Technical, Techniques, Hints, and Tips => BRUSHLESS Motors and Speed Controllers => Topic started by: funtimefrankie on November 30, 2009, 01:23:47 pm
Title: 34 inch Precedent Fairey Huntsman
Post by: funtimefrankie on November 30, 2009, 01:23:47 pm
Anyone gone brushless with this model?
(The Glass fibre hull version)
If so what's your set up???
thanks
Frank
Title: Re: 34 inch Precedent Fairey Huntsman
Post by: red181 on December 07, 2009, 11:45:28 pm
ive gone brushless with the 4 foot huntsman 28, not quite there yet with final set up, align 1640kv 600l motor, castle creations hydra reversing esc, 1.5:1 gear ratio, 19.2v nimh, yesterday ran with 2 x 9.6v (19.2v) 4600 mimh packs, and 55mm "x" blade prop, after about 15 mins going quite fast, things started to get a bit warm, so think it was a bit over propped.
Recently tried same set up, but with 52.5mm prop, with 6 cell 5000mah lipos, for approx 15 seconds it was absolutely ballistc :embarrassed:, but then a lipo cell died. After doing some research, I am going to drop to 5 cells, and test with smaller prop, just waiting for the 2 cell to arrive, to pair with a 3 cell I have, I think if I try 6 cells again, something will blow up, and paypal is well and truely empty!! :}
Post by: triumphjon on June 12, 2010, 06:36:19 pm
i see you have gone the brushless route , im about to start a fairey spear , but im looking at biulding as per origanal  , ie twin shaft twin motors ! with the motors fitted in the correct compartment amidships , how did tour model perform ?
Post by: HS93 (RIP) on June 12, 2010, 11:20:08 pm
look at
http://www.modelboatmayhem.co.uk/forum/index.php?topic=21584.0
it has the motor in the right place but it is 42"
Peter
