Mess Deck: General Section => Model Boating => Topic started by: Patrick Henry on August 17, 2011, 07:54:37 am
Title: Quick question chaps...
Post by: Patrick Henry on August 17, 2011, 07:54:37 am
I need to charge this battery pack...six sub-c cells, 7.2v 1600a/h
(http://s1.postimage.org/2ow2gw9z8/17082011114.jpg) (http://postimage.org/image/2ow2gw9z8/)
With this charger...variable output.
(http://s1.postimage.org/2owknt3es/17082011115.jpg) (http://postimage.org/image/2owknt3es/)
The charger has the following outputs marked on it: 50-80-120-180-240-300
What would be the best setting to put the charger on to recharge the battery pack? Anyone assist me with this?
Thanks chaps,
Title: Re: Quick question chaps...
Post by: MikeA on August 17, 2011, 09:27:39 am
charge it at 300 i say!!
battery calc says 6.4 hours, which makes makes thats 6 hours 24mins!!
http://www.greenbatteries.com/batterycalc.html
Post by: Patrick Henry on August 17, 2011, 09:30:34 am
Ta Mike...I'll wind it up a bit then.
(interesting link, by the way...)
Post by: malcolmfrary on August 18, 2011, 12:12:47 pm
Assuming that the numbers are mA, then 120 for a very safe long charge, 180 for a fairly safe long (but not quite as long) charge.  Full whack if you intend and manage to keep a close eye on it toward the end of the charge time.  Battery is a 1600mAH, 1/10 of that is 160mA, so 10 hours at that plus a bit for luck, i.e. overnight.
