The Shipyard ( Dry Dock ): Builds & Questions => Submarines => Topic started by: homerlex on August 20, 2006, 05:35:29 pm
Title: Anyone know where to find Holts P40 resin/glass in US or online
Post by: homerlex on August 20, 2006, 05:35:29 pm
Chris Cloke mentioned using  Holts P40 resin/glass for an "adhesive" instead of epoxy.  I can't seem to find it anywhere (in stores or online). Anyone have any ideas?
Title: Re: Anyone know where to find Holts P40 resin/glass in US or online
Post by: HS93 (RIP) on August 20, 2006, 05:44:10 pm
Try this link if you google http://www.google.co.uk/search?hl=en&q=holts+p38&btnG=Google+Search&meta=    there are plenty  ie
http://www.shop.edirectory.co.uk/autosave/static/225/miscellaneous+15807.html
Peter
Post by: ambernblu on August 20, 2006, 06:15:25 pm
... if you go on ebay and search 'P40 Glass Fiibre' there'll be some on 'BUY IT NOW' I'm sure!
Found some :
http://cgi.ebay.co.uk/P40-Glass-Fibre-Compound_W0QQitemZ130018612823QQihZ003QQcategoryZ72203QQrdZ1QQcmdZViewItem
Post by: homerlex on August 20, 2006, 07:54:43 pm
Seems to be readily available in the UK.  Can anyone point me to an equivalent available in USA?
Thanks!
Post by: sheerline on August 22, 2006, 02:55:48 pm
The Holts P40 resin/glass mix I told eveyone about is apparently made by Isopon!! I was sure it was made by Holts and perhaps it was once upon a time and had its brand name changed but it is available over the counter here in the UK and costs £5-99 for a 600mL tin.
Sorry if I misled anyone.. Guess the grey matter aint wot it used to be!
Post by: sheerline on August 22, 2006, 03:36:22 pm
 :o Told you the brain was going, that should have read 250mL at £5-99  :P :P
Post by: HS93 (RIP) on August 22, 2006, 06:03:23 pm
  I think its called Bondo over there
http://www.bondo-online.com/catalog_item.asp?itemNbr=210
Peter
