Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: hover tim on September 23, 2008, 07:28:45 pm
Title: futaba 7 channel computer transmitter
Post by: hover tim on September 23, 2008, 07:28:45 pm
hello have just got this transmitter it seems very good but i now have to figure out the dark art of mixing as i wouuld like one of my hovercraft which has two motors for thrust to be done off one stick ie when i pish the right stick forward both mortrs go forward when i puch back both go back when i puch left one motors goes left and when i push right the right motor moves please cold someone walk me through how to do this as i cant get my head round all of the flyboy sfuff in there  ???
Title: Re: futaba 7 channel computer transmitter
Post by: Peterm on September 23, 2008, 07:57:35 pm
ACTion has the answer.   See dealers.   Pete M
Post by: David_S on September 23, 2008, 08:06:14 pm
I don't have this transmitter, but most modern computer txs have good mixing built in, so you shouldn't need to buy an external mixer. Basically need to mix throttle and rudder channels. Might get a better response on a model flight group where this tx is actually used.
Post by: Colin Bishop on September 23, 2008, 08:15:29 pm
A problem that you can find is that the inbuilt mixing is geared to aircraft use and is of limited functionality if you want to apply it to a boat unless you use the sticks in other than the normally accepted manner for marine models. My Futaba 6 EXA is like that.
Post by: David_S on September 23, 2008, 08:21:22 pm
My 9 channel JR aircraft tx has several free mixers, so you can mix any channel with any other. All computer txs I have used over the last 20 years or so have had at least some free mixing.
Mind you, I haven't tried this in a boat as yet, but have a twin-screw kit on the way, and will buy a new radio for it when I've built it, so I might have to eat my words :)
Quick thought after posting  ::) Some of the aircraft txs have a 'twin engine' mix built in, which would do exactly what you want, mixes two throttle outputs with the throttle and rudder stick. You might need to change modes so that the radio knows the rudder is on the right stick if that's how use it, as most come as mode 2 (throttle and rudder on left stick) by default.
Post by: Martin (Admin) on September 23, 2008, 08:44:36 pm
What model Futaba is it?
Post by: hover tim on September 23, 2008, 09:19:49 pm
its a futaba t7c 2.4 ghz fasst although the craft does have rudders i will be using the motors to do the stearing like a tank see attchment
Post by: Martin (Admin) on September 23, 2008, 11:53:28 pm
I think with the 7C you have to use Heli mode which has 3 programmable mixers.
http://manuals.hobbico.com/fut/7c-manual.pdf (http://manuals.hobbico.com/fut/7c-manual.pdf)
