Mess Deck: General Section => Model Boating => Topic started by: hoverboy on July 23, 2009, 06:46:41 pm
Can someone please tell me where I can get a revolving radar motor as I am having trouble tracking one down?
Thanks.
flj action i have one very good price
As Gordon says, ACTion R/C Electronics.
Speak to FLJ and get your 5% Mayhem discount.
www.action-electronics.co.uk
got any servos lying around? check the gearset to see it it has teeth allround the final output gear, if so cut the stop dog off it, remove the electronics off the motor, and wire the servo onto 2AA cells. will give you a steady rotation at a realistic speed
If you're short of space for the motor, look at Model Motors Direct - he has a very tiny geared motor, but its quite expensive.
Barrie
Mine is out of an old computer CD drive - there's at least 3 good small motors in those.
get the proper one then you cannot go wrong O0
I'll have a look tonight! :-))
I have had a few of these, very good :-))
http://www.hobbyengineering.com/SectionM.html
Russ
Hi Slim
What Do You Do With The Rest Of The Drive(s)??
try this sites
http://www.precisionmicrodrives.com/
http://www.gizmoszone.com/shopping/storepro5/agora.cgi?
Came Across MMM... They Do What They Call "Flick" Motors.... Seem Suitable For Turning Radars
http://www.mobilemarinemodels.com/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww.mobilemarinemodels.com%2facatalog%2fElectrical.html&WD=motor&SHOP=%20&PN=Motors.html%23a100#a100
Bottom Of Their Page Bud
all this mucking around when dave of action has the right one for around £6
ACTion RC Electronics.
Servo Motor 2 for £ 1.00; M5 £ 3.00; M7 £ 4.50 (All Incl VAT)
M7G MOTOR & GEARBOX
£ 7.00 Incl VAT
Popular for radar drive; includes set of components to give the correct rotational speed from either 1.2v, 6v or 12v supply
ALL LESS 5% Mayhem discount
http://www.action-electronics.co.uk/stuff1.php
I would agree that the Action Electronics offering is the easiest and probably cheapest solution IF you have space. I have used it myself. If however you are short of space, then the MMM one or one from Precision Microdrives takes up less room and doesn't need anything but the motor and a battery.
Barrie
I found the gearset a bit confusing, couldnt get the cogs to line up, so ended up using a servo instead.
Thanks lads.
I certainly now have a good choice, so will have to work out which is the correct one for my application.
Pete
