Technical, Techniques, Hints, and Tips => DC Motors (Brushed) and Speed Controllers => Topic started by: tjones27 on November 18, 2010, 10:42:47 am
Title: Suitable ESC for 600 and 700 size motors
Post by: tjones27 on November 18, 2010, 10:42:47 am
    i know this may seem like a very silly question but i have a graupner 600 8,4V motor and a Graupner 700 Turbo 9,6V motor.
Which is the cheapest ESC i can use to run both of these, not at the same time, and not in the same model.
So that i never have to ask this question again, whats the thing to look out for with the motor to decide which ESC i need to use with it.
is it the current drain at max efficiency, or the current when stalled?? or what else??
Many thanks
Title: Re: Suitable ESC for 600 and 700 size motors
Post by: nick_75au on November 20, 2010, 03:33:17 am
It depends on the prop, you should aim to use a prop so the motor so its running at max efficiency, though you can go a little higher in amps towards the "maximum power" rating.
you should never need an esc that exceeds the stalled rating of the motor for a boat, a fuse in the battery positive wire rated less than the ESC rating is recommended.
gear reductions enable larger props to be used
Nick
Post by: rathikrishna on December 21, 2010, 06:13:41 am
Hai respected friend...you must try this at home...its my home made speed controller..ith no expense...and can try here this link as i posted a detailed instruction here in MBMH...http://www.modelboatmayhem.co.uk/forum/index.php?topic=27882.0 and an instructional video here...http://www.youtube.com/watch?v=SS3gkDgQSz4  so try it  and make your crafts even more versatile..with your own ideas....have a nice craft...
