Mess Deck: General Section => Model Boating => Topic started by: Martin (Admin) on February 18, 2009, 07:17:15 pm
Title: Motor / Battery / Prop for any boat - add yours!
Post by: Martin (Admin) on February 18, 2009, 07:17:15 pm
A good idea suggested by someone else!  :-))
Would it be possible to have a section devoted to what motor/battery/prop combination other members have fitted to whatever boat they have built? It would possibly help prospective builders plan their internal layouts I think? Something like this:
Name….            Boat….                          Scale….          Motor….                 Battery….           Prop(s)
 U-33               Tamiya USS Missouri       1/350th         2 x Mabuchi 280    4x 2000a/h AA    2 x 20mm plastic
Title: Re: Motor / Battery / Prop for any boat - add yours!
Post by: das boot on February 18, 2009, 07:31:59 pm
U-33     U-33(U-212 class)           1/96th        Mabuchi 385       7.2v 4300 nicad pack       scale 50mm seven blade scimitar whitemetal
Post by: GG on February 18, 2009, 07:34:27 pm
Nice idea Martin, but.......
the propeller diameter without the pitch is of limited value. The number and type of blades would be handy too.  Probably wise to have a place for any speed reduction as well.
Glynn Guest
Post by: Tug-Kenny RIP on February 18, 2009, 07:52:54 pm
This list seems a good idea as we are always getting questions like this.
It might be better to run the list vertically, using a master.
item 1    ************
item 2    ************
item 3    ************
etc.                      ;)
Post by: Martin (Admin) on February 18, 2009, 07:56:53 pm
Name -  U-33
Boat - Tamiya USS Missouri
Scale - 1/350th
Motor - 2 x Mabuchi 280
Battery - 4x 2000a/h AA
Prop(s) - 2 x 20mm plastic
Post by: Tug-Kenny RIP on February 18, 2009, 08:04:41 pm
Name -       Boston Typhoon
Boat -        Trawler
Scale -       1/32
Motor -       Robbe 1000
Battery -     12 volt  7Amp/Hr  lead Acid
Prop  -        70mm
Thanks Martin
Post by: DickyD on February 18, 2009, 08:34:53 pm
We already have a topic for this Martin.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=5226.0
(http://i124.photobucket.com/albums/p8/DickyD_photos/breakpc1.gif)
Post by: das boot on February 18, 2009, 08:45:22 pm
The idea of this was just give those building a new boat a rough idea of what others had used for power and propulsion in a similar build Dicky...
Oh well, I thought it may have helped.
Post by: DickyD on February 18, 2009, 09:03:07 pm
A lot of people have already done that on my link Rich :-))
Martin has a short memory, he started the topic. {:-{
Post by: Martin (Admin) on February 19, 2009, 09:08:54 am
I had forgotten, I have a short memory.....  :embarrassed:
But lets carry it on here as this is specifically about drive set-ups.
Post by: das boot on February 20, 2009, 07:52:33 pm
Waiting for someone up some info on their Matchbox/Revell Flower class corvettes.... O0
Post by: Martin (Admin) on February 20, 2009, 08:01:38 pm
Boat - Matchbox / Revell Corvette
Scale - 1:72
Motor -  400 size (low revs)
Battery - 6v 4Ah
Prop(s) - Original Plastic prop in kit!
Post by: DickyD on February 20, 2009, 08:43:56 pm
1:72 Revell Flower Class Corvette.
Deans Marine Kyte motor
6" prop shaft with oil filler
3 bladed brass prop
Marine 5 speed controller
7.2v nicad battery pack.
Universal prop shaft coupling
Existing kit rudder bonded to smaller rudder with resin
Futaba 2 channel radio.
Runs 3-4 hours at slightly over scale speed.
Link to build:   http://www.modelboatmayhem.co.uk/forum/index.php?topic=1272.0
                     http://www.modelboatmayhem.co.uk/forum/index.php?topic=1878.0
(http://i124.photobucket.com/albums/p8/DickyD_photos/DSCF0224Medium.jpg)
Post by: DickyD on February 20, 2009, 08:47:19 pm
Robbe Scheutze Minesweeper 1:40 scale.
Two Robbe motors, two Robbe propshafts and three Robbe rudders all supplied with the kit.
Overlander 50amp speed controller Discharge: 50A forward/20A reverse. Plug in and go, no set up needed.
Two Sitek 40mm 3 bladed brass props.
Two Tornado TRC4300 9.6v Sub C Nimh battery packs.  No need for ballast.
JJC Turbocat sound system [great]
Runs slightly over scale speed.
Dont know run time as batteries have never run down. Have run for approximately 3 hours.
Link to build:   http://www.modelboatmayhem.co.uk/forum/index.php?topic=2809.0
(http://i124.photobucket.com/albums/p8/DickyD_photos/08.jpg)
Post by: DickyD on February 20, 2009, 08:50:18 pm
Robbe PT15  1:40 scale
Two rudders as supplied
230mm propshaft with oiler tube and fine pitch 35mm 2 blade prop
I used a Deans Marine Kestrel 5 Motor.
Futaba Rx
( Did not use recommended motor as the gear box is sometimes noisy went direct drive. )
Link to build     http://www.modelboatmayhem.co.uk/forum/index.php?topic=4789.0
(http://i124.photobucket.com/albums/p8/DickyD_photos/06_editedMedium.jpg)
Post by: DickyD on February 20, 2009, 09:04:15 pm
1:40 scale American PGM
Purchased hull and scratch built superstructure.
Deans Marine Kestrel motor
Futaba Rx
Futaba Servo
8" prop shaft with oiler and 40mm 2 bladed prop.
JJC Turbocat sound system.
Build   http://www.modelboatmayhem.co.uk/forum/index.php?topic=10227.0
(http://i124.photobucket.com/albums/p8/DickyD_photos/DSCF1377.jpg)
