The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: Patternmaker on July 02, 2010, 04:46:15 pm
Title: RYOBI 30cc LEAF BLOWER CONVERSION
Post by: Patternmaker on July 02, 2010, 04:46:15 pm
Ryobi  30cc leaf blower conversion to water cooled. marine. Bought from ebay for £24.00
Well made engine with solid con rod, 2 piston rings & fairly light, good project for conversion.
I ditched the clutch and pull start, machined the fins from the face of the flywheel, manufactured a pulley which also locks the flywheel..
Flexi shaft coupling.tapped to 9mm to fit crankshaft.
Machined the fins from cylinder and made a water jacket from 3” Dia Aluminium bar much larger than Zenoah with increased cooling capacity.
Title: Re: RYOBI 30cc LEAF BLOWER CONVERSION
Post by: martno1fan on July 03, 2010, 08:28:19 am
Loveley work Mick look forward to seeing it finished.
Mart
Post by: Patternmaker on July 03, 2010, 08:55:28 am
Cheers Mart, just engine mounts & cooled manifold to make.
Post by: martno1fan on July 03, 2010, 04:07:47 pm
Some people can be a bit negative about the use of these cheap strimmer type motors but ive found them to be quite reliable when ive used them.Ok not the fastest motors out there but with a few tweaks which im sure you have in mind theyre great value.I only wish i had the access to a lath and the skill to use it  :((.
Mart
Post by: Patternmaker on July 03, 2010, 09:23:56 pm
Mart
Yes Mart your absolutely right about the negativity, as I have said before If I can produce a reasonable reliable engine conversion for under £50.00 including engine, materials, engine mounts, coupling & header its well worth it.
The Ryobi was originally an American design now manufactured under licence in China, spares are easily available.
The 30cc engine has a 36mm bore and 30mm stroke, with a but if tweaking, change the carb I hope to get around 1200rpm.
Dave reckons it will turn a 482 prop, 82mm Dia 114.80 pitch.
Mick
Post by: Patternmaker on July 04, 2010, 03:04:51 pm
New exhaust flange made from 3” dia aluminium bar, comparison to Zenoan smaller flange.
Post by: martno1fan on July 04, 2010, 09:34:18 pm
Hi Mick yea the x482 or prather 280 were the best props for my old weedy powered boat ,that was just with a carb change to a wa167 carb.
 That said after a bit of porting (nothing exotic as i know nothing about it really i just copied what others had done etc) i could spin a smaller prop .I found the 3 blade 6717/3 ran ok also but i think maybe a 70 mm diam 3 blade prop would have been even better.If you can get 12,000 rpm a 275 prop might be another decent prop to try,its what a lot of the Americans used on the old homie powered boats.
 The flange looks very good you do nice work as allways  :-)).
Mart
Post by: Patternmaker on July 07, 2010, 04:37:41 pm
Finished engine, total weight 1.5kg, getting 10750rpm with existing carb
Post by: martno1fan on July 08, 2010, 01:09:02 pm
Looks very nice Mick should make a good sports engine  :-)).
Mart
Post by: Patternmaker on July 08, 2010, 01:40:32 pm
Cheers Mart, just the hull to do to put it in.
Mick
Post by: Patternmaker on July 15, 2010, 12:48:08 pm
Final modifications, carburettor insulator made from 3” dia aluminium bar with Teflon gaskets to prevent warping when hot, a common problem
With Zenoah's, causing bad idling and loss of top end power.
Smaller plug cap to fit under hatch cowl.
Getting 11800 rpm with 16mm venturi carburettor without tune pipe.
Post by: phillnjack on February 12, 2011, 12:46:47 am
Youve turned that into a real nice piece of kit.
I do like your cylinder jacket for the cooling,very good work.
those car and exhaust plates also look very good,you should make a few to sell,im sure
people would buy them as they look very well made.
you now have a very nice engine, and saved a few hundred quid as well.
very well done, what boat is it going in ?
phill :-))
Post by: Patternmaker on February 12, 2011, 04:46:42 pm
The engine went in this boat!
Mick
http://www.modelboatmayhem.co.uk/forum/index.php?topic=24616.0 (http://www.modelboatmayhem.co.uk/forum/index.php?topic=24616.0)
Post by: dadandlad on February 12, 2011, 07:53:10 pm
What angle and width do you cut the starter pulley vee
Cheers Mark
Post by: Patternmaker on February 12, 2011, 08:03:30 pm
Hi Mark, exactly the same as a 12v starter pulley.
Mick
Post by: dadandlad on February 13, 2011, 08:26:55 am
Thanks Mick
Just one more question,have you kept the same diameter or made it bigger so as to lower the gear ratio to make it a little easier on your starter motor
Thanks Mark
Post by: Patternmaker on February 13, 2011, 09:00:21 am
Hi Mark, the pulley dia is 2.25"
If you are converting the same engine you will need a Sullivan starter, it has a lot of compression.
Mick
Post by: phillnjack on February 13, 2011, 05:08:39 pm
I agree with the above
as cheap starters are not worth buying, they dont have the ooomph for some engines.
ive come across afew that will no way start a sc91 ,unless on 24 volts.
i do think this engine conversion is very good.
phill :-)
Post by: dadandlad on February 14, 2011, 07:20:43 am
Cheers Mick
I will bear that in mind when i purchase my starter
Total agreement with phillnjack the conversion looks very proffesional  :-))
