Technical, Techniques, Hints, and Tips => Batteries & Chargers => Topic started by: bikerdude666 on February 23, 2012, 12:00:07 pm
If I were to use cells like these: http://www.component-shop.co.uk/html/single_cells.html is it a case of simply solder wire from 1 cell to the next, and the put a tamiya plug on it? And would i just use the same charger as i use for my nimh stick packs?
YES
Barrie
As long as the charger volts out is slightly higher than the combined cell voltage
Component Shop will make you up any combination -a lot less hassle
use my charger for 7.2V and it's another 7.2V pack that I want. How do you find out about them making up any pack you want? i can't see anything about it on their site, and the pack would need to be a certain shape split cell pack.
... and I came here looking for a discussion on electrochemistry.... <:( <:(
best I can do is a potato clock :D
Send them an email showing what you need they do any amount of different combos or
put' made up packs' in the search box
Potatoes are not rechargeable and dont solder well
what you need is Battery bars and a very big soldering iron you have to be quick soldering you can also get a holder to hold them when you soder ids it is sub "c" you are going to use
http://www.modelsport.co.uk/schumacher-gold-battery-bars-pk5-/rc-car-products/30689
http://demonpowerproducts.co.uk/product_info.php/venom-ven-1599-battery-assembly-jig-p-2637
there are cheaper battery rigs
Peter
You can also buy large diameter heat shrink to cover your pack with. John.
