The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: Kmot on November 19, 2010, 05:01:34 am
For anyone who knows:
When constructing a copper boiler, is it recommended to use the same thickness material for the end caps as the thickness of the boiler body?
Or is it a non critical issue?
I have 3" diameter Type L copper pipe which is .090" nominal thickness. I can get copper sheet in 14 gauge at .095" or 16 gauge at .065". The thicker the copper the harder to work it into some domed caps. I was hoping I could just use the 16 gauge for the end caps.
Thanks!
As a person working in boilers for years, I myself would use the same thickness bulkheads as the copper tube.
You can always machine some mandrels and heat the thicker copper sheet, then compress the mandrels tight in a hydraulic press, made from an inexpensive jack.
Giovanni
Thanks for the advice John. :)
If you can't find the same thickness then dish the ends outwards which is the strongest form of boiler end caps, and stay it with a decent size (at least 5/32") bronze stay.
Greg
Don't go searching too hard Kmot, you've allready got some material the same thickness as the tube? It's called "The Tube" (Slit and flatten a piece). On the "Other" forum in the books section, there's a freebie download of Hariss's Bible, that's the one everyone should be following for the pressure calcs.
Regards Ian.
Oooooooooooops, nearly forgot, ANNEAL regularly, saves tears (The crying ones)
Hi kmot...nice to see you here too :-))
Sergio
Thank you all, for the replies. Re: cutting off a piece of tube and slitting, etc. Nope, sorry Ian, that would end up making a very short boiler! {-)
Anyway, per most advice I have placed an order for a piece of .093" sheet. (I was wrong about it being .095).
I have Stan Bray's book and I intended to make a domed hardwood form, and pound the annealed piece of sheet over it. Re-annealing as I work it. However, I very much like the idea of sunworksco about making a mandrel and using a hydraulic bottle jack. I will have to think about that some more.
Hi Sergio! ok2
