Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: edd_stutt on April 25, 2011, 01:07:25 pm
hello, i am new to all this but i purchased a aqua power 280 and a zebra standard servo zs-s2113,
its connected up to a backup battery pack with 4 aa batteries, this is 2.7 mhz the servo will run from the backup pack but not the main battery from the controller. my controller has a 2 mhz chip it controls the servo but not the motor, the battery is a 12 volt 7.2 ah lead acid, i have power to the controller but the motor will not run from the throttle.
the motor will run when directly connected, its a 8.4v-9,6v high torque high performance super flying model motor.
i noticed the box from the controller says 4 khz, does anyone have any clue as to why the controller is not sending power to the motor? i can however programme the controller using the programme button, all parts were new and supplied by a retailer who stated they will work together. any help would be much appreciated, thanks.
i have found the cause of the problem, it was down to a faulty unit in my rc on the throttle, all works fine now its been replaced, thanks anyway
