The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: Bernhard on January 09, 2011, 12:47:56 pm
hi...I have Another Friend here in Denmark .Poul....he have starting on this Launch,,hull from UK...where he will have a Cheddar proteus in
I think he needs a much larger funnel- the current one looks very underscale, other than that It's a lovely little launch, the steam plant looks very tidy.
Greg
hmm thanks yes can be? bot it is the one from the proteus,, i think allso it will be looking better with a bigger one............
Easiest way would be to just sleeve the one that is already on with some aluminium or heat resistant plastic tubing- this will keep all the critical tube sizes correct, but will appear bigger to the eye an in scale with the rest of the boat.
Greg
ohh yes good ide,,,Thanks
Another beauty in the making... O0
Bernhard,
What hull is your friend using?
From the photo it looks as though he has trimmed a little off the top of the hull to reduce the height. Is that correct?
Excellent woodwork. Wish I was good enough to turn out work like that. Can't wait to see it finished.
Bob.
Bernhard, you have great buddies; this boat is going to be another great model...i love the details like the brass portholes in the front frame
Have a look at this Bob
http://www.orionmouldings.com/fishingmodelboathulls.htm
.....yes it is this hull Traditional Scottish Fifie 1:12 Scale
.yes he have cut some of the hull....it look alot better ,,and it didn't neat so much ballast in,,,to stay right in the water,,,it will be around 20kg,,,total..........
Thanks for the info on the hull. At 50" that is a lot of boat.
Pity I don't have the room to build one that size.
Currently waiting for my River Queen.
Bob.
hi Bob,,,,,,,The River Queen is a great boat,,,and a nice size to ..not to heavy ,,,i have 2 off them.....I'm very happy fore
Regards Bernhard
hi.......Poul have don some more work on the launch,,,sorry the photo whas to small,,,i will try to get bigger ones,,i dont know how to delay this post,,,,,,,,
Good evening !
Hello Bernard , you are gone for another splendid project. I am planing to built one like yours and now , I have seen that you cut the hull to make it lower (she look nicer) , I am really excited. :-))
Is it what you cut which is shown on the photo? If so, how many ckinks did you cut out (2?) ? It seems that you cut the top (surrounding belt ?) , then an extra piece of hull. Can you explain why?
Also; is there any passage (hole ?) already made to run the shaft for the propeller through the queel ?
Last question: did you ordered it with wood finish paint or did you do it yourself???
Thank you for showing and sparing your talent! :-))
Regards.
Hi......Thanks ..bot . it is my friend Poul there is the builder on this,,,,,, yes it was with wood finish...and it look a lot better now...first he did it...so he didn't neat to much ballast in it,,,he did cut what you see in the photo,,,and came the surrounding belt back ...it is a littel more heavy?,,,and is different than the clinker.no you have to make the Hull your selves,,no problem... i will try to post photos bot they are JPG,,,
Regards Bernhard,,,,,,,,,,
2 more
Good evening!
EXCELLENT! O0
And what a workshop!! :-))
Regards!
Hi........So have Poul don a littel more wood work..and some brass tools and a shootgun,,,
Hi..so is the Boat in the water,
Bernhard, such great detail, Looks GREAT!!!!! :-)) :-)) :-))
