Mess Deck: General Section => Beginners start here...! => Topic started by: Dreadstar on May 07, 2010, 02:38:27 pm
Title: Taking the plunge,building my 1st boat.
Post by: Dreadstar on May 07, 2010, 02:38:27 pm
Ok,so I'm not a newbie on here,but this will be my first ever build from scratch,so in that sense,I'm very much a beginner. :embarrassed:
  I've decided to try something very simple to begin with,as my skills aren't exactly what you could call brilliant,and although it's not a GG plan,I think it's quite similar in style.
  Now as I'm also a big fan of the lamented Bob Symes classic Model World series,I'd thought of doing the Sea Rider too. However I came across an article and set of plans that really peaked my interest,and I thought to myself,why not try that,so here I am starting off building a model of a Vosper Corvette by Clive Halliwell.(Oct 2009 MMI)
  Now I know that you can buy a kit of this vessel,and that it'll look the bees knees,but my finances won't stretch to buying one of them,not only that but I'd be afraid of messing it up during the build. Can you imagine the expletives that would issue forth if I messed it up,coupled with the fact that my painting isn't very good,it would turn out to be a waste of money.
  This way,even if I make a mess of it,I won't have broken the bank ballance doing it.
  I bought all the necessary balsa,propshaft/prop,rudder assy & paint for just over £40.00. I've still to purchace the weapons suite and ships boats/davits though. As it's 1/96th scale,can anyone give me some ideas as to suppliers of weapons in this scale.
 Hull base started,just waiting for the glue to dry.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1430.jpg)
Title: Re: Taking the plunge,building my 1st boat.
Post by: Dreadstar on May 07, 2010, 05:34:23 pm
First hull side on. Won't be able to do any more today though.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1431.jpg)
Post by: Dreadstar on May 07, 2010, 11:21:32 pm
The motor and propshaft and rudder have been installed,though the shaft has yet to be epoxied into place. Next will be the building and fitting of the servo mounts,then I can fit the other side of the hull into place. I'll post photo's of each stage as it's completed.
Post by: Dreadstar on May 08, 2010, 12:20:08 pm
Second side now on,and motor and propshaft epoxied into place.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1432.jpg)
Post by: Dreadstar on May 09, 2010, 11:42:02 am
Getting there slowly but surely.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1433.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1434.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1435.jpg)
Post by: hama on May 09, 2010, 12:58:02 pm
Hey, that looks great! She will be a beauty on the water, one can tell already.
Good luck!
Hama.
Post by: Dreadstar on May 09, 2010, 06:33:37 pm
Thanks for that Hama,and even though I was out sailing most of the afternoon,I've now got all the decks finished,and the aft superstructure fitted to the rear deck. I'll post some more pics later tonight.
Post by: Dreadstar on May 09, 2010, 11:59:52 pm
As promised,here are the current photo's of the build.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1436.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1437.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1438.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1439.jpg)
Post by: Martin (Admin) on May 10, 2010, 08:50:40 am
Well that don't look too bad at all!   :-))
Post by: Dreadstar on May 10, 2010, 09:18:28 am
I would say that that was the easy part,now comes the hard part......fitting her out. I've built and fitted the bridge structure,but something doesn't seem quite right about it,so I'm probably going to have to re-do it. {:-{
 One thing I've found out,is that there are very few photographs of this corvette,which make detailing her a bit of a swine. I can only find the one view of her,which is taken from the water looking upwards to her starboard side. Does anyone know where I can find an aerial shot of her,so that i can find out details of her deck layout please? :-)
Post by: DickyD on May 10, 2010, 05:41:18 pm
Hi, not having the plan, which Vosper corvette is this you are making ?
Post by: Shipmate60 on May 10, 2010, 05:45:15 pm
You can get modern 1/96 scale fittings from sirmar: http://www.sirmarmodelships.com.
Dicky its the modern Vosper Corvette similar to the small Deans one.
Post by: Dreadstar on May 10, 2010, 06:18:08 pm
Yup,it's the Vosper MkIII Corvette,the version with the twin mounted HA 4" gun turret and 2x 40mm bofors. Max speed 23kts.
Post by: Dreadstar on May 11, 2010, 12:14:20 am
The original bridge,as per the plans,though I wasn't too happy with it.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1440.jpg)
 The bridge as it is now,having found a semi-decent photo of her.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1441.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1442.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1443.jpg)
The photo's that I found.The top one is of a MkI,and the second one is of the MkIII
(http://i92.photobucket.com/albums/l4/xuihpilli/kromantse.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/dorina.jpg)
Post by: Dreadstar on May 11, 2010, 02:57:52 pm
I've got most of the mainmast built now,but don't expect it to be overly realistic. :embarrassed:
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1445.jpg)
I also got my ships weapons through today from John Smith,and crackers they are too. Just positioned roughly on the hull,just to get some idea of how she'll look. ok2
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1444.jpg)
Post by: Dreadstar on May 11, 2010, 05:56:12 pm
Current position,complete with home made funnel,(not too bad for a first attempt),I know that it's not quite the correct shape,but it'll do me.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1446.jpg)
Post by: hollowhornbear on May 11, 2010, 10:05:23 pm
looking good O0
Post by: Dreadstar on May 11, 2010, 11:31:01 pm
Thanks for that bear,but please don't expect the super-detailing finish that we're all so envious of. Wood is not my medium,so the fact that this has turned out so well thus far is amazing,I've really surprised myself here.  The next headache is going to be the tripod rear radar mast.......EEK
  I've got some ships boats and derriks coming from Reade's models,though I wish that I'd ordered some life rafts whilst I'd been shopping online. I'm not too sure what to make them from though,any ideas anyone?
Post by: derekwarner on May 12, 2010, 07:28:22 am
 :embarrassed: nice to see Dreadstar that you have Fosters in Glasgow......... {-) %% - Derek
Post by: Dreadstar on May 12, 2010, 04:04:35 pm
Ok,so I've still to cross brace the mast legs,but I think it'll do.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1447.jpg)
 The first of the aerials for this boat.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1448.jpg)
Post by: Martin (Admin) on May 12, 2010, 04:38:55 pm
Class workmanship Dreadstar   :-))
Post by: Dreadstar on May 12, 2010, 04:59:11 pm
A quick blast with the paint can,just to see how it'll look,(using Humbrol Sea Grey).
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1449.jpg)
The rear Radar mast.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1450.jpg)
Post by: Martin (Admin) on May 12, 2010, 05:17:15 pm
I would prep the hull with 'sanding sealer' or the like first, gives a much better finish....
Post by: Arrow5 on May 12, 2010, 05:21:14 pm
ARRRRGH Martin NO ! %) :o :o :o :o not on the Humbrol painted bits.   Sanding sealer only on bare wood.
Post by: Dreadstar on May 12, 2010, 05:42:16 pm
Since I don't have much in the way of free cash at the moment,I'll be sealing the hull with multiple coats of yacht varnish,both inside and out. That's what I sealed the RBR speedboat with after all,and that seemed to work out alright.Ok,so it's not as good as resin would be,but we have to cut our coat according to our cloth. ok2
 The good thing is,that there are 3 separate deck sections,which can all be painted away from the hull,which will be getting dealt with separately.
Post by: Martin (Admin) on May 12, 2010, 06:37:38 pm
Sorry, yes, that's what I meant.   :embarrassed:
Post by: Dreadstar on May 14, 2010, 12:20:55 am
The hull has had it's 1st coat of varnish,which was rubbed down once it had dried,she's just had her 2nd coat of varnish applied. The bridge window frames have been cut out and stuck in place,so it's looking a bit more like the thing now. I haven't had much in the way of time to work on her today,but hopefully tomorrow will see some more progress done to her,and I can post up some more pics. ;)
Post by: Peter Fitness on May 14, 2010, 02:48:25 am
Not wishing the Scots any harm, but Glasgow is about far enough away for me. Fosters  >>:-( Horrible stuff  O0
You're doing a good job Dreadstar, she looks great  :-))
Peter.
Post by: Circlip on May 14, 2010, 09:42:13 am
Bit late now, but one of the most effective ways to seal a Balsa hull with this or hard chine construction is tissue paper and "Dope". The tissue is the same as used for covering toy Aeros and the method was given an excellent write up by FLJ in the Swordsman build log. Strengthens the structure too as well as giving a smooth base.
Post by: Dreadstar on May 14, 2010, 12:53:15 pm
Not a lot done yet,but that's the bridge details done now I think.She's actually starting to look like a ship now.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1451.jpg)
Post by: Tugwilson on May 14, 2010, 01:01:01 pm
I knew there had to be something useful in a can of Fosters  {-)
it's looking great Dreadstar keep the pics coming
Tug
Post by: Dreadstar on May 14, 2010, 03:03:16 pm
Some more detailing done,including finding another couple of aerials. Dropdown panels represented on aft superstructure. ok2
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1453.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1452.jpg)
Post by: Dreadstar on May 15, 2010, 04:29:59 pm
Didn't get a lot of time to work on the boat today,but still,I've made the liferaft holders & rafts,fitted some ammo lockers and the fancy deflector plate at the rear of the deckhouse. The hull has had it's 3rd coat of varnish now too.I'm still waiting on my ships boats and davits to come through the post.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1454.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1455.jpg)
Post by: Dreadstar on May 16, 2010, 12:52:49 pm
Ok,she's had her tank test(re bath),which she passed with flying colours. All the R/C gear has been installed and tested,though trimming her weightwise is going to be a headache. At the moment,she has 2x 3700mAh 7.2V  batteries,one either side of the motor,plus a 3700mAh 4.8V pack in her just to reach the boot top. I'll be running her on just the 4.8V pack,as the revs produced by the 7.2V pack,will power her like a fast electric. She's had her first coat of paint,but I've now run out of grey,so she's going to have to wait for her next coat. I'm charging up my camera battery just now,so that I can take some pics and vids of her afloat and sailing.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1456.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1457.jpg)
Post by: Dreadstar on May 16, 2010, 06:35:03 pm
Had her at the pond today for a test sail,and all I can say is oops. Even at 4.8V,I had to turn my throttle EPA right down to almost nothing,or she'd try to act like a diving speedboat. This little thing is fast,faster that the Sovremenny RTR and that's saying something. I need to add some more lead to the stern compartment,to try and keep the bow up a bit. You'll see what i mean from the photo's and short vid.(I'm barely using any throttle here).
  I'd to take out the stickpacks,as they were just too heavy,I replaced them with some lead sheet instead,but she still rolls like a pig. I may need to fit stabalisers to her to try and cut down on the roll.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1459.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1460.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1462.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1463.jpg)
I'll post the vid once it's been uploaded.
Post by: Dreadstar on May 16, 2010, 06:45:57 pm
As promised,here the short vid from today.
http://www.youtube.com/watch?v=OhJ6DkYjY0g (http://www.youtube.com/watch?v=OhJ6DkYjY0g)
Post by: DickyD on May 16, 2010, 08:49:17 pm
Think a smaller motor might be a good idea.
Other than that, well done it looks ok. :-))
Post by: Dreadstar on May 17, 2010, 01:00:13 am
I've still to finish painting her,and fit the ships boats when they come through,but other than that I'm very happy with how she's turned out.  :-))
  The only reason that she's got the 540 motor in her,is that was all that I had laying around,and I wanted to keep my costs to a minimum.  ok2
Post by: Dreadstar on May 17, 2010, 06:21:49 pm
Current painting status.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1466.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1467.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1468.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1469.jpg)
Post by: Dreadstar on May 19, 2010, 12:37:08 pm
Decks have been painted,and most of the ship has been given a coat of varnish,to protect the surface.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1470.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1471.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1472.jpg)
Post by: Shipmate60 on May 19, 2010, 01:29:41 pm
That is coming together nicely.
Post by: Dreadstar on May 20, 2010, 02:24:18 pm
I got my 30mm plastic props through today,along with some lifebelts,both of which have been added to the ship.  I should have my ships boats through either tomorrow or the next day,which will finally allow me to fill in that large gap on the upper deck. I've made up a stand for her,crude though it is,but it'll do me just now.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1474.jpg)
Post by: Tugwilson on May 20, 2010, 07:11:46 pm
Ha the stand is fine just give it a coat of paint  :-)) and your have it top draw. it's come out very well for a first effort. ok2
when i think back to my first effort ......well we shall not go there.... {-)
Post by: Dreadstar on May 20, 2010, 11:39:07 pm
Thanks for that Tug. There's still a lot of work to be done to her,but at least I've got an operational boat. Some more short vids,and a few pics from today.
http://www.youtube.com/watch?v=88pPRvLW08w (http://www.youtube.com/watch?v=88pPRvLW08w)
http://www.youtube.com/watch?v=4yn2CFDLdBY&layer_token=76237915258a4121 (http://www.youtube.com/watch?v=4yn2CFDLdBY&layer_token=76237915258a4121)
(http://i92.photobucket.com/albums/l4/xuihpilli/001.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/003.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/004.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/005.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/007.jpg)
Post by: Dreadstar on May 21, 2010, 01:47:14 pm
Davits fitted,and the ships boats roughly in position,they've still to be painted though,but it'll give you a good idea of how she's going to look.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1482.jpg)
Post by: Tugwilson on May 21, 2010, 04:35:51 pm
he he he excuse my titter. how are your crew going to launch the tenders,? the davits are going to be int the way for them to swing over the side. {-) %%
just my sence of humer Dreadstar. it's lokking the dogs whats its. well done have fun sailing her.
Tug
Post by: Dreadstar on May 21, 2010, 06:15:27 pm
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1483.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1484.jpg)
Post by: Dreadstar on May 23, 2010, 05:39:07 pm
Some vids & pics from today.
http://www.youtube.com/watch?v=bmYNXnujTIE (http://www.youtube.com/watch?v=bmYNXnujTIE)
http://www.youtube.com/watch?v=ePTtsYCy6ts (http://www.youtube.com/watch?v=ePTtsYCy6ts)
(http://i92.photobucket.com/albums/l4/xuihpilli/001-1.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/002.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/003-1.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/005-1.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/006.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/007-1.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/008.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/009.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/010.jpg)
Post by: Martin (Admin) on May 23, 2010, 06:12:57 pm
This is just a great build Dreadstar, simply great!   :-))
Post by: Dreadstar on May 23, 2010, 06:20:25 pm
Thanks for the compliment Martin,it's much appreciated. That's the bulk of the work done now,it's just the details that I've still to finish,but I'm very happy with how she's turned out,and how she sails.
David.
Post by: Martin (Admin) on May 23, 2010, 06:31:10 pm
I've just had a look and I thought that I had this magazine but no, has anyone got a copy I can borrow?
Post by: dougal99 on May 23, 2010, 10:15:32 pm
Martin
I have a copy complete with plan that I will bring along to Wicksteed (assuming I make it in one piece)
Doug
Post by: Dreadstar on May 23, 2010, 10:19:58 pm
Have I piqued your interest in this wee ship then Martin?  :-))
Post by: Dreadstar on May 24, 2010, 02:44:40 pm
Getting there slowly but surely. The i.d. number is just temporary,until I can get some decent vynyl stickers for her.
(http://i92.photobucket.com/albums/l4/xuihpilli/001-2.jpg)
Post by: Dreadstar on May 25, 2010, 02:05:53 pm
I'm in the process of re-painting the lower hull,as I feel that the red I used was just too vibrant. I'm currently re-doing it in a brick red shade,which shouldn't look quite so garish to the eye. I've also built a rather crude anchor winch,which I know won't look anything like the real thing,but it should hopefully give the right impression of one. Like I said in an earlier post,this ship just needs to look the part,she doesn't need to be too accurate,which I don't think I'm capable of yet anyway.
Post by: Dreadstar on May 25, 2010, 11:58:35 pm
I'm going to do away with the anchor winch and go with two capstan winches instead,which seems to make more logical sense than my idea.
(http://i92.photobucket.com/albums/l4/xuihpilli/001-3.jpg)
Post by: Dreadstar on May 27, 2010, 12:03:04 am
Modified foredeck fittings,navigation lights recessed into leading edges of bridge,and 2nd coat of brick red paint below the waterline.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1498.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1499.jpg)
Post by: Dreadstar on May 27, 2010, 12:44:50 am
Current side view.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1500.jpg)
Post by: Dreadstar on May 27, 2010, 11:41:12 pm
Some more pics from today. In the vid that I'll post later,a bad connection left her without power,and at the mercy of the wind.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1505.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1504.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1503.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1502.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1501.jpg)
Post by: Dreadstar on May 28, 2010, 12:16:27 am
Well now,this is embarassing,filming your boat,when a duff connection leaves you powerless to aid your stricken boat. I've since replaced the ESC with another one,and she works ok again. I'll really need to change over all my connections to Deans plugs,rather than rely on the vagaries of the Tamiya plugs.
http://www.youtube.com/watch?v=P8RZ34F3YV8 (http://www.youtube.com/watch?v=P8RZ34F3YV8)
Post by: Peter Fitness on May 28, 2010, 03:05:39 am
I definitely recommend Deans plugs  O0. I had a similar problem to you about 4 years ago while sailing in the Lane Cove River, Sydney. The boat drifted way up stream for about an hour until my son was able to obtain a rowing boat from a friendly boat hirer. When the boatman saw the model, he would not charge my son for the rowing boat.
The problem proved to be a faulty connection, so I fitted Deans plugs in all my boats and have had no further trouble.
Your boat looks great on the water, Dreadstar, well done  :-))
Peter.
Post by: Dreadstar on May 28, 2010, 06:41:51 am
Thank you Peter,I'm just glad that she's turned out so well. It would be interesting to see what sort of a job one of you pro's can make of it. Personally,I think my one looks sharper than the one in the article,but I may well be looking through rose coloured glasses,don't you. Still,at least I've proved to myself that I can build something that sails quite well. Now to decide,once she's been finished off,just what my next project will be,though I'm drawn to GG's semi-scale WWII U.S.S. Ripley.That might be quite a nice little ship to try next.
Post by: Peter Fitness on May 28, 2010, 11:34:32 pm
I'm no pro, Dreadstar, I'm still in the Intermediate class. The pros are the likes of Bluebird, DickyD, Tug Kenny and Bryan Young, to name just 4 of many on this forum. Some of the modellers on Mayhem have been involved in the hobby for much of their lives, whereas I only started in 2004 and I'm still on a steep learning curve.
It has been said that experience is not making the same mistake twice - if that's so, then I'm a slow learner  :embarrassed:
The Ripley should make up into a nice little model. It was interesting to read Glynn Guest's comment that he tried to incorporate a prototypical "heel" into its design, but it proved to be too stable.
Peter.
Post by: Dreadstar on May 29, 2010, 10:02:57 am
I'm an even newer start than you then,I only started on boats last July. I'll admit,that the heel of the corvette caught me a bit off guard when I first tried her out,but she straightened out afterwards.A good few nervous moments I can tell you,but I've got a handle on her quirks now,and you can throw her into a tight turn without any worries,as you can see in the vids. I've now got the anchor chains in place. I've ordered up ladders,stantions,anchors, bollards,and ariels for her which will take about two weeks,in order to finish her off.
 I was never really a large scale modeller,spending 36 years playing miniature wargames before moving onto R/C cars in 2006,then boats in 2009. Modelwise,I was scratchbuilding spaceships for Irregular Miniatures,over 100 different designs,but I burnt myself out doing it. A couple of examples:-(The first ship was only made for myself)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1049.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1053.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1018.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1003.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN0979.jpg)
Post by: Dreadstar on May 31, 2010, 12:00:07 am
Had the pond all to myself,as most of the other members were over at Knightswood club.
http://www.youtube.com/watch?v=JXbXuIcB_cE (http://www.youtube.com/watch?v=JXbXuIcB_cE)
Post by: Dreadstar on June 06, 2010, 06:32:20 am
Just a short vid from yesterdays Open Day.
http://www.youtube.com/watch?v=YUF45_XNHO4 (http://www.youtube.com/watch?v=YUF45_XNHO4)
Post by: Dreadstar on June 12, 2010, 03:15:21 pm
Latest vid,trying to get that darned Homer Nip to heave to for inspection.
http://www.youtube.com/watch?v=ohZN0vRRWw4 (http://www.youtube.com/watch?v=ohZN0vRRWw4)
Post by: Dreadstar on June 14, 2010, 12:27:46 am
Another vid,this time with a young newbie at the helm.
http://www.youtube.com/watch?v=U6d3JtlruJo (http://www.youtube.com/watch?v=U6d3JtlruJo)
Post by: Dreadstar on June 18, 2010, 10:20:43 pm
I'm getting there slowly but surely. I really don't know how you lads have got the patience to do miles of handrails,what I've done so far,is beginning to drive me nuts.Still,I think that it's improving the look of my little corvette,especially now that I have all the remaining fitments that I need.  :-))
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1544.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1545.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1546.jpg)
Post by: Dreadstar on June 20, 2010, 06:58:52 pm
Some pics from today,plus another vid,showing her current build status.
(http://i92.photobucket.com/albums/l4/xuihpilli/003-3.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/004-2.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/006-2.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/008-2.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/009-1.jpg)
http://www.youtube.com/watch?v=Mks-4V7L9u8 (http://www.youtube.com/watch?v=Mks-4V7L9u8)
Post by: Dreadstar on June 21, 2010, 11:59:51 pm
I've finally cut out and painted her characteristic freeing ports,and added the warning labels to the sides of the guns. The 1/72nd figures aren't painted as well as I used to be able to do,middle aged eyesight and all that,but they don't look too out of scale. They'll do until I can get hold of some decent 1/96th figures. Anyway,here are some current pics of her prior to having the repainted sections varnished. I've still to rig the mast for the signal and pennant flags and buy a Ghana navy ensign for her,then I think I'll be finished.
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1558.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1559.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1560.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1561.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/DSCN1562.jpg)
Post by: dan on June 22, 2010, 12:08:29 am
Spot on mate  :-)) :-)) :-)) it looks like it runs very well on the water  O0
Post by: Dreadstar on June 22, 2010, 05:44:25 pm
DOH.....A bit of a Homer moment there I'm afraid,it's not the Ghana flag that I require,it's the Nigerian flag. She's the NNS Otobo(F82), sistership to the NNS Dorina(F81). I haven't a clue where i got Ghana from.  :embarrassed: I've ordered up the flag as well as a Rab 25mm 3-blade brass prop(type 1),which with a little luck will slow her down appreciably,to something closer to reality,unlike the warp speed that she's capable of just now.  ok2
 Does anyone know where I should fly the flag from,or do I need to add a jackstaff to the aft deck?
Post by: Dreadstar on June 24, 2010, 06:43:38 pm
Just a few pics from today.
(http://i92.photobucket.com/albums/l4/xuihpilli/001-5.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/002-3.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/003-4.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/004-3.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/006-3.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/007-4.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/008-3.jpg)
(http://i92.photobucket.com/albums/l4/xuihpilli/005-3.jpg)
Post by: Dreadstar on June 25, 2010, 04:02:31 pm
Now fitted with a Raboesch(type1)25mm 3-blade brass prop. These two video's show just how maneuverable she really is. The first one is of normal ahead running,and the second one is of her going astern.
http://www.youtube.com/watch?v=b0yjm33q2Rs (http://www.youtube.com/watch?v=b0yjm33q2Rs)
http://www.youtube.com/watch?v=Jve1W-lgDzo (http://www.youtube.com/watch?v=Jve1W-lgDzo)
Post by: Circlip on June 25, 2010, 04:17:47 pm
Bet the crew "Enjoyed" the Captains slalome session in the first vid, especially if they were in the mess having lunch  :-))  {-)
  Looks good Dreadstar, what next??
Post by: Dreadstar on June 25, 2010, 04:37:43 pm
I'm thinking that I might try making GG's Paladin class semi-scale frigate next from MB Oct 2005 issue. Hopefully it's as straight forward as it seems,though I might modify it slightly to suit myself. :-))
Post by: Myansome on July 07, 2010, 11:31:51 am
All I can say is BRILL! That's given me great inspiration! Cheers, mate!  :-))
Post by: Dreadstar on July 11, 2010, 08:22:38 am
The wee Otobo at the Warship Weekend 2010.Watch out for the 1/72nd scale Bismark at the end.
http://www.youtube.com/watch?v=nngVrL7MfN0 (http://www.youtube.com/watch?v=nngVrL7MfN0)
Post by: Myansome on July 11, 2010, 11:20:42 am
  :-)) as we do say do here ........................ ansome job!!!!!!
Post by: Dreadstar on July 18, 2010, 08:21:11 pm
A short vid from today at Elder Park.
http://www.youtube.com/watch?v=X8GJarqc4-Y (http://www.youtube.com/watch?v=X8GJarqc4-Y)
Post by: brianB6 on August 29, 2010, 05:05:43 am
Hi Dreadstar
Pity I was not a member of the forum when you started building Otobo since I have VT's "as fitted" 1:48 General arrangement and numerous detail plans and photos of the Dorina that I obtained during a visit to VT's in 1980.
My model was inspired by a photo on the cover of a Model Boats mag. around then.
Having just returned to model boating after other interests over the past 20 years, I am currently updating the radio and adding detail to my Dorina.
I will post a photo once I have learnt how to do it on this site
B6
Post by: Dreadstar on August 30, 2010, 12:08:09 am
I'd really like to see a 1:48th scale model of the Dorina,so once you've figured out how to post the photo's Bob,then please put them up.  :-))
Post by: brianB6 on August 30, 2010, 05:21:45 am
Hi Dreadstar
Hopefully these will appear on the screen.
The model took me about 3 years on and off.   I love doing the small bits and at the time wanted to 'get it right'.
The hull is ply bulkheads and skin apart from the bulwarks and flat sides which are .75 mm. styrene.
The deck and superstructure are 1.5 mm. perspex which apparently is now coming into fashion.
Details from brass and perspex.  4"  Gun traverses and elevates, Radars revolve, and most lights work.
I am currently changing to 5 channel 2.4 gig radio since the old 29 meg Tx has 'had it'
I will also finish the bridge details (captains chair and gun site etc.) and try to make the ladders if I can still work to that accuracy and vents if I can work out how to build them.
Post by: Peter Fitness on August 30, 2010, 05:41:33 am
Lovely work, Brian :-)), very impressive O0
Peter.
