, 2010, 11:49:18 pm »
mine hasnt got anything down through the cabin roof , a small fillet of car body filler has been used to blend the screen into the roof line ! the central join is also masked by my walnut mast that is glued onto the screen joiners top & bottom with epoxy glue , the wire for the mast light goes through the small gap in the screen and down into the forward cabin .
John W E
  • I see no ships !!
« Reply #99 on: December 30, 2010, 06:28:21 pm »
It's nice to have a back-up longbuild - thank you for that.
We did have a backup plan in motion which we can stop now thanks to the new supply  :-))
Plans are still going ahead for a new beginners build of a different boat - as has been requested.
aye
john
Pages: 1 2 3 [4] 5 6 7 8 9 10 11   Go Up
Page created in 0.017 seconds with 22 queries.
