The Shipyard ( Dry Dock ): Builds & Questions => Any Other Builds => Topic started by: micknjen on March 15, 2007, 03:34:14 pm
just afew picks of my 14cell hydro
WOW !!!! now that's nice
Can we some details of motor, esc, shaft etc
Richard
looks awesome what does she handle like, i bet you have problems keeping it on the water.
hi speedcontroller is a astec mhf2 120 amp 12-30 cells motor is a Graupner BB700 8.4 turbo the boat is fast and stable i think the hull
will take a lot more power something to try a a later date . the shaft is A complete direct drive unit consisting of motor housing and mount, shaft with 4mm (5mm for 800 unit and 3/16 dog drive for the super long 550mm version) threaded end,brass or alloy(3291)outer tube with bearing and teflon thrust washer, appropriate coupling and mounting hardware. The motor housing has a flange that will screw down to a wooden mounting block - captive nuts and screws are provided. Alternatively a mount that goes over the shaft can be made. The unit shaft outer is removeable and can be cut down. There is a small amount of length adjustment available. The installation is completed by cutting the inner shaft to length to suit.
Hi Mike!
Good to see you are still into the fast electrics. Great looking boat, who did the paint job?
Cheers,
Ian.
8)
hi ian the hull comes like that from astec going to try and get up to brid later in the year for a weekend see you soon
Hi MIke,
let me know when you are coming and we'll meet up. You can see what's on at the lake on our website......you know which one.
Cheers,
Ian.
(Regards to jenny)
8)
Hi Ian nice to hear from you hope to catch up with you and george later in the year
Love Jennie
