The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: HS93 (RIP) on February 05, 2010, 10:32:17 am
if you use a external water tank to connect to your clack valve so you can do a quick top up without having to have a have water tanks or spanners to tighten up joints this is what you need , got a few of these today and they look ideal they are even a dry break not that you need one so it would be easy to have a tank and hand pump to top up boiler before you release the boat etc.
http://www.rdgtools.co.uk/acatalog/AIR_BRUSH_HOSES_AND_EQUIPMENT.html
Here's another source, perhaps more convenient for N.American modelers, for brass quick connects. Both single shut off ($10) and double shutoff ($37) available:
http://www.smallparts.com/Single-Shut-Off-The-female-side-of-the-coupler-has-a-shut-off-check-valve-to-prevent-fluid-leakage/dp/B0015HS9MI?ie=UTF8&pf_rd_r=1VGQT4491NDKWK7X1576&pf_rd_m=A2LPUKX2E7NPQV&pf_rd_t=201&pf_rd_i=B0015HN0F4&pf_rd_p=493386671&pf_rd_s=left-4
Another option is to replace the clack valve with a Goodall valve. This might be desireable if you have trouble with the clack ball sticking:
http://www.rcgroups.com/forums/showthread.php?t=1193276
www.swagelok.com also have a very high quality range, although quite expensive....
Yes but THE BEST money can buy. Swagelok are the standard for all fittings on Oil and Gas plants
