Mess Deck: General Section => Tugs and Towing => Topic started by: chrise on May 21, 2009, 08:30:56 am
Title: Why a Model Tug Towing loads so SMALL
Post by: chrise on May 21, 2009, 08:30:56 am
Which bit of calculating a model/full size towing/handling capability doesn't work & why?
If we take a typical tanker of 200,000 tonnes it can be handled in port by 3 tugs of 60 tonne bollard pull and is about 300 metres long.
Typically model towing tugs are 1/32 which gives a scale tow of 9.375metres or around 30 feet.
Typically a model towing tug has a bollard pull of 3kg (well mine does anyway) which is about 1/22400 of the real thing and scales to a tow of about 8.9 tonnes.
Typically a reasonable ship handling tug displaces around 300 tonnes or around 1/666 of the tonnage of the tow. Even if we assume a model weight of only 20lbs this gives a tow of around 6 tonnes.
So if we take the worst from the above we should be able to handle a 9 metre 6 tonne tow & be overpowered doing it. This is a vastly longer/heavier tow than anything that I have ever seen in model tug towing.
Why? If the answer is convenience then surely we are towing with models that are too large/powerful to be scale.
Please ease my feelings of cheating.
Title: Re: Why a Model Tug Towing loads so SMALL
Post by: Capt Jack on May 21, 2009, 09:02:26 am
Would you want to try and get a 9 metre tow into your sailing pond !!!!
But i do know what you mean, i have been allowed to push the large maned models that Warsash Collage use at Marchwood Lake, hard work but good fun and more inkeeping scale wise.
Post by: Martin (Admin) on May 21, 2009, 09:05:04 am
 I can't get a "9 metre 6 tonne" tow in the back of my car?!....
Post by: dreadnought72 on May 21, 2009, 09:30:19 am
I think your maths is spot-on. The model's bollard pull is on a (scale) par with the real thing, so the objects you're "tugging" correctly should be around the size you mention. Turning to real world experience, we know we can shove a 30' narrowboat with one hand, and I suspect three model tugs would have no problem (slowly) moving one of these around in calm conditions. But it wouldn't be very quick (just like the real thing) nor very exciting (ditto) compared to using smaller tows.
Maybe the question should be "can you make a nine metre tow that'll fit in a car?"
...I think you could, at a pinch. In a big car. Water-ballasted (nesting) boxes that could be bolted together pond-side might work. Or a bow/stern structure with some form of fabric covered spaceframe in-between?
Andy
Post by: chrise on May 21, 2009, 09:46:30 am
Maybe we can't fit a nine metre tow into the car but a number of towing venues - eg Ellesmere Port - have plenty of tows that are about scale. It would be interesting to see a competiton that included them somehow.
I go back to what I said about should tow boats be smaller & less powerful than we are currrently using if we are saying the tow is fixed. Springer size & powered tugs (not necessarily Springer shapes) would be much more scale than those currently used by many.
I know about boys & the size of their toys arguments but I am hoping we can exclude that  & concentrate on a more authentic experience.
Post by: dreadnought72 on May 21, 2009, 03:02:26 pm
There's a few scale effects that creep in as you go for smaller sizes, but I agree - it could broaden the appeal of tugging. Especially if you could bring many wee tugs to an event in a boot.
Andy
Post by: ministeve on May 22, 2009, 10:15:20 pm
we at e port have sailed a 30 foot ship if you remember the aircraft carrier HMS invincible owned by a fellow mayhemer also one of the wirral lads has the san George which is 32nd scale at 15 feet in 3 sections and takes around 35 5 litre water bottles
Post by: catengineman on May 22, 2009, 10:23:39 pm
would this be that push capt jack?
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i85.photobucket.com/player.swf?file=http://vid85.photobucket.com/albums/k49/adonis_spanner/MarchwoodLake016.flv">
Post by: Umi_Ryuzuki on May 22, 2009, 11:22:57 pm
Mine, and Toesupwa's models have handled and pushed 900lb+ (408.23Kg) tows...
So that would be, what, about 180 tonnes?
I would love a go at Arrows Invincible...   8)
Post by: lighterman on May 23, 2009, 08:30:29 am
thats why i stick to lighterage tugs and build barges (lighters) to scale the last 4 i made with the tug and the tow ropes out made a nice long tow 2 ranks of 2 came in at 8' the other boat users tend to pack up and run when i show up at the pond with that lot! "oh god it's him again... filling the pond with a load.. mutter mutter" if i could find some working lightermen at 1/32 that could slack the tow ropes as i turn i would make up less room {-)
Post by: ray123 on May 23, 2009, 08:42:48 am
the same with my canadian logging tug  its 22inches long 1;24th scale   to to scale log boom's  they would be 52ft long  (to long for our home water's   regards ray
Post by: poll on May 26, 2009, 06:59:57 pm
Hi Chrise, There are clubs like E/port  Wirral  Balne Moor That do have competitions through out the year, that any one can come along and have a go.
I do take on board what you say, But how do we scale THE WIND? To have a large tug do's help a little.  The tow's are 350/400lbs in weight
John      Balne Moor M.B.C.
Post by: ministeve on May 26, 2009, 09:00:56 pm
[url]if his works the vid is at Ellesmere port at one of our tug towing events the tow has about 15 5ltr sand bottles in her and is great to tow
hope you like if you search for ministeve on youtube you will find all of the vids i have uploaded
http://www.youtube.com/watch?v=SAX710p_Qe8
Post by: catengineman on May 26, 2009, 09:21:19 pm
http://www.youtube.com/watch?gl=GB&v=SAX710p_Qe8
this link will work    :-)) :-))
R,
Post by: andyn on May 26, 2009, 09:59:46 pm
Towing load small my left .....
(http://i288.photobucket.com/albums/ll184/andyn_01/LLanberis-290608-034.gif)
Post by: ministeve on May 27, 2009, 01:12:46 am
how did you do that cat  :embarrassed:
Post by: portside II on May 27, 2009, 09:43:33 am
Steve , thats one of the questions that comes to mind when i see you and your tug in action  :-)) .
daz
Post by: tigertiger on May 27, 2009, 09:59:04 am
...we should be able to handle a 9 metre 6 tonne tow & be overpowered doing it. This is a vastly longer/heavier tow than anything that I have ever seen in model tug towing.
...Why?
If I understand the question.
Why can't my model pull 6 tonnes?
This could be because the scale effect of water molecules. The water density does not scale down, so it would be like a real ship (1:1 scale) sailing in oil or even treacle.
Is my assumption correct?
Post by: portside II on May 27, 2009, 09:25:25 pm
sounds good to me TT  :-)) .
daz
Post by: catengineman on May 27, 2009, 10:02:43 pm
...Why?
I am not sure on what you say is! MY twin VS powered Ventur tug berthed a vessel with a weight of 5.5 tonnes yes the dead weight of the vessel is five and a half tonne! and the model moved it side ways to what we can say was a scale speed (myself, capt jack, the owners and the crew)
http://s85.photobucket.com/albums/k49/adonis_spanner/?action=view&current=MarchwoodLake016.flv
Post by: Navy2000 on May 28, 2009, 12:55:36 am
Here are a couple photos of my tug Goliath which is based on the Mr. Darby tug that psuhes a barge that weighs in at 840 pounds anad she has no problem with handeling this barge. The tug has a pull of 18.8 pounds on a fish scale.
(http://i220.photobucket.com/albums/dd68/Navy2000-1/Goliath01.jpg)
(http://i220.photobucket.com/albums/dd68/Navy2000-1/Goliath04.jpg)
Duane
Post by: chrise on May 28, 2009, 05:59:15 pm
The replies are really interesting - thank you.   :-))
I love the YouTube video where the load is heavy enough not to care a d--n what the tug does. Towing around where I live seems to involve a load so small & light it leaps to follow the tug.
840lb tows, 15 x 5 litre sand bottles etc - magic to my ears.
Scaling effects are interesting & I would appreciate comment from anyone who knows about full sized towing. I hear what you say about wind & treacle but what size/power/weight ratios are actually scale in behaviour terms. I appreciate the difference between a loaded & an unloaded model tanker in a cross wind & I am sure a full size tug skipper does as well. But where does scale effect/difficulty lie?
I have pushed a 30ft yacht around & I must admit that it did not feel like what I expect a super tanker might feel like but I am not sure why. Of course I might be completely wrong about the feel of a real tug pushing a real tanker. The most real towing/pushing that I have done was on the tug course at Gloucester docks - which was a great day out incidentally!
Chris
I hope to be a Balne Moor in August for the MMM listed "tug-in"
Post by: Navy2000 on May 28, 2009, 10:24:25 pm
One thing that I have told others with tug boats if they are useing a plastic prop is to take it off and throw that away and go with a brass prop and towing power will come up some. The plastic prop will flex while it is being turned and has lots of water to push. Brass props will not do this.
(http://i220.photobucket.com/albums/dd68/Navy2000-1/Goliath1.jpg)
Duane
Post by: ZZ56 on May 28, 2009, 11:24:54 pm
...Why?
According to some books i read, the viscosity difference is overcome by the propeller of the model spinning at higher RPMs for equivalent power output.
I think Chrise is asking why we don't see 1:32 scale ships being used more often, with the obvious answer that such a model would be too large to be practical.  Someone has to store, tow and launch it.  At a smaller scale like 1:96, there are fewer options for tug models and they become much smaller and fiddlier.
Post by: chrise on May 29, 2009, 08:22:00 pm
I was really overstating my point but I am always surprised that even in "championship" towing events the tugs always look so big & overpowered compared to the tow but then "scale" seems so important in other ways.
I was at a towing event a couple of years ago where a very small Springer(ish) type tug with a couple of the smaller Graupner z drives (I think) - from Southend MBC I seem to remember - managed to tow perfectly well but everyone else had models at least twice the size & probably ten times as powerful. This guys efforts seemed worthy of much greater admiration. Instead I seem to remember him being told that he wouldn't have managed to look as good had it been a bit windier.
I know 30ft tows, at most venues & for most of the time, are impractical but then a handicap based on bollard pull, or a better idea, might be interesting.
I will now stand back, duck, & see what happens!!!
Post by: craftysod on June 02, 2009, 11:18:02 pm
Have a look at the Alfold show pics buy Ron.
There is a massive tow by a tiny tug,the pics dont do justice how big it really is,
oh and i want one of that little tug,who owns it,named Tracey
Mark
Post by: ray123 on June 03, 2009, 07:37:50 am
hi craftysod  the guy is a member of our club   the tug is from waveley models  g.r.p hull  14inch powered by a 400 motor
(dont know the name that it is sold under  'sorry')
 the tow belongs to me & is 5ft x 2ft beam   & theres quiet a lot of drag ''there'' :-))  regards ray
Post by: More Coffee on July 12, 2009, 08:02:21 pm
Just use a floating dock..
Lets say the dock is comprised of a series of 45 gallon plastic drum's...each drum when full of water will weight approx 480Lbs... just fill a few drum's full of water and yer off ..
Now Has anybody calculated what a 200,000 ton ship weighs when its in the water ..yes it displaces 200,000 ton of water ..but she should weight less in waterthough not sbmerged..Im trying to remember high school and Archimedes Principal here ..
u
Post by: chrise on July 13, 2009, 11:12:26 am
u
I always thought that if it floated & displaced 200000 tons of water then it weighed 200000 tons & that is why it displaces 200000 tons of water. I am not sure which Archimedes principle you are referring to.
Chris
Post by: Navy2000 on July 13, 2009, 11:45:25 pm
The biggest thing here is to get the proper set up for the tug that you have. I have seen many tugs of the same size and be so far apart in what they could handel. Like the modified darby tug that I had the (Goliath) I had two Pittman servo motors that at 12 volts turned 3500 RPM's and I used the 3.5 inches kort nozzle prop made by prop shop that is what gave me a total power of large bollard pull that I had. This also helped me to push or pull large size barges. I am sure that I could have done more than I did but never tested it out. Now the same motor and prop of the same size with out having the kort nozzles in a Brooklyn tug a friend of mine was able to get about 8.5 pounds of bollard pull on a fish scale. I had one member of my club that had a Sequin tug and was only able to get about 1.5 pounds of pull. It all comes down to a good set up with your model, now all models can not be great with lots of power some tugs just will not allow it do porp size and the RPM's of the motor and also the pitch of the prop. For tug boats I tend to buy my props from Prop Shop and if they have two different props that are the same in Dia. I then will get the one that has the most pitch to it to help out with the pulling power. I also think that speed controls also play a small factor in all of this as well. Not all speed controls will deliver all the volatge that we all hope that they will.
Duane
