Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: Garabaldy on January 31, 2009, 04:18:34 pm
Title: Hitec 55 servo
Post by: Garabaldy on January 31, 2009, 04:18:34 pm
Are these servos compatible with my futaba 2.4gig reciever?
Title: Re: Hitec 55 servo
Post by: malcolmfrary on January 31, 2009, 05:23:09 pm
Go to
http://www.modelflight.com.au/rc_model_electronics/hitec.htm
scroll down to your servo, there is a link to the Hitech servo manual.
This gives the operating specs which show that all Hitech's servos expect a pulse between 3 and 5 volts at the rate of 50 per second.
Futaba for some reason are very shy about letting potential customers see their tech specs.  Obviously their servos work, but there were rumours in the past that Futaba RXs only put out a 2.5 volt pulse, which might make things a bit marginal, but they should be compatible.
Usually, the only difference is the shape of different manufacturers plugs, which are often keyed to fit only their own RXs, but as modellers we have the means of removing the offending bit of plastic from the plug.
Post by: tomocj on February 11, 2009, 02:33:50 pm
Hi Ive used Hitec servos with futaba rx and had no problems at all ,so you should be ok to use the hitec 55.
Chris
Post by: Garabaldy on February 11, 2009, 06:19:11 pm
cheers guys :}
G
