The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: Abfil on October 25, 2010, 08:39:04 pm
Title: Express yacht windstorm 45
Post by: Abfil on October 25, 2010, 08:39:04 pm
Hello
I m show you the built of my second boat. It’s an express cruiser of 45 feets. I m inspire of the spider of Cantieri di sarnico. I m made it with my son Lucien.
(http://nsm04.casimages.com/img/2010/10/25/101025093456535046992291.jpg)
After a modeling on delftship I drawing on autocad alls plans of pieces, kell, and sections in first.
(http://nsm04.casimages.com/img/2010/10/25/101025093614535046992305.jpg)
The modeling
(http://nsm04.casimages.com/img/2010/10/25/101025093707535046992331.jpg)
The outside view
(http://nsm04.casimages.com/img/2010/10/25//101025093719535046992332.jpg)
The pieces
Title: Re: Express yacht windstorm 45
Post by: Abfil on October 25, 2010, 08:45:47 pm
I built keel upward. There re 7 sections in plywood in thickness 5 mm. The keel is made with 2 pieces of plywood 5 mm. Notches are cut for piece of wood 5x5 mm for consolider.
(http://nsm04.casimages.com/img/2010/10/25/101025094140535046992369.jpg)
(http://nsm04.casimages.com/img/2010/10/25/101025094210535046992371.jpg)
(http://nsm04.casimages.com/img/2010/10/25/101025094353535046992383.jpg)
(http://nsm04.casimages.com/img/2010/10/25/101025094505535046992409.jpg)
Bye
Philippe
Post by: gwa84 on October 25, 2010, 10:37:01 pm
nice work would like to see more  :-))
Post by: Abfil on October 26, 2010, 10:23:01 am
Hi everybody
Thanks !
Here is now the pose of pieces 5x5 mm. There re only 4. Two for the corners and two for the deck plate.
(http://nsm04.casimages.com/img/2010/10/25/101025095123535046992463.jpg)
(http://nsm04.casimages.com/img/2010/10/25/101025095100535046992437.jpg)
The floor of bath is stiked behind the first section with fobs.
(http://nsm04.casimages.com/img/2010/10/25/101025095111535046992452.jpg)
For the bow, I could not to arch the piece. It’s too little. Then I cutted plywood with the good shape. I added fobs in same material.
(http://nsm04.casimages.com/img/2010/10/25/101025095135535046992464.jpg)
Bye
PS adress of plans
http://plansmodelismeyacht.blog4ever.com/blog/index-333923.html
Post by: martno1fan on October 26, 2010, 03:14:20 pm
Very nice work my only concern is the thickness of ply your using as it might end up a tad heavy,might be something to think about but nice work all the same  :-)).
Mart
Post by: Abfil on October 26, 2010, 03:28:01 pm
With the software delftship I calculated a weight of 1,9 Kg . I m not afraid. I think use accus less heavy than battery. I wait after the pose of hull for weigh it.
Post by: Abfil on October 27, 2010, 12:03:19 pm
hello, the continuation ..
Now that the skeleton is very stiff, I pursue with the pose of hull. There re 4 boards. 2 for bottoms and 2 for sides. I m begin with bottoms and after sides
(http://nsm04.casimages.com/img/2010/10/27/101027122710535047001424.jpg)
First botton
(http://nsm04.casimages.com/img/2010/10/27/101027122734535047001425.jpg)
Second botton
(http://nsm04.casimages.com/img/2010/10/27/101027122909535047001426.jpg)
The pose of sides is more dificulte because the bow is very waisted. I m put in water the wood for soften it
(http://nsm04.casimages.com/img/2010/10/27/101027122920535047001428.jpg)
Before of to stick top of hull Lucien sand that who exceed.
Bye
PS adress of plans
Post by: Abfil on October 29, 2010, 10:07:35 am
Hello
Now, we are going to put other pieces of wood 5x5 for access to the front of boat. There is 4. We added also a section in alft of the floor of bath.
Tne little board stick on. We used paper size for drawing it correctly.
(http://nsm04.casimages.com/img/2010/10/29/101029102558535047013877.jpg)
(http://nsm04.casimages.com/img/2010/10/29/101029102610535047013880.jpg)
(http://nsm04.casimages.com/img/2010/10/29/101029102621535047013883.jpg)
Bye
PS adress of plans
Post by: martno1fan on October 29, 2010, 02:33:29 pm
Very nice work
Post by: Abfil on November 03, 2010, 11:29:17 am
hello
Now I m stick pieces of access to  the bow. There re built in 4 parts. It's board of samba in tickness 2 mm
(http://nsm04.casimages.com/img/2010/11/02/101102095740535047045580.jpg)
(http://nsm04.casimages.com/img/2010/11/02/101102095800535047045583.jpg)
Then I m start the bath board. It s easy to make. 2 boards, up and down and between fobs cut not parallel
(http://nsm04.casimages.com/img/2010/11/02//101102100309535047045604.jpg)
(http://nsm04.casimages.com/img/2010/11/02/101102101721535047045699.jpg)
(http://nsm04.casimages.com/img/2010/11/02//101102101747535047045700.jpg)
The suburd is dress with a lot of pieces of wood and after sanded
(http://nsm04.casimages.com/img/2010/11/02//101102101817535047045701.jpg)
(http://nsm04.casimages.com/img/2010/11/02//101102101844535047045703.jpg)
(http://nsm04.casimages.com/img/2010/11/02//101102101911535047045708.jpg)
Under I have stick a board the aesthetics
Bye
PS adress of plans
Post by: Abfil on November 05, 2010, 07:45:38 pm
good evening
I show you, now, the built of the stern. It s enough difficult to do. I use a lots of pieces.
(http://nsm04.casimages.com/img/2010/11/05//101105082157535047061320.jpg)
I start by pose the low part
(http://nsm04.casimages.com/img/2010/11/05//101105082208535047061322.jpg)
(http://nsm04.casimages.com/img/2010/11/05//101105082248535047061328.jpg)
Then I make the block at port and  starboard
(http://nsm04.casimages.com/img/2010/11/05//101105082300535047061329.jpg)
After I stick a piece in forme of U. It's the outline of the sun mattress
Bye
PS adress of plans
Post by: steamboatbob on November 06, 2010, 11:51:53 am
fantastic build mate hope it all goes well for ya :-))
Post by: Abfil on November 08, 2010, 07:54:59 pm
Hi guys
This is the continuation of stern
(http://nsm04.casimages.com/img/2010/11/05//101105082312535047061330.jpg)
(http://nsm04.casimages.com/img/2010/11/08//101108084056535047081576.jpg)
Pose of the base of the staircase
(http://nsm04.casimages.com/img/2010/11/08//101108084110535047081600.jpg)
stick flask of staircaise
(http://nsm04.casimages.com/img/2010/11/08//101108084124535047081601.jpg)
beginning of pose of stern
(http://nsm04.casimages.com/img/2010/11/08//101108084136535047081602.jpg)
Bye
Philippe
(http://nsm04.casimages.com/img/2010/11/08//101108084159535047081605.jpg)
Post by: Abfil on November 09, 2010, 07:49:09 am
Hi guys
Bye
Philippe
Post by: Abfil on November 13, 2010, 05:42:47 pm
hi
I have just finish the stern !
(http://nsm04.casimages.com/img/2010/11/13//101113064237535047109627.jpg)
Every piece of wood have been sand for his place ! I do still the step of staircase
(http://nsm04.casimages.com/img/2010/11/13//101113064250535047109628.jpg)
 the result ! I m enough satisfied
Bye
PS adress of plans
Post by: Abfil on November 17, 2010, 03:19:24 pm
hi guys
now I begin the cockpit . I start by floor and faces. After I cut pieces of roof. And for finish I start the pose of board
(http://nsm04.casimages.com/img/2010/11/17//101117123531535047133474.jpg)
(http://nsm04.casimages.com/img/2010/11/17//101117123545535047133475.jpg)
stick of all pieces of cockpit and roof
(http://nsm04.casimages.com/img/2010/11/17//101117123651535047133477.jpg)
 stick of wood rod
(http://nsm04.casimages.com/img/2010/11/17//101117123815535047133478.jpg)
 Pose of the biggest board of roof
(http://nsm04.casimages.com/img/2010/11/17//mini_101117123827535047133479.jpg)
Practically all the boat is equipped
Bye
Philippe
PS adress of plans
Post by: Abfil on November 30, 2010, 10:21:11 am
Hi !
The work go slowly, it's more difficult now. I stick boards of roof and outside face of cockpit. A lot of surfaces are convex. I need many pieces.
(http://nsm05.casimages.com/img/2010/11/24//101124064328535047184568.jpg)
(http://nsm05.casimages.com/img/2010/11/24//101124064341535047184569.jpg)
(http://nsm05.casimages.com/img/2010/11/24//101124064415535047184570.jpg)
(http://nsm05.casimages.com/img/2010/11/24//101124064443535047184571.jpg)
Bye
Philippe
PS adress of plans
Post by: Abfil on December 19, 2010, 06:31:11 pm
Hello everybody
This is the last progress on my boat. I just finish the top of cabin.
(http://nsm05.casimages.com/img/2010/12/19//101219072741535047337166.jpg)
(http://nsm05.casimages.com/img/2010/12/19//101219072839535047337184.jpg)
(http://nsm05.casimages.com/img/2010/12/19//101219072853535047337185.jpg)
Bye
Philippe
PS adress of plans
Post by: gwa84 on December 19, 2010, 10:19:26 pm
just so excellent work im loving watching this come together cant wait to see a finished ship sailing away
Post by: Abfil on January 08, 2011, 04:35:55 pm
Hello guys
I make the windscreen with pieces of wood.
(http://nsm05.casimages.com/img/2011/01/08//110108053314535047438276.jpg)
It's very oblique like that the boat is more sport. It go faster  {-)
(http://nsm05.casimages.com/img/2011/01/08//110108053329535047438277.jpg)
At this time the two main pieces of boat are built: The hull and the roof and cockpit.
(http://nsm05.casimages.com/img/2011/01/08//110108053359535047438301.jpg)
I can start to begining the arrangement.
In first I assemble sats of sofa,
(http://nsm05.casimages.com/img/2011/01/08//110108053420535047438304.jpg)
then I make all the pillows.
(http://nsm05.casimages.com/img/2011/01/08//110108053432535047438305.jpg)
After I make sideboard kitchen.
(http://nsm05.casimages.com/img/2011/01/08//110108053444535047438306.jpg)
It begin to look like at a cruiser !
(http://nsm05.casimages.com/img/2011/01/08//110108053457535047438312.jpg)
Bye
PS adress of plans
Post by: Abfil on January 20, 2011, 06:16:23 pm
Hello
I  continue the built and I finish the inside of cockpit. The sofa on port, the stage and armchair of driver and the dashboard !
It's a little job, but all thinks are longer to make !
Here are the images
(http://nsm05.casimages.com/img/2011/01/20//110120071240535047502580.jpg)
The stage of post piloting
(http://nsm05.casimages.com/img/2011/01/20//110120071224535047502579.jpg)
The port sofa
(http://nsm05.casimages.com/img/2011/01/20//110120071313535047502582.jpg)
Armchair driver
(http://nsm05.casimages.com/img/2011/01/20//110120071326535047502584.jpg)
(http://nsm05.casimages.com/img/2011/01/20//110120071340535047502585.jpg)
(http://nsm05.casimages.com/img/2011/01/20//110120071355535047502587.jpg)
The dashboard
(http://nsm05.casimages.com/img/2011/01/20//110120071253535047502581.jpg)
Pose to white
Bye
PS adress of plans
Post by: w3bby on January 20, 2011, 09:12:33 pm
Love watching the progress on this build :-)) :-)) :-)) Far more patience and skill than I could ever put into a project O0 O0 O0 Looking forward to seeing the finished boat and the running vids.
Must say I'm surprised by the lack of feedback from the "regular" contributors............
Post by: Abfil on January 21, 2011, 07:40:27 am
Yes me too, but it's like this today. There more people interessing to take then to give .... And I think, a lot of people begin a construction and they are not the patience and experiment. It's seem easy to built a model but we must do the think one after one.
Bye
Post by: samuelmerry on January 21, 2011, 04:16:15 pm
Very nice, I do not build this kind of boat but after the last couple of comments I felt I had to say something!!! ok2
You are clearly very skilled at what you do!
Looking forward to seeing the finished model.
Post by: martno1fan on January 23, 2011, 08:45:18 am
Sory i havent comented for a while but as i said before very nice work,i also like the blue boat did you build that one too  :-)).Keep up the good work.
Mart
Post by: Abfil on January 23, 2011, 06:41:03 pm
Thanks,
Yes, mart,  it's my firt boat, I draw it too, and after I built it. It's name is windstorm 60. It's 1 m longer. There re 2 motors speed 600 7,2v. I propose its plans ....
Bye
Post by: Abfil on February 17, 2011, 05:16:31 pm
Hello everybody
Now, I finish the bath mattresses. And like the pilot seat was too large I replace it by little bench. I also place a little staircase for down in cockpit
(http://nsm05.casimages.com/img/2011/02/17//110217060931535047666148.jpg)
The bath mattresses
(http://nsm05.casimages.com/img/2011/02/17//110217060945535047666152.jpg)
All cushion covered by tissue
(http://nsm05.casimages.com/img/2011/02/17//110217061002535047666154.jpg)
The little staircase
(http://nsm05.casimages.com/img/2011/02/17//110217061016535047666155.jpg)
The bench of pilot
Bye
PS adress of plans
Post by: Abfil on November 25, 2011, 03:28:18 pm
address of plans
http://www.plansbateaux.net/
Post by: turbinecol on December 03, 2011, 09:08:52 am
Wonderful, exceptional work. Especially love the way everything is drawn up on CAD first. Hope you get to start painting it soon. Enjoy that...
Post by: goBulawayo on October 03, 2012, 06:39:36 pm
Wow nice design and superb build, have you finished it?
Wayne
Post by: gebo on November 01, 2012, 11:09:31 am
I have detailed plans of windstorm 45, if some wishes, FREE !
