Mess Deck: General Section => Model Boating => Topic started by: CERES on June 15, 2010, 10:09:02 am
:-)I have made a balsa plug of a rowing boat and I now want to create the actual boat from paper Mache.
Having tried using torn newspaper and flower/water paste, when fully dried it does not come away from the plug without tearing.
Anyone got any suggestions or do you think a plug could be formed from Plasticine.
Many thanks,
Ceres.
Make sure your plug is highly polished on top of the 2 pack gloss paint you should be using, then give the plug a mist spraying of Trex or another sprayable cooking oil. ok2
As you're making paper hulls and not fibreglass, the plug surface doesn't need to be like a mirror, but it helps.
Nige
Another option: wrap the plug with clingfilm.
.... or a wax.
Vasaline always works for me :-))
Any of the above should work, but remember that flour/water paste was what was used pre-polycell to fasten wallpaper to walls, so a layer of something is needed.
All the release ideas are excellent :} It is Mayhem after all!
Suggestion for glue: use diluted emulsion paint - its an acrylic and when hard is waterproof thereafter
(http://i222.photobucket.com/albums/dd159/andrewh_photo/Footys/Footbeard/DSC02785.jpg)
and with a gold-coloured* coat
(http://i222.photobucket.com/albums/dd159/andrewh_photo/Footys/Footbeard/DSC02787.jpg)
*my style advisor buys matchpots - I get to use them up
Came out very well, but I confess that I used a layer of epoxy/finishing cloth for the final (outside) layer
(http://i222.photobucket.com/albums/dd159/andrewh_photo/Footys/Footbeard/DSCF1073.jpg)
In fact you can use any glue, so long as you waterproof well enough
andrew
:-)) :-))Just as I thought. If you want an answer to a question on models, Non better than members of Mayhem Forum. Thanks a lot Guys.
Ceres.
That looks great ,very well done .
