Technical, Techniques, Hints, and Tips => DC Motors (Brushed) and Speed Controllers => Topic started by: essex2visuvesi on May 02, 2011, 07:18:30 am
As the title says
I have got loads of the stuff (New I would like to add)... would it be suitable to make a motor water cooling coil?
Perfect I'd say..but a second opinion would be good.
Do you have a brake pipe 'tool' kit? if you know what I mean....when I was messing about with MG's we had a pipe forming thingy..can't remember what it was called now... {:-{
Will work fine personally I use a slighly smaller motor or anything to form the coil.If you use the motor to form the coil you will find that it is slighly loose,tighter the better
Stav
Copper is about as good as you can get for a heatsink, short of putting the motor directly in contact with the wet stuff. You will probably have to anneal the tubing a couple of times to get all the bends in.
I make my own watercooling blocks out of copper sheet for the processors on my computer, keeps it lovely and cool which makes things super reliable- I've never had a system crash in years. :-))
Andy
Stav
you mean one of these?
http://www.carparts-direct.co.uk/home/brake-pipe-flaring-kit
Then yes lol
Then yes lol
Yes, you just need something to form the coil, its easy, sorted I reckon... :-))
Bit of broom handle should do the job :D.... warm the pipe a little and bob is your uncle!
Hello,
I think if you place a Magnet onto your "Copper" brake pipe, you are in for a shock!.
Copper coloured it may be, but its not Copper.
The Pressures involved in a cars brake system are very high, Copper pipe would burst.
John.
Cu-Ni-Ferr, although SOME advertise pure Copper tubing. Only thing to watch is that when bending, don't form kinks that will restrict flow.
Regards Ian.
Hello,
Yes, you can buy Copper tube, but we were repairing Aston Martin, Ferrari, Jaguar, and various Classic cars, each worth a small fortune, we never used the copper stuff!, too much of a risk.
The only time I have used copper tube was for the Oil Feed lines on a 1898 Panhard Levasour, which had next to NO brakes!!.
It had wood blocks on the rear wheel drums only !!.
Most, if not all, modern cars use the Nickel/Copper type of tube.
John.
Regards Ian.
Recall an old plumbers trick of the trade, was to tightly fill the pipe with fine sand and heat whilst bending.
Never tried it myself.
Hello,
John.
I don't think it's the pressure thats the problem but work hardening, copper work hardens and the vibration in the car would cause copper pipe to crack, copper covered steel, the copper is to reduce corrosion.
http://en.wikipedia.org/wiki/Bundy_tube
EDIT
In light of the next couple of commennts and rather than adding more OT posts I looked it up and pressure if 2500 Psi would be a problem, Its just what I was told by the RTA when doing a vehicle resoration a while ago :embarrassed:
Spose it always pays to dig a little deeper, especialy where beaurocrats are involved :P
Nick
I must agree with circlip....a cupro/nickle/ferric alloy is used ....pure copper & nickle are metals with astronomical $...where as the 76% steel content of Cu-Ni-Fe provides a cost effective alternative with the nickle providing high strength & corrosion resistance, & the copper providing malleability & corrosion resistance O0 ....Derek
PS...I would not use the material for a water cooling heat sink......... >>:-( <*< <:(
Pressure is/can quite easily be the reason for NOT using pure Copper. Copper plating is attacked by road salts etc. Citroen, in their infinite wisdom use d to use plastic covered steel tube (1/8" -3mm bore) for their brake and active suspension lines, sadly these used to rot at the ends where the coating had to be removed for the clamping nuts to work. Luckily no-one suggested replacing them with Copper, 2500PSI would have taken its effect.
"There's only one way to kill a mole" Line from a Jasper Carrot performance, same applies to bending tubes successfully. MANY trains of thought but only one is the answer, rolls and a wiper die.
Regards Ian
Even if it's an alloy it's still going to be pretty effective at siphoning off heat, and if he has plenty of it, I would be inclined to at least try it.
sorry... <:( should have explained........or clarified {:-{ about the physical properties of 76% steel Cu-Ni-Fe tubing
1. precision cold bending [die & former] of 76% steel ....Cu-Ni-Fe tubing as used in repettative applications such as the automotive industry as mentioned here is fine......millions of new automoblies have the same fitted every year........
2. 76% steel content Cu-Ni-Fe tubing cannot easly be annealed for hand bending
3. localised heating to cherry red... O0 followed by off hand bending may be OK for one off 90 degree bend...but the results will vary consideribly ;) ....Derek
Hello,
John.
Well there's not much steel in it as a magnet will not stick to it lol
I would just suck it and see- cost owt to experiment, and it's not like you're putting the pipe under any degree of pressure when in use.
thermal transfer test underway with a bucket of cold water and a windscreen washer pump :D
Goodness %%....what are we comparing here?????????????????????????????????????????????????????????????
1. a Kornal Saunders fried duck fillet :P
2. a bacon & egg roll {-) ........
3. a cold tuna sandwich........ :kiss:
if the result you get is as per Essex2visuvesi
"Well there's not much steel in it as a magnet will not stick to it"
Just give it a go.......... O0 %) ....Derek
Has worked on my Tito motors without problems.
the pump is where the problem may arise as some pumps used are not rated to run for long periods but a fuel pump can be used to overcome that problem
Stop being a silly burger Derek
Regards Ian.
{-) Oooooops, fergot the smiley.
The pump is for testing purposes just to give a flow throught the pipe. The boat will have standard water pickups
There seems to be good thermal transfer through the pipe wall as the pipe feels significantly colder to the touch after the pump run for 30 seconds
i have two coils fabricated around my jp 400 motors both of which were made from a peice of COPPER brake pipe , works a treat & didnt cost anything to make ! the brake pipie kits from automec are copper and supplied for classic cars , ive fitted them in most of my longer term classics when new pipework has been fitted , along with stainless steel braided hoses where any flexible joins are required . i even converted my modern escort mk5 van !
Hi All,
Back in the days when we used to use i/c engines in model boats we used to make our own cooling coils from Calor gas tubing which was thin copper tube and bent round a cylinder without distorting. Now as I say this was "back in the days" and I don't even know if it is still available but your local Calor gas depot should know. It was certainly easier and softer to work with than brake piping. No doubt some of the folks on here will have used it and can advise...
Dave.
Aluminium has the same sort of specific heat capacity as copper. Would this not be a useful alternative, if required?
Andy
Bundy is steel pipe with a copper coating on its internal and external surface To give some extra protection
Kunifer a brand name for brake pipe is formed from a 90% copper 10% nickel alloy (known as 90/10)
Haven't we got a bit off topic.
The original question was about copper brake pipe being used for cooling on a model boat motor.
Any metal pipe will be useable as the thermal transfer rate will still be fairly good.
If the pipe is a good tight fit to the motor does it really matter if it is copper, steel or an alloy.
The simple answer is YES it will be fine as long as you have enough turns and cold water passing through.
At a max pressure of about 1/2 Bar or 7psi after the tube gets a bit furred up (if it does).
Party's over <:(
Ah well it was good while it lasted O0 O0
Stil some gems in there just need to find them. :-)) :-)) :-))
I use the aluminium tubing that most model shops sell, crimp one end fill with salt and nice easy tight bends, works beautifully.
I agree make sure you bend it round something of a smaller diameter
Hi all,copper pipe cant be used for brake pipe, it work hardens,it must be annealed after two years of use or it will crack/fracture. It is illegal to use as brake pipe in North America , I would suspect the law is the same in the U/K. What we do use is a special galvanized pipe that has a copper lining to prevent internal corrosion, I make new pipes most every day from this pipe for vintage jags,MG,s & triumphs. The tool we use for flaring the pipe ends is a Picavant tool from U/K it is high quality but expensive,it has dies to fit all the different flare pipe diameters, it is for sale on their web site. Now it will be O/K to use as a cooling jacket on a electric motor.pack it with sand & wrap it around something slightly smaller than the motor, it will do the job no problem. Mick B.
Nope copper pipe perfectly legal in the UK, I've done loads & never had a problem. The burst level is way above what brake line pressure will get to. Automec in the UK make brake kits with copper as well as copper/nickel pipes. http://www.mamut.net/automec/subdet11.htm I've used there brass unions & silicone brake fluid on various cars. Great because no rust....
I have two flaring tools a Picavant one & a cheapy pliers kit, bith do the job.
Hi, TR7V8 while I would agree with you that the copper pipe can take the brake fluid pressure,the reason copper is banned in brake pipes is because it work hardens in a very short period of time( 2 to 3 years) & would have to be annealed at that time to prevent the possibility of fracture. We are not allowed to use the pipe you listed though we of course can buy it direct from U/K. Using it is quite another matter & I for one will not use a copper product as it does not meet our safety standards. Can you imagine telling your customer that every 2 to 3 years he/she must have the brake pipes removed & annealed to maintain their safety margin ??.The brass fittings we do use & they are not a problem, different application, they are in a fixed position & are not prone to vibration. Mick B.
Hope you all have Mot Certs for your boats
I anneal mine every year
After a warm summer sailing they are launched into cooler water come January %% %% %%
PS my boats don't have brakes :-))
Good grief....... i do hope no one ever asks a technical question ;)
Someone will , always do just wait for it I think I got off topic. The copper pipe will work well for a cooling jacket. Mick B.
yep any motor shop will sell you copper brake pipe if you ask for it.
you can even buy brass , but it wont pass mot for some daft reason...
If you already have some brilliant, use it and it will work.
Now even if the pipe that some people sell is copper, or alloy or steel it will still work.
you dont need any particular brand,type or precious metal, anything that wont melt is gonna work.
the more coild the better some say ? but leave a small space and youl get even cooling !!!!!!
the more water that passes through it fast, then obviously the better.
phill
