Mess Deck: General Section => Model Boating => Topic started by: subs1 on April 02, 2010, 01:05:46 am
Title: R/C swimmenwaggen
Post by: subs1 on April 02, 2010, 01:05:46 am
Does anyone have a copy of an article on converting to radio control the Italiara swimmenwaggen kitset .
I have read the article somewhere but didn't copy it .
Thanks Malcolm  NZ
Title: Re: R/C swimmenwaggen
Post by: Martin (Admin) on April 02, 2010, 09:14:00 am
This one?   http://cgi.ebay.co.uk/1%2F35-model-kits%2F-Italeri-schwimmwagen_W0QQitemZ150420103878QQcmdZViewItemQQimsxq20100305?IMSfp=TL100305178002r12548
Post by: andyn on April 02, 2010, 02:44:34 pm
The Italeri Swimmwagen is only 10cm long, so would be damn near imppossible to convert.
Post by: Subculture on April 02, 2010, 04:10:43 pm
Perhaps you're thinking of the 1/6th scale Schwimmwagen by Dragon models?
http://www.bnamodelworld.com/model-kits/armour-1-6/1-6-schwimmwagen-type-166-75013
Or the smaller 1/16th version by Eduard?
http://www.mediamixhobby.com.sg/shop/military/1-16-scale/1-16-military-kits/ed6106.html
Post by: Philipsparker on April 02, 2010, 07:56:40 pm
I've got the Eduard kit but even though it's the biggest model Swimwaggen available I'm still not convinced that the conversion is possible. There's not a lot of space to hide the mechanics and the kit is probably a bit heavy for floating. Mind you, they did sail with the waterline pretty close to the door tops.
(http://farm4.static.flickr.com/3283/2541289691_bb0533f264.jpg)
(http://farm4.static.flickr.com/3287/2541291051_66a420ecb3_m.jpg)
I recently tried to build a Top Gear style Damper van and just couldn't get enough bouyancy in the thing to make it work properly. Mind you, the waterline on that is pretty low. Photos of this floating(ish) VW at: http://philsworkbench.blogspot.com/search/label/Damper%20Van
Good luck though, I'll be interested to know if this IS possible.
Post by: subs1 on April 02, 2010, 08:08:28 pm
DUH  !!! Your right . I should have said Dragon  1/6th ( I must have had a senior moment ) !!
Thanks , Malcolm  NZ]
