Mess Deck: General Section => Beginners start here...! => Topic started by: jacko69 on April 18, 2012, 10:39:54 am
hi i have just got a really old restoration 34inch huntsman made out of wood,the problem i have is trying to locate all the detail parts like the bow rail rear ladders roof rails and the list goes on can anybody help me locate theese parts.
You just have to make then !!!
Timo2
http://www.modelboatmayhem.co.uk/forum/index.php?topic=4645.0
Timo2
cheers guys looks like im going to have to put my woodwork skills into practice evan tho they aint that good.
aint there a company who makes a detailing kit for this boat.
Not as far as I have found as I'm looking as well
im sure sombody told me you can buy a kit for around £70 for it but i cant remember who it was.
hi - this Company do the kit so may be worth a phone call or an email :-))
http://www.angliamodelcentre.com/index.php?cPath=8_66_68
aye
john
:-)) thanks bluebird just got off the phone to them they are going to do a detail kit for the huntsman for about £10 -£15 dont think thats bad got to ring back tomoz to find out what they are putting in the kit will post on here as soon as i find out once again cheers mate
dave
dave
Please do as I'm interested in one as well
just keep your eye on this thread mate will list all parts what comes in the kit.
what engine you running in ya boat essex.
Not started the build yet but I have been ammassing parts:-
1000kv 4240 Brushless outrunner
200A Water cooled ESC (Went for the biggest as Chinese amps are known to be smaller)
2x 6S 2800Mah lipos giving 5600Mah (left over from my trex 500)
4mm Balraced prop, with oiler
Futaba metal gear rudder servo (was the tail servo on my Caliber 3 helicopter)
A selction of plastic 2 and 3 blade props from 30 to 45mm
ive not managed to find many off the shelf detail parts for my own pair , hence have been making my own
(http://s10.postimage.org/6et58arph/097.jpg) (http://postimage.org/image/6et58arph/)
both models use the grp hull , but have the cabins permently attached with removable sections for acsess to motors , control equipment and batteries !
Just a quick post so I can find this thread easily, I would also be interested in the contents of the "fittings kit" before I start on mine.
( Request to Martin for a "watch this thread" button on the forum :} )
( Just found a "Notify" button might try that ! )
HawkEye
wondering what a detail kit will contain for between 10 & 15 pounds ? what fittings are people looking for ?
right i have spoken again to anglia models he has asked me what people would like to be put in the detail kit so your feed back would be very helpful.
i have asked for theese items.
bow rail
cabin rails
cleets
rear ladder
anchor and chain
steering wheel
lamps
so if you can think of out else please let me know thanks.
dave
then you could add , morse controls , dash clock set , pulpit / pushpit , stanchions . both types of air scoops , laser cut window frames , cockpit screen frame , mushroom vents etc all dependant what they are proposing to make these fittings from ? personally i dont like the white metal stuff thats available so wont use it , hence ive made most of my own parts including the polished alloy air scoops on my 31 ! jon
Red181 has a very nice Huntsman - he can also supply nice custom made air scoops.
I can't find the sales post to show you (it was there pre meltdown) - Try a PM - maybe he will still do them.
His scoops are too big for this kit... he has the 48" model
What planking do you guys reccomend for the deck?
mine is also the 34 inch version , my deck is laid with 5mm wide teak strips
Mine's the Precedent 34" but it's a total wreck at he moment.
Thought I'd mention that I really liked the Walnut I used recently.
i have used lollie sticks looks quite good if i say so myself
I have just dropped the window frame parts off to be recut by cnc in light alloy and then polished (Local machine shop owes me a favor lol)
If they turn out OK and there's any interest in these then Ill see about getting a few sets made up
Also does anyone know where there is a good supplier of suitable deck furniture?
Sorry for Hijacking Jackos thread but I thought that the information is relevant to his build as well.
Ill start a build log this evening as I have started putting mine together
what is the distance from the transom to the propshaft entry point?
Using PM devlins settings of 23mm from keel to prop and prop 110mm from the transom
depending on your set up i did post on the other thread ( spearfish requirements ) a week or two ago a full set of dimensions for fitting both the propshafts and rudders through the hull , my own models are twin shaft , & the motor/s are fitted in the same position as they would be on a full size fairey huntsman 31 / spearfish
Thats great thanks...
is the 30mm from propshaft to hull skin measured from the centre of the propshaft or the top? my proptube is 8mm in diameter so its a 4mm difference
i normally measure from the centre of the propshaft , to the hull skin .
I thought so but just wanted to double check
The precident instructions are a little sparse when it comes to the prop shaft install
note , my shafts are much shorterthan the original precedent recomendation , my motors are below the open cockpit , ive opened the section behind the air scoops on the cabin sides and made some internal ducting which forces a small amount of air down towards the motors ,
dave
Is there any update to add to this thread yet jacko, waiting in anticipation :-)
HawkEye
Maybe some pix too please?
