The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: olly49 on October 27, 2011, 10:23:55 pm
Title: which wood to build a Swordsman?
Post by: olly49 on October 27, 2011, 10:23:55 pm
Hi to all.
It's been along time since I built a boat like this.
So there are two minds of thoughts, should I build in from balsa or like my old Huntsman out of ply.
If ply, should it be out of marine or lite ply?
Can someone please advise?
Many thanks
Olly49
Title: Re: which wood to build a Swordsman?
Post by: HS93 (RIP) on October 27, 2011, 10:33:27 pm
what size of boat are you building
peter
Post by: gwa84 on October 28, 2011, 12:33:21 am
prsonaly i would go with liteply  2resons ease of cutting and working with and lightness  :-))
Post by: MikeA on October 28, 2011, 03:04:36 am
i allways use light ply. Thin but strong.
Post by: Peter Fitness on October 28, 2011, 05:08:43 am
I use a lot of 1/16 ply in my models. It doesn't have to be marine grade, but it does need to be thoroughly waterproofed - I use fibreglass resin inside and outside the hull. Rubbed down with wet and dry paper (used wet) it gives a good finish for paint, undercoat first then top coat(s).
Lite ply is good too, but it needs quite a bit of filling to hide the grain.
Peter.
Post by: LarryW on October 28, 2011, 09:53:28 am
(http://s4.postimage.org/k4ldsb9tl/swordsman5.jpg) (http://postimage.org/image/k4ldsb9tl/)
    HI,  this one of mine was built with lite ply  , strong and easy to work ,     takes all paint finishes ,      LARRY....
Post by: olly49 on October 28, 2011, 10:35:13 am
Many thanks for all replies.
It's the 36" version, so what size lite ply to use and where.
The hull would this be horizontal or
vertical skinned? using lite ply and what size?
Post by: MikeA on October 28, 2011, 10:46:32 am
for that size i would use 2mm but thats my preference.
Post by: derekwarner on October 28, 2011, 01:48:54 pm
olly49  :D ..laminated ply....be it 1/16" lite or 2.0 mm marine grade will provide a superior material to bend & [plate] the shape for a hull  O0
This ply material also has far greater parent material strength over balsa.......... :-)) ....Derek
Post by: F1 madness on October 28, 2011, 04:40:12 pm
as the others have said lite-ply,heres the best place to purchase it and comes in various sizes and thickness's
http://www.slecuk.com/catalogue/Wood.html
