Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: helmsman on January 13, 2007, 10:30:16 pm
Title: Can anyone help
Post by: helmsman on January 13, 2007, 10:30:16 pm
I have been given a set of 2ch FUTABA 27m radio gear. The problem is that someone has cut the receiver aerial and i do not know what the true length of it is. The set is called "BIONIC GOLD". The "Tx" is the "FP-T2NCR" and the "Rx" is the "FP-R102GR". Can any one help.
Title: Re: Can anyone help
Post by: roycv on January 13, 2007, 10:34:41 pm
Hi, go for 30 inches, its not that critical.
regards Roy
Post by: Colin Bishop on January 13, 2007, 10:42:14 pm
Roy is right. Around 30 inches or 76cm should be fine for 27meg boat use.
Post by: Faraday's Cage on January 14, 2007, 10:08:58 am
TIP :-
Before I cut down a receiver aerial I measure the length and mark it on the back of the receiver body.
Then, if I want to use the rx in another model I know what the full length of the aerial should be.
Terry.
