Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: sunworksco on December 02, 2010, 01:02:01 am
Here are some images for hacking a Robbe F-14 Navy radio with a Hitec 2.4GHz RF module.
Only use the PPM, + & - terminals.
Only use the factory antenna connector on the RF module PBA.
Do not use the terminal strip, that is indicated on the RF module image, for the antenna cable connection.
I am using a generic 2.4GHz antenna. The antenna cable plugs directly into the RF module PBA.
I'm also using the Jeti TU2 switch and wiring harness to plug into the Robbe PBA.
I will post more when the RF module hack is finished.
Thanks,
Giovanni
