Technical, Techniques, Hints, and Tips => Batteries & Chargers => Topic started by: comtoray on February 07, 2012, 12:36:32 pm
Can i get a fast charger to charge 8, 2600 NI-MH batterys at once thank you :-)
This one charges eight AA batteries at one time.
http://www.duracell.co.uk/en-GB/product/multi-charger.jspx
This one does four AA batteries in15 minutes.
http://www.duracell.co.uk/en-GB/product/15-min-charger.jspx
Thank you Dicky, im having one of those i appreciate it cheers...Ray :-))
7 day shop.com
do a battery charger which charges 8 at a time too, it'll work of a car ciggy lighter and mains 240 volt
there were on offer recently at only £ 9.99 covered in their branding....- dont know if they still have them or not ?- i know rc component store sells the same item too but with 'vapex' branding on it
http://www.component-shop.co.uk/html/vte8000.html
7 day shop.com
Guy I have one of these from 7dayshop.com but they are not on their web site anymore, they only have the four battery types. :-))
are they sub C size ? if so you can use any of the buggy car Fast chargers
Peter
Although its possible to fast charge this type of battery. I would like to know how much it shortens their life by? How hot is too hot? As batteries are cheap would it be better to have a spare set and rotate as required. John.
Any Ni-MH battery not specifically designed for high discharge/charge should not be fast charged if you want many cycles.
Basically any size other than Sub C batteries for buggies fall into this category.
The best charge for a high cap. Ni-mh is a 1/10 C for 12 -14 hours.
So john S's suggestion of a spare set makes sense.
A suggestion for a charger, get a 4 button smart charger, there are many brands but all of them can charge nearly any battery you can throw at it and with the correct type of charge for that battery.
Nick
If the charger is to charge your transmitter batteries, why do you need a fast charger?.
Modern Radios run for ever on one set of 2600 NiMH cells.
My T4U is good for a few visits to the pond (8 Cells) and my Spektrum
(4 Cells) is even better.
Get a 4 - 8 Cell Delta Peak charger and plug your TX in on return from the lake
and you will be ready for the next outing.
You will get tired before your batteries!
