The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: Tombsy on January 24, 2012, 11:41:25 pm
Title: Aquacraft VS1 tunnel FE conversion
Post by: Tombsy on January 24, 2012, 11:41:25 pm
I thought I'd show a few pictures of my VS1 conversion. I'm using an O.S. lower and an Aquacraft 2300kv motor with adapter, a Turnigy 120 amp esc and Nanotech 4s 5000mah batteries.
This is what I'm starting with a nitro powered VS1 that I've raced for a few seasons but it's still in pretty good shape.
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0276.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0275.jpg)
The hull was stripped and the fuel tank removed then the deck cut out for the new battery box.
(http://i4.photobucket.com/albums/y126/Pescador58/Hullcut.jpg)
New pieces cut out and brass for sealing the wire and cables.
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/VS1pieces.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/VS1brass2.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0312.jpg)
Test fitting the motor and esc for steering cables, motor wires, and cooling tubing.
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0326.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0320.jpg)
Hitec waterproof digital servo and steering cables.
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0329.jpg)
Ready for clear coat and pexi lids for both compartments.
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0335.jpg)
Title: Re: Aquacraft VS1 tunnel FE conversion
Post by: Tombsy on January 30, 2012, 06:56:02 pm
Not much interest but here's a pic of it all back together, 2 coats of West Systems inside and sprayed with 2 coats of Klass Kote epoxy on the outside. Hopefully that should keep it watertight. The motor wires and steering cables are sealed to the brass with heat shrink tubing. I still need to trim the back of the cowl to clear the motor wires.
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0340.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0341.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0345.jpg)
(http://i4.photobucket.com/albums/y126/Pescador58/RC%20Vehicles/Aquacraft%20VS1%20FE%20conversion/IMG_0348.jpg)
Post by: NigelW on February 01, 2012, 09:40:25 am
Looks nicely engineered. Are you going to make a motor cowl for it?
Nigel
Post by: Tombsy on February 01, 2012, 09:41:40 pm
Thanks, they don't usually use engine cowls for racing these but it would look pretty good.
Maybe I can modify one of the ones from the Proboat Stiletto to fit.
