The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: JR on July 20, 2011, 08:55:53 pm
can anyone point me in the direction where to obtain drawings or books containing dimensions for the construction of marine boilers.
I might be able to help, what steam engine do you have in mind and what heating method are the first questions, followed of course by what sort of hull are you going to put it all in ?
I might have the drawing you need (failing that I'll draw one up for you)
There are also a few books aound
Model Stationary and marine Engines by K N Harris
Making Simple model Steam Engines by Stan Bray
Model marine Steam by Stan Bray
High Speed marine Steam by A A Rayman
To name just a few, available from Tee Publishing www.teepublishing.co.uk
Hope this helps
Phil
He needs "Model Boilers and Boilermaking" by Harris Phil.
Regards Ian.
See I knew I would forget one {:-{
Check your PM's JR
Regards Ian.
Copied from RC Groups-
Here is a short list of Books.
(Maybe not so short ;<)
K.N Harris's book Model Boilers and Boilermaking.
(This one is almost considered the Bible among Boiler Makers)
Found online PDF copy:
http://www.fastonline.org/CD3WD_40/JF/424/19-422.pdf
"Model Stationary and Marine Steam Engines" by K.N.Harris
http://www.fastonline.org/CD3WD_40/JF/424/19-423.pdf
Building Simple Model Steam Engines
Books 1 & 2
by Tubal Cain
Making Simple Model Steam Engines
Model Marine Steam
by Stan Bray
Another Article/book to add,
Safety of Copper Boilers by Kozo Hiraoka this nine page article was first in Live Steam & O.R. (Vol. 40 No. 6 Nov-Dec 2006) and is included in Building the New Shay.
Introducing Model Marine Steam
By John Cundell and Jim King.
Model Making 1919 Edition
By Raymond Francis Yates
Also
Boys' Book of Model Boats
http://www.gutenberg.org/files/29064...-h/29064-h.htm
Well to branch out into plans here is a link with lots of plans including Elmer's Engines;
http://www.john-tom.com/index.html
From mogogear
I found this compiled list of Steam engine and boiler books that have been scanned into use by Google-- there are links to a pdf file on each book.
Enjoy the over 100 books on this brad subject
http://stommel.tamu.edu/~baum/google-steam.html
Scale Model Steamboats - by Phillip Vaughan Williams
For those who want to really move along.
"Experimental Flash Steam" by J.H.Benson and A.A.Rayman.
Bogs Book
http://hotfile.com/dl/65130144/d7e33..._book.exe.html
More plans They are in French but very buildable
http://jpduval.free.fr/Plans_moteurs_vapeur_p1.htm
The Oscillating twin cylinder engine is very popular.
This link applies more to full size equipment than models, but does cover steam basics;
http://www.pipingnews.com/steam2.htm
Gerald.
