Technical, Techniques, Hints, and Tips => Tutorials & "How To’s" ... => Topic started by: lozvik on March 12, 2011, 01:01:21 pm
hi guys is it at all possible to make a 2 channel transmitter into a 3 ? just want to add a switch to open a trap door
Some you can, depends on the radio, what make and model is it?
acoms techniplus
Anyone know if the Techniplus has a hidden 3rd channel?
would it not be better to buy a cheap 3 channel transmitter
Your right! Have a look at the "Giant Cod" T4U 2.4G radio
http://www.giantcod.co.uk/gianitcod-24ghz-4channel-mode2-transmitter-p-403779.html
http://www.modelboatmayhem.co.uk/forum/index.php?topic=19330.msg188075#msg188075
Nice price! O0
The blurb says it's a mode 2 set. 'The printed circuit board has a tiny slide switch marked “mode 1/ mode 2” which needs positioning accordingly.'
What does that mean exactly, please?
Thanks Al
Its aimed at flyers
Mode 1 Throttle and rudder on the right hand side
Mode 2 these are on the left
The throttle is normally not fitted with a spring return to centre
I am now much enlightened.
Thank you. :-))
Al
