Mess Deck: General Section => Chit-Chat => Topic started by: pip jones on December 21, 2010, 02:04:59 pm
Title: steam boiler for stuart triple
Post by: pip jones on December 21, 2010, 02:04:59 pm
can anyone tell me if there is a boiler made to suit the stuart triple. it must produce about 4lbs steam per hour at 150psi, and i am struggling to find something suitable. regards, pip jones.
Title: Re: steam boiler for stuart triple
Post by: derekwarner on December 21, 2010, 07:06:30 pm
pip....talk with mailto: [email protected]   boilers....his largest boiler [6" horizontal] is listed as follows...I would suggest you simply confirm your intended engine as your specification requirement [4lbs steam per hour] is questionable .....Derek
______________________________________________________________________________________________________________________________________________________________________
Diameter 6 " (150mm)
OA Length (including burner) 11.5" (290mm)
Length of pressure vessel 7.5" (190mm)
Flue tube diameter 2 X 2" (50mm)
Number of cross tubes 10 in each flue
Number of longitudinal stays 9
Outer shell thickness 10G (3mm)
Approximate total capacity 2.5L
Maximum working pressure 80psi (5.5 bar)
Test pressure 160psi (11 bar)
Weight including burner 5.2kg
Burner (2) diameter 2 " (50mm).
Fuel Butane or butane/propane mix.
2 off 5/16"x32tpi bushes in backhead for water gauge. 1 1/4"x40tpi bush in backhead for pressure gauge.
1 off 5/16"x32tpi bush in boiler top for safety valve.
1 off 5/16"x32tpi bush in boiler top for steam outlet.
1 off 3/8"x32tpi bush in boiler top for steam manifold
1 off 5/16"x32tpi bush in boiler side for check valve
2 blind bushes tapped M6 are fitted in the bottom of the boiler to allow mounting in a suitable cradle.
Measured steam output 1600 cu ins/min (26219ml/min) at 50psi (65/35 mix)Gas pipe diameter 1/8"
Steam Pipe Ouutlet 3/16"
Exhaust pipe diameter 1/4"
Post by: pip jones on December 21, 2010, 11:17:05 pm
thanks derek. the problem is i have been told that the triple will only run efficiently on 120-150psi, and the maccsteam boiler is only rated at 80psi. it will obviously run on this pressure, but not to its full potential. regards, pip
Post by: derekwarner on December 22, 2010, 05:03:01 am
I understand all that pip....but thought Maccsteam may do HP specials .....Derek
Post by: pip jones on December 22, 2010, 07:25:54 am
i must admit i had not thought of that. thanks for the advice, and i will contact maccsteam today and see if they do a high pressure version. fingers crossed. regards, pip.
Post by: HS93 (RIP) on December 22, 2010, 07:41:54 am
Also try they do boilers to order all types
http://www.cheddarvalleysteam.co.uk/
Tim was the boiler maker at Cheddar Models so will probably know what you need.
Peter
Post by: Circlip on December 22, 2010, 07:50:23 am
http://www.westernsteam.co.uk/
 Quality speaks for itself.
Post by: derekwarner on December 22, 2010, 08:05:33 am
Thanks Circlip........I had the name www.western in my favourates listing but couldn't associate boilers
I think it is amazing when we have a female of the species as a qualified & certified boiler builder :-)) .....Derek
Post by: Circlip on December 22, 2010, 12:41:59 pm
She is an ex Cheddar apprentice and is Highly regarded as one of the best Derek. One of hers is in the Philippines.
  Regards   Ian.
