The Shipyard ( Dry Dock ): Builds & Questions => Yachts and Sail => Topic started by: JerryTodd on July 06, 2012, 04:49:36 pm
I started a thread on the Macedonian here, but that models has been set aside for the moment as I try to complete another. The other, being a schooner, and therefore simpler in rig and it's amount of detail than a frigate, I hope I would have a chance to complete - and sail. I also live near Baltimore and it's the 200th anniversary of the War of 1812 in which Baltimore played a prominent role. In consideration of the readership here, I won't dwell on that unfortunate spat between cousins.
This model is of a boat whose construction I worked on in late 1976, then crewed on in 1981. For the bicentennial of the Battle of Yorktown I was specifically hired because I had square rig experience and black powder cannon experience. I acquired a copy of the plans in 1982 from the designer, and started a 1:32 scale model back then, but that was destroyed in one of many moves. This model began in earnest in September of 2011, actually started before Macedonian. It is 1:20 scale giving it the following dimensions:
- Hull length: 54" (137.16cm)
- Length on deck: 48" (121.9cm)
- Length on waterline w/o rudder: 46.75" (118.75cm)
- Length over the rig: 81.5" (207cm)
- Beam: 13.625" (34.6cm)
- Draft without ballast keel: 5.875" (14.9cm)
- Total height (top of jack-yard to bottom of keel): 61.6" (156.5cm)
- Total Sail area: 2,049.13 square inches in 7 sails as shown above, 2,205.13 with the flying jib.
(http://s17.postimage.org/z7ik7tbaj/sailplan.jpg) (http://postimage.org/image/z7ik7tbaj/)
The real vessel was lost in a squall North of Puerto Rico in May of 1986 taking her captain and three of her crew with her. This model is something of a memorial to them. I can't see it without remembering them, and I hope that will be true for others that knew them and the boat.
November 2010: The plans were scaled up to 1:20. The patterns were drawn in Paintshop Pro v.7 and printed on the plotter. These were pasted to 3/16" plywood and stood on the build-board.
(http://s8.postimage.org/nqafhsrz5/pri20101113a.jpg) (http://postimage.org/image/nqafhsrz5/) (http://s8.postimage.org/xz2wnmg0x/pri20101113b.jpg) (http://postimage.org/image/xz2wnmg0x/) (http://s8.postimage.org/e75c22tup/pri20101113d.jpg) (http://postimage.org/image/e75c22tup/) (http://s8.postimage.org/hmsuxw1pd/pri20101119c.jpg) (http://postimage.org/image/hmsuxw1pd/)
October 2011:: After letting the forms season for a year, ok2 a keel was cut and planking began. The model is planked in 1/8" thick white pine.
(http://s8.postimage.org/56w5458dd/pri20111008a.jpg) (http://postimage.org/image/56w5458dd/) (http://s8.postimage.org/l3ux0v0rl/pri20111009l.jpg) (http://postimage.org/image/l3ux0v0rl/) (http://s8.postimage.org/a2zrvu8ip/pri20111021l.jpg) (http://postimage.org/image/a2zrvu8ip/) (http://s8.postimage.org/lqttqdxnl/pri20111031a.jpg) (http://postimage.org/image/lqttqdxnl/) (http://s8.postimage.org/vmuwq13fl/pri20111031j.jpg) (http://postimage.org/image/vmuwq13fl/)
November 2011:: The planking was completed by Halloween. An attempt to take a glass hull off this one as a male-mold was botch. The forms were removed and the inside coated with resin. Then the outside got a layer of 3oz glass cloth.
(http://s8.postimage.org/6sbevyild/pri20111103h.jpg) (http://postimage.org/image/6sbevyild/) (http://s8.postimage.org/d4qk5slnl/pri20111120i.jpg) (http://postimage.org/image/d4qk5slnl/) (http://s8.postimage.org/j49pvph29/pri20111225a.jpg) (http://postimage.org/image/j49pvph29/) (http://s8.postimage.org/d22357sm9/pri20111225b.jpg) (http://postimage.org/image/d22357sm9/)
March 2012:: The prop notch was cut in sternpost and a daggerboard trunk for fin keel was installed. The fin is 1/8" aluminum sheet that will get a lead bulb of about 12-15 pounds attached.
(http://s8.postimage.org/wve6xx601/pri20120317a.jpg) (http://postimage.org/image/wve6xx601/) (http://s8.postimage.org/upjw3f2jl/pri20120323c.jpg) (http://postimage.org/image/upjw3f2jl/) (http://s8.postimage.org/cy89oyn4x/pri20120323e.jpg) (http://postimage.org/image/cy89oyn4x/) (http://s8.postimage.org/8ntltdi1t/pri20120323f.jpg) (http://postimage.org/image/8ntltdi1t/) (http://s8.postimage.org/77i3b8f4x/pri20120331p.jpg) (http://postimage.org/image/77i3b8f4x/)
April 2012: Installed the wales. Made the motor mount bulkhead. Installed the deck beams and the inner cabin trunk. Put on the fashion pieces on the quaters and then the stern's "fancy pieces." Some paint. The rudder was made of 5/16" Plexiglass with a 3/16 brass rod rudder post drifted to the rudder with 1/16" rods. A copper heel plate is threaded to receive 2 screws that hold the gudgeon plate to the keel. A brass tube goes through the counter to make the top bearing for the rudder post. The lid portion of the cabin trunk was made.
(http://s8.postimage.org/88ic0cw4h/pri20120402f.jpg) (http://postimage.org/image/88ic0cw4h/) (http://s8.postimage.org/5d58ths4h/pri20120405b.jpg) (http://postimage.org/image/5d58ths4h/) (http://s8.postimage.org/u54v0q9b5/pri20120405f.jpg) (http://postimage.org/image/u54v0q9b5/) (http://s8.postimage.org/8u2piq1sx/pri20120405k.jpg) (http://postimage.org/image/8u2piq1sx/) (http://s8.postimage.org/axd4qe1lt/pri20120405o.jpg) (http://postimage.org/image/axd4qe1lt/) (http://s8.postimage.org/yztyl9i8x/pri20120405s.jpg) (http://postimage.org/image/yztyl9i8x/) (http://s8.postimage.org/r5tczvag1/pri20120407a.jpg) (http://postimage.org/image/r5tczvag1/) (http://s8.postimage.org/k1bjqu36p/pri20120407j.jpg) (http://postimage.org/image/k1bjqu36p/) (http://s8.postimage.org/eompcpfa9/pri20120411k.jpg) (http://postimage.org/image/eompcpfa9/) (http://s8.postimage.org/rribvz5i9/pri20120413c.jpg) (http://postimage.org/image/rribvz5i9/) (http://s8.postimage.org/63tdlj541/pri20120414c.jpg) (http://postimage.org/image/63tdlj541/) (http://s8.postimage.org/qmo9qlj1d/pri20120418b.jpg) (http://postimage.org/image/qmo9qlj1d/) (http://s8.postimage.org/619hyp1gh/pri20120420e.jpg) (http://postimage.org/image/619hyp1gh/) (http://s8.postimage.org/ei4evvgrl/pri20120421c.jpg) (http://postimage.org/image/ei4evvgrl/) (http://s8.postimage.org/3owwnczhd/pri20120426j.jpg) (http://postimage.org/image/3owwnczhd/) (http://s8.postimage.org/67ilo1l7l/pri20120426h.jpg) (http://postimage.org/image/67ilo1l7l/) (http://s8.postimage.org/8fws5dsbl/pri20120425d.jpg) (http://postimage.org/image/8fws5dsbl/) (http://s8.postimage.org/fhuprkvxd/pri20120425i.jpg) (http://postimage.org/image/fhuprkvxd/) (http://s8.postimage.org/vethoaobl/pri20120425m.jpg) (http://postimage.org/image/vethoaobl/) (http://s8.postimage.org/ni90g2cv5/pri20120427e.jpg) (http://postimage.org/image/ni90g2cv5/)
May 2012: Four sets of bitts were made along with hatch coamings, the period bilge pumps, and the bowsprit. A mount was made for the rudder servo and speed control in the cabin.
The masts were made of white cedar using the Bird's Mouth method. They got fitted with cross-trees, caps, topmasts, and mast hoops.
The tiller will be used to steer the model as there's no room for linkages, etc, below. A heavy copper tiller was soldered to a collar that attached to the rudder post. The scale wooden tiller covers the copper tiller.
(http://s8.postimage.org/chdvb1km9/pri20120501d.jpg) (http://postimage.org/image/chdvb1km9/) (http://s8.postimage.org/6rxmqqeg1/pri20120504p.jpg) (http://postimage.org/image/6rxmqqeg1/) (http://s8.postimage.org/lzdmb36ap/pri20120509b.jpg) (http://postimage.org/image/lzdmb36ap/) (http://s8.postimage.org/khnklsc69/pri20120511c.jpg) (http://postimage.org/image/khnklsc69/) (http://s8.postimage.org/47xeiw1i9/pri20120511j.jpg) (http://postimage.org/image/47xeiw1i9/) (http://s8.postimage.org/a6b7t4kgx/pri20120513c.jpg) (http://postimage.org/image/a6b7t4kgx/) (http://s8.postimage.org/pdr7dhcbl/pri20120514g.jpg) (http://postimage.org/image/pdr7dhcbl/) (http://s8.postimage.org/qerg2ltb5/pri20120515a.jpg) (http://postimage.org/image/qerg2ltb5/) (http://s8.postimage.org/d9bxwhzfl/pri20120515d.jpg) (http://postimage.org/image/d9bxwhzfl/) (http://s8.postimage.org/z78eqaeg1/pri20120516c.jpg) (http://postimage.org/image/z78eqaeg1/) (http://s8.postimage.org/vmcj729wh/pri20120516g.jpg) (http://postimage.org/image/vmcj729wh/) (http://s8.postimage.org/vxtzjtqch/pri20120517a.jpg) (http://postimage.org/image/vxtzjtqch/) (http://s8.postimage.org/497ccb3c1/pri20120517f.jpg) (http://postimage.org/image/497ccb3c1/) (http://s8.postimage.org/4ltoldfa9/pri20120517k.jpg) (http://postimage.org/image/4ltoldfa9/) (http://s8.postimage.org/alhfp102p/pri20120518g.jpg) (http://postimage.org/image/alhfp102p/) (http://s8.postimage.org/b9qa7yysh/pri20120519i.jpg) (http://postimage.org/image/b9qa7yysh/) (http://s8.postimage.org/69su00t5t/pri20120522g.jpg) (http://postimage.org/image/69su00t5t/) (http://s8.postimage.org/gilb5uh7l/pri20120523d.jpg) (http://postimage.org/image/gilb5uh7l/) (http://s8.postimage.org/w2sowdrc1/pri20120523f.jpg) (http://postimage.org/image/w2sowdrc1/) (http://s8.postimage.org/6iqepy5y9/pri20120524c.jpg) (http://postimage.org/image/6iqepy5y9/) (http://s8.postimage.org/w08t9jnoh/pri20120529b.jpg) (http://postimage.org/image/w08t9jnoh/) (http://s8.postimage.org/8kqw473xd/pri20120530c.jpg) (http://postimage.org/image/8kqw473xd/) (http://s8.postimage.org/jvtjskash/pri20120530g.jpg) (http://postimage.org/image/jvtjskash/) (http://s8.postimage.org/pilbcanxd/pri20120531e.jpg) (http://postimage.org/image/pilbcanxd/)
June 2012: The rudder fairleads that will guide the rudder cables through the sud-deck were installed.
The sails were cut from Dupont Supplex, marked with panel lines, patches, cloths, and tabling glued on with fabric glue; bolt-ropes sewn on, and reef points made.
The gaffs, boom, and other spars were made. "Iron" work for stuns'l booms, ringtail, and the clew iron of the mains'l were made.
Two spools of Dacron sailthread were bought and used to make rope in three diameters to be used on the model.
(http://s8.postimage.org/a8lg53sf5/pri20120601e.jpg) (http://postimage.org/image/a8lg53sf5/) (http://s8.postimage.org/ak2whv8v5/pri20120603a.jpg) (http://postimage.org/image/ak2whv8v5/) (http://s8.postimage.org/fhgh2zau9/pri20120611b.jpg) (http://postimage.org/image/fhgh2zau9/) (http://s8.postimage.org/v1nutikyp/pri20120611g.jpg) (http://postimage.org/image/v1nutikyp/) (http://s8.postimage.org/pnp2lyv8h/pri20120612c.jpg) (http://postimage.org/image/pnp2lyv8h/) (http://s8.postimage.org/6wn5bt0o1/pri20120612d.jpg) (http://postimage.org/image/6wn5bt0o1/) (http://s8.postimage.org/tisgojee9/pri20120613b.jpg) (http://postimage.org/image/tisgojee9/) (http://s8.postimage.org/9mwh8zxcx/pri20120614e.jpg) (http://postimage.org/image/9mwh8zxcx/) (http://s8.postimage.org/n2jhyg5up/pri20120614f.jpg) (http://postimage.org/image/n2jhyg5up/) (http://s8.postimage.org/jhj11hbxd/pri20120626a.jpg) (http://postimage.org/image/jhj11hbxd/) (http://s8.postimage.org/wx61qxkf5/pri20120628a.jpg) (http://postimage.org/image/wx61qxkf5/) (http://s8.postimage.org/4j0m71wv5/pri20120628b.jpg) (http://postimage.org/image/4j0m71wv5/)
July 2012: Began making and installing blocks and other rigging such as foot-ropes on the yards.
(http://s8.postimage.org/ef1p6p2n5/pri20120701f.jpg) (http://postimage.org/image/ef1p6p2n5/) (http://s8.postimage.org/cyq6ojzq9/pri20120701h.jpg) (http://postimage.org/image/cyq6ojzq9/) (http://s8.postimage.org/dzqfdogpt/pri20120703a.jpg) (http://postimage.org/image/dzqfdogpt/) (http://s8.postimage.org/3mvejhpcx/pri20120703g.jpg) (http://postimage.org/image/3mvejhpcx/) (http://s8.postimage.org/yfspnst5t/pri20120705e.jpg) (http://postimage.org/image/yfspnst5t/)
So that's where I am so far. The model is to be displayed at a visitor's center in Baltimore on July 22nd as part of those War of 1812 festivities. July 22nd, it seems, is when the first 7 letter-of-marque boats sailed from Baltimore. She won't be completed by then, but I'm working on getting her somewhat presentable.
The RC side of this is a little in the air. I planned on a continuous loop trolly sort of set up as found in models like Robbe's Valdivia, but I have two notions for handing all this over lapping sail I want to experiment with. Besides that, there's running back-stays on both masts, and running fore-stays on the main mast I want to be operational; plus yard bracing - and there's not really much room inside this hull, which is why I made her 1:20 scale. I wanted her to be 1:36 to fit in with Constellation and Macedonian, but there just wasn't enough room in her at that scale.
Absolutely super Jerry! I'll even forgive you mentioning the war. :embarrassed:
I thought I'd post some photos of the real boat this one's modeled after.
(http://s10.postimage.org/4dqpb89xh/pride81_23.jpg) (http://postimage.org/image/4dqpb89xh/)
One of my babies. First thing I did was toss the waterproof fuse and make up some slow match and linstocks.
I tried to get proper rigging installed, but they would have no such thing - so there were no breechings, retrieving tackle, etc.
(http://s10.postimage.org/he71lelvp/Patapsco198110.jpg) (http://postimage.org/image/he71lelvp/)
Leaving Baltimore for Chestertown, October 1981.
(http://s10.postimage.org/jdj1z2qth/pride81_04.jpg) (http://postimage.org/image/jdj1z2qth/)
On the sail over to Chestertown Maryland.
(http://s10.postimage.org/tc40lk091/pride81_19.jpg) (http://postimage.org/image/tc40lk091/)
(http://s10.postimage.org/6kuxz5f7p/pride81_22.jpg) (http://postimage.org/image/6kuxz5f7p/)
While becalmed on the Chester River in Maryland, the engineer and I took the Zodiac out and I snapped this last picture on my roll.
Note the mian tops'l is not set, and you won't see it set very often till 82 because it was a pain in the tucas to set with it's jack-yard.
Eventually they left the jack yard aloft and ran a cable down to deck; then ran the sail up hanked onto this cable so it looked like it was set on the jack-yard.
(http://s10.postimage.org/66tlzjv45/pride81.jpg) (http://postimage.org/image/66tlzjv45/)
Hauling a$$ into the York River on the way to Yorktown, October 1981. We had just taken in the fore tops'l. The lee rail was under and the gun muzzles in the water up till then.
(http://s10.postimage.org/pts0p5zd1/Pride_of_Baltimore_Yorktown_81.jpg) (http://postimage.org/image/pts0p5zd1/)
Me (upper right) and "Sugar" (far left in the skilt) are the only crew, the rest are reenactor friends of mine from shore.
We fired the guns so much they though we were on fire and sent a fire engine down to the dock. Sugar was a survivor of the wreck in 86.
(http://s10.postimage.org/piakceix1/pacific198212.jpg) (http://postimage.org/image/piakceix1/)
A lovely shot of Pride in the Pacific in 1982.
The model is basically getting jury-rigged so it can be displayed on the 22nd, but some of this is permanent work. The bolt-ropes have been sewn on all the sail, so they are complete. Footropes on the yards, sails lashed to their gaffs, jack-yard, etc. I got some brass belaying pins for Constellation but they were too big - it turns out they're perfect for Pride.
(http://s15.postimage.org/o8hrcm7tz/pri20120706d.jpg) (http://postimage.org/image/o8hrcm7tz/) (http://s15.postimage.org/ij1isb1nr/pri20120710a.jpg) (http://postimage.org/image/ij1isb1nr/) (http://s15.postimage.org/bejpj9uef/pri20120713g.jpg) (http://postimage.org/image/bejpj9uef/) (http://s15.postimage.org/vuq4nrfaf/pri20120714a.jpg) (http://postimage.org/image/vuq4nrfaf/) (http://s15.postimage.org/fmehs0vtz/pri20120714d.jpg) (http://postimage.org/image/fmehs0vtz/) (http://s15.postimage.org/u473m9xrb/pri20120714e.jpg) (http://postimage.org/image/u473m9xrb/)
Well, the event of the 22nd was moved to the 21st, and I was out of town, getting back in time to do the 22nd, but couldn't get back earlier - so - no go.
Anyway, I found the news paper was selling a lot of photos on ebay, many of which were of the Pride of Baltimore, and many of which showed details not on the plans, or visible in what photos I have.
Several images were of the boat when she was hauled in 1979 after suffering damage to her rudder in a storm in the Delaware Bay. One thing I noticed was that the wale didn't fair into the stem the way I did it, but ended somewhat abruptly. There was also a plank covering the seam between the hawse bolster and the wale that I hadn't noticed before - but apparently had been there since she was built..
(http://s14.postimage.org/bdaqg5anh/pri20120723a.jpg) (http://postimage.org/image/bdaqg5anh/)
I bounced all over trying to figure out the pumps, which are not even alluded to in the plans. One photo on ebay taken during the boat's construction showed yard foreman, Fred Hecklinger working on the pumps. I could see the 'V' shaped iron strap that I though was part of the iron straps wrapping the pump heads, was actually separate and attached to the cabin front. I thought the post that held the pump handle attached to this, but it actually it's braced by the 'V' strap and sits on the deck.
(http://s14.postimage.org/4bcsty71p/pri20120724a.jpg) (http://postimage.org/image/4bcsty71p/)
The plans do include drawings for Pride's armament - which bear almost no resemblance to what was actually on the boat. The main battery consisted of four 6 pounders carriage pieces. These were basically scaled down 18 pounders in shape and proportion. I've done scale drawings and now I'm trying to get a wooden gun barrel turned to make a mold from to cast the rest in resin.
(http://s7.postimage.org/yl5uh0uyf/gun.jpg) (http://postimage.org/image/yl5uh0uyf/)
Sorry for the lack of updates, but I'm preparing to move and so haven't been working on the models.
My new home has a garage attached to the house that will be my shop so it's just a matter of getting over there and getting set up again.
It may be a little while, but knocking on wood here, I hope to be steaming along nicely again in a few weeks time.
Well, it's been more than a "few weeks" and I'm still not "streaming" nicely or otherwise. We'll not go into the whys of things here, but...
Pride was taken out to the Chesapeake Bay Maritime Museum's Model Expo back on the 31st of May to be publicly displayed for the first time. Macedonian and Constellation went along too and Constellation actually was sailed in the pool they had set up.
The visitors to my little display were very interested and asked some great questions. They were impressed by the size of the models and that they weren't kits, but were surprised that they were built of ordinary materials available at the local hardware/lumber store.
In preparation for this event, I installed in Constellation a system to test for handling the over lapping heads'ls. It consist of two free moving arms on either side of a sail-arm servo with a pin at the end of it's arm to move one of the free arms when it rotated. This would take in on one sheet of a sail while leaving the other slack, and inversely, slack one sheet before taking in on the other - the way you actually sheet heads'ls when tacking.
This set-up will control all the fore-n-aft sails on Pride, though I may put the main sheet on a separate servo for better balance control.
Attached are images of my display at the Expo, Pride at the Expo, a sketch of the jib sheeting plan, two photos of the test set-up installed in Constellation, and a pic of Constellation sailing in the pool.
Hello Jerry,
Very nice to see you have settled in at your new place.
The models look terrific !.
Good to have you back.
John, :-)) :-)) :-))
I'm glad this was resurrected or I would have missed a great build! Well done sir.
@JerryTodd:
Nice work!
Thank you for an elegant and simple method of handling the sheeting in this situation.
You indicate that is a prototype - one thing I reckon you may run into is some tangling with the uncontrolled sheet. In a slightly similar situation, I have used clear plastic sheet to provide a clear slippery area so the sheet has nothing to tangle with. In this situation you have, perhaps two such areas, one for each sheet with a division between the sheets so they cannot tangle with each other. I have used the clear stuff from blister packs or binder covers, also the stuff that was once used to make the old fashioned overhead transparencies is Ok. The plastic area effectively becomes a "chain locker" for the sheet - it should have nothing to tangle with but itself if that makes sense.
Not sure if I have got across what I meant, but hope this may provide some direction.
I got it ;)
In Constellation's case there's nothing to tangle with (inside the hull), or so I thought, but then I started thinking about it. With the boat heeling, bouncing about, etc, as it sails the most obvious thing for the slack sheet to tangle with would be the servo arm and it's post, and the semaphore arms themselves. I plan to mount a cleat on the semaphore arms to make fast the sheets and make adjustments easier. I made a note to check for this possible issue and your suggestion.
Looking at Pride again I began measuring and figuring out how the control lines will run below decks.
Using two Hi-Tec HS-815BB "Mega Sail-arm" servos mounted on either side of the fin trunk and fitted with my Semaphore Arm Sheeting set-up; one servo will control the heads'ls and bracing the tops'l yard. The other servo will control the fores'l and mains'l sheets along with the running stays for the fore topmast, main topmast, and main stays. Both servos will be fitted with servo stretchers to get the most travel out of them.
Currently everything is controlled by a Spektrum Dx6 with an AR6000 rx, but that will be changed for a Hobby King 6 channel set that will have a sliding pot for the motor control. This Rx has been removed from it's case and will be mounted in a custom case for this model
Let's hope this works....
I cut 4 sticks 6-1/2" long, 3/4" wide, and 3/16" thick from pine.
I tapered and sanded them. They stacked, two each, on a bit of brass tubing as a bushing to keep the pivot holes from wearing larger. A pan-head screw serves as a pivot pin and holds them to a common block so it's all one assembly.
There's a thin styrene "washer" between them and on top, and they sit on a 1/4" Delrin block to lift them over the servo arm.
The block will be screwed to the servo-tray between the two sail-arm servos, one pair facing port, the other starboard.
If they work as good as they look everything
should be fine Jerry.
fine looking kit your making ,looks very interesting ,I need to do something similar ,thanks for showing ..
Here's a photo of the assembly apart so you can see the components and another pic showing the lovely red color the arms got painted as I have a spray can of red paint and nothing much to use it on. :)
Just found this thread. Reading it has made me late for an appointment. Simply superb. :-))
I'm terribly sorry you were late - please don't worry, it'll be here when you get back. :)
The "Other Models" link in my signature takes you to my website which has much more potential to make you even later next time. :)
And thank you all for the kind replies.
I echo those sentiments. Another triumph Jerry.
Great job your doing Jerry, I like when people find problems with scratch builds and come up ingenious solutions :-)) U2
So here's the arms temporarily installed. I have to make attachments for the sheets and paint the mounting block.
Finalizing where the sheets will go through the deck I came up with the following measurements for each sheet's full travel:
Starboard servo:
Fore sheet: 44cm
Main sheet: not measured yet
Port servo:
Fore stays'l: 10cm
Flying jib: 28cm
Jib sheet: 34cm
Tops'l yard brace: 39cm
Jerry
This is a nice build.
Your method of sail control is novel but I can see no reason why it will not work. She will be great fun to sail.
I can confirm this from experience sailing my own Baltimore brigantine. At 1/48th scale it's a lot smaller than your vessel and a little later (1830). The hull lines on these American vessels are quite beautiful, but they do have a deceptively small hull volume.
Send some more pictures to the forum please.
A lovely model Picketboat. How did you deal with the overlapping sails?
One thing I've always noticed with modelers is a penchant for sheeting everything to the center-line. In the case of heads'ls and my loose-footed fores'l, sheeting to the center-line spoils the sail's set when close-hauled; it simply sheets the sail in too much, and reduces it's efficiency. Besides that, the actual vessels, the prototypes, didn't sheet that way, most seldom do. It also makes it more difficult to deal with sail overlap, sharpening the angles that the sheet must be pulled over from one side to the other than would be the case if the sheets went out to the rails as most real vessels do. On real boats even those sals that sheet to the center-line typically have travelers making them self-tending when tacking.
Pride mains'l had a double-ended sheet. This sort of "yoke" in the main-sheet actually keeps it from bringing the boom right to the center-line and works like a traveler. The first inclination to replicate this to some degree in a working model is to anchor one end to the deck, run it through a block on the boom, then through the deck to the servo. This arrangement actually increases the length of sheet the servo has to pull. The sketch shows how I intend to get the basic appearance and function of the double-ended sheet while keeping the operation of the single sheet.
(http://www.modelboatmayhem.co.uk/forum/index.php?action=dlattach;topic=38123.0;attach=162050;image)
Most recently, I redid my entire shop so I could actually work in it without moving half it's contents out onto the driveway, ( that adventure is documented here... http://todd.mainecav.org/dyws/shop201604.html (http://todd.mainecav.org/dyws/shop201604.html) for those that are interested in such matters ). With the shop usable, if not "finished," I decided to set a goal of getting Pride sail-able in time for the model boat event at the Chesapeake Bay Maritime Museum in October. I started on setting up the steering...
Some time ago I set up the rudder servo in the aft end of the main cabin trunk with the idea of using either and arm or drum to pull the tiller from side to side. There's no accessible space under the deck behind the cabin to where the tiller is, and so there's no way to make a hard control system that isn't painfully obvious and spoils the scale appearance (hard system meaning push-rods, etc). Pride used relieving tackle on her tiller much like a small yacht has a tiller extension or length of line to steer against the weather-helm. So the idea was to use steering cables and imply this relieving tackle in appearance.
When I started to rig this set-up, I couldn't get it to work. A cross arm or drum wasn't doing the job and a fore-and-aft arm like I used on my Constellation needed the steering cables to be routed to places I wouldn't be able to access. So I opted to move the rudder servo forward, just behind the foremast. Here I could access it through the the model's 600mm x 140mm main-hatch instead of the 115mm x 170mm cabin trunk. Routing the steering cables forward was pretty straight forward, and though I ran them both to the port side of the hull, I figured the servo's cross-arm set at an angle would compensate for that. The problem was that as the arm rotated beyond a certain point, relative to the last fairlead the steering cables came through, it was moving more sideways than away, and the amount of cable it was effectively pulling dropped off significantly at the last few degrees of rotation. This could be solved, even improved on, with a quadrant of some sort on the servo, but that seemed like too much effort. What I ended up doing was going to my tried-and-true system from Constellation using what I guess could be called a counter-tiller on the rudder servo.
Here's a little video on the semi-jury-rigged steering set-up Pride would up with:
https://youtu.be/9juGl_3XboA (https://youtu.be/9juGl_3XboA)
With the steering basically settled, I ordered a couple of extensions from Servo City, for the servo's cable so it would reach the receiver, and half-a-dozen shaft collars to make a propeller, and to have some spares around. In the mean time I began to work on the fores'l sheeting, which I'll get into in the next post....
PS: I have to say I am not liking the system for image attachments on the forum now. It's impossible (that I can find) to embed the images in the message as I had done back at the start of this topic, the images don't even upload till you post the message, and even in editing, or "modifying," they can't be moved into the text. The "insert image" button is looking for a hyperlink to an offsite image and does nothing with the images uploaded to this site. What happened? It used to work very nicely, as you can see from prior posts in this thread.
To get the sketch into the post, I had to "View Image" in Firefox, copy the image url, and use Insert Image in Modify. That's definitely not going to appeal to anyone.
Hello Jerry,
Well thought out, and very clever too !!.
You have got me thinking.
This coming Winter might see some big changes on my two big yachts.
On Endeavour, I have run "fake" sheeting along the deck, to show where the real boats sheeting ran.
There is now a good chance that it may now become "real" sheeting.
Good to hear from you again !!.
John. :-))
Always good to hear from you as well John.
I've been poking at the fores'l sheeting, but my problem is too much friction - it binds too much for the arm to pull the sail across. With a single screw-eye fair-lead I can pull the sail over with the sheet just laid over my finger, but the sheets route below decks and over to the starboard side to get to the sheeting arms, and both are doubled onto the arms to increase the arm's pull length. Too many places to rub, and screw-eyes make for tight corners, so I'm going to have to make proper blocks, but we'll get to that later....
In the mean time, I made a propeller from a shaft collar and some sheet brass... 1st & 2nd pictures
...mounted the master switch in the front of the cabin trunk... 3rd picture
...installed blocking in the mast partners that hold the masts at the correct rake angle and help against twisting... 4th picture
...installed a "beam" aft to catch the end of the sub-deck there... 5th picture
...and got to making some quickie blocks to use on the fair-leads down below decks. They don't have working sheaves. Some of these will no-doubt get replaced with ones that have working sheaves (probably from some Delrin rod I have), but these will help me get the system in order. 6th picture
On the subject of working sheaves; the lovely blocks in the image down there somewhere, which were sent to me by Mr Victor Yancovitch, will be modified (like the one front-center) with working sheaves for use on the tiller ropes above deck. 7th picture
Another bit of procrastination was framing up the new "engine room hatch." I have a feeling I'm going to widen the main hatch from 5.5" to maybe 8". The last fair-lead for the sheeting arms are mounted near their tips, inside the hull, up under the deck, and will be a real pain to access. That's down the road. Once I get the sheets working, then I'll revisit the idea and determine if it's really necessary; and I painted the inner cabin trunk black. The lid has slit windows on the sides and I colored the inner part with black marker where you could see it through them. I just seemed neater to paint the whole thing. 8th picture
Took all three models to a Model Expo at the Chesapeake Bay Maritime Museum on the 18thPride actually free-sailed for the first time!
My friend Mark sailed his 46 inch schooner Cliodhna (Clee-na) for the first time in the pool at National Maritime Day (May 2022).
He controls the sails with a sort of clothes-line system driven by a winch. A common system in RC sailing models, especially schooners, and what I originally intended to use in Pride.
The winch drives a closed loop and the sails' sheets are attached at points so the loop's travel pulls the sheets the requisite length for each sail. Mark used one loop to control the over-lapping jibs, and the other loop controls all the rest of the sails (the ones with booms basically).
Watching this work so well in the pool, especially with the over-lapping jib, I started rethinking Pride's set-up - again.
(https://modelshipworld.com/uploads/monthly_2022_06/cliodhna.png.5b0f925dc0338c35021ad5a4b41b874f.png) (https://modelshipworld.com/uploads/monthly_2022_06/cliodhna.png.5b0f925dc0338c35021ad5a4b41b874f.png) (https://modelshipworld.com/uploads/monthly_2022_06/cliodhna_sheets.png.2827518bdd6f063b60e55bbeb7b5cb96.png) (https://modelshipworld.com/uploads/monthly_2022_06/cliodhna_sheets.png.2827518bdd6f063b60e55bbeb7b5cb96.png)
I could finish this model if I could work out the controls, and what I was working on I don't think was going to work. Sometimes the first idea winds up being the best idea, with some adjustment,
First off; I already plan to remove the motor. There's no way that that 1 inch prop is going to move all that sail in even against the slightest breeze. The motor will go to the upgrade of my rope-walk.
With the motor gone, the Rudder servo can be moved aft to where the motor was, closer to the rudder and the receiver, so I won't need an extension cable.
Two winch servos with be re-mounted just forward of the rudder servo, and the other end of their loops with be at the forward end of the main hatch, just behind the foremast. This should get me enough length to control everything, even, I hope, the square tops'l.
(https://modelshipworld.com/uploads/monthly_2022_06/pri20220622newplan.thumb.png.d67f1078f6d3acb537229d5978252889.png) (https://modelshipworld.com/uploads/monthly_2022_06/pri20220622newplan.png.85aae1ed6232c9aa62e88849e31af81c.png)
Another step towards getting this girl in the water is the arrival of 50 pounds of lead shot. Now to gather the materials and courage to cast a lead bulb.
Everything but the prop shaft's been pulled out, and some changes were made in the plan...
The rudder servo gets moved a little further aft so I can access the screw that hold the arm through the cabin hatch, and putting it in or out, if the need arises, will be easier.
The winches will be mounted opposing each other; one aft where the motor used to be accessible via the Engine Room hatch with it's loop running to the foremast. The other winch just aft of the foremast, accessible via the main hatch with it's loop running around the aft winch. The makes the system narrower and easier to deal with though the hatches.
I printed a test gun for Macedonian a little while back, and sat it on Pride, just to see. It looks perfect, or darn close.
I thought I had a pair of winch servos around here somewhere, but I haven't turned them up yet. I have to mount the rudder servo and work up fairleads for the steering lines. Then make up servo trays for the winches that include a pair of sheaves for turning the opposing loop, which means 3D modeling and printing some sheaves for all that. I also need to determine the size and shape of the lead bulb.
I'm starting to think Pride may actually sail this summer.
I pulled out the prop shaft and cut back the stuffing box tube, plugging it with epoxy.
I fit two beams for where the rudder servo would be put, and assembled them into a frame that was epoxied in as a single piece.
Next come the turning blocks for the steering lines, and making mounts for the winches.
Looks very good and you seem to have all the potential problems covered.
If the control loop for the rudder will be running though eye rings (and there is nothing wrong with this) I found with my models that using light weight fishing line worked better than cord. It creates less friction, its less visible (therefore smaller eye rings can be used) and does not wear and fray. Running the line through very small lengths of copper tube where it ends at the servo arm meant that when adjusted to length the copper tube could be crimped flat with pliers securing the nylon without having to tie knots in it.
I have assorted sailing models that have been working for years with this method and all have been maintenance free.
Keep up the good work
(FYI: I can't get the attached images into the body of the post, and they don't open full-size when you click on them. In Firefox, I right-click the image and "open in a new tab" to see them full size without leaving the post)Constellation's steering lines run through screw eyes and have given me no problems at all. Pride, on the other hand, is a bit more complicated. The lines run to the sides, turn to s-shaped tube fairleads that direct them 90° and up through the deck so they come out on either side of the lazarette hatch. On deck they will run through functional blocks in the waterways. I'll be using Dacron line I walked from 3 strands of sail-tread (I used off-the-shelf Nylon line in Constellation). That bit of tubing at the lazarette is the big friction machine, so to reduce it as much as possible I'll be putting functional blocks in the hull where the line makes it's first turn from the arm to the lazarette.
When testing the braces on Constellation, I hadn't walked any of the aforementioned Dacron line I was going to use, and used some cotton cord I had on hand instead. There's a few eyes under Constellation's deck to guide the braces from the winches to where they come through the deck. There was so much friction the system wouldn't function, the winches wouldn't budge at all! In a panic, I hurriedly walked out some 12 foot lengths of Dacron and rigged it up. It ran flawlessly and has since.
Mean-while, back at the ranch...
I pulled out the old servo-tray that was on the trunk for the fin, and reseated the main-mast step. Made a pair of trays for the winches from 3/16" luan plywood and painted them yellow, because I had a can of red and a can of yellow spray paint, and I can't paint everything red. ;)
The old motor bulkhead was extended up to carry the aft winch tray, the blocks I put in when the rudder servo was forward were repurposed to carry the forward winch.
I 3D printed four copies of a pulley wheel I found on Thingiverse and re-scaled to 1 inch (25mm) to be the idlers for the loops. They're mounted on the little blocks you see on the trays with #8x1" wood screws with a brass washer under each.
I rigged up the loops for testing, but I need to sort out the radio gear I haven't touched in a while, and charge everything up. I measured that I have roughly 20 inches (50+cm) of travel on the loop which is much better than I was getting the first try (see: http://todd.mainecav.org/model/pride/model09.html (http://todd.mainecav.org/model/pride/model09.html) )
The picture looking down at the model shows what access will look like with the deck on and the hatches open.
This is looking very impressive
Also had a look through your website, very interesting
Thanks Andy.
I 3D modeled Pride's guns over the last few days while I was distracted by other projects like a foot-bridge from over a drainage ditch so the spectators at an upcoming American Civil War reenactment can get from the parking area to the event.
I started by modifying my 18 pounder 3D model, but the number of bands are different, in a different place, and I'd need to remove that Bomefield cascable ring and the ER cartouche on the barrel. I opted to make a new barrel from scratch. The carriage was easy enough to rework into the right size and shape as Pride's.
I set the guns at 45⌡ with the muzzle down so it would drain resin from the barrel as it printed. I printed four guns at once, and each of the four was a single piece. I modeled the vent, and the breaching rings to be loose, but the resin hardened at these spots so the vent is clogged and the rings won't move, other wise the printed were perfect. I'll replace the rings with brass so I can pass the breaching line through it.
The 6 pounders done, I hunted down everything I had, and looked for more, on the swivels. Examining pictures the 1 pounder swivels were simply scaled down versions of the 6 pounders; so I re-scaled my 3D model and added that odd stock and the yoke, and printed two of them.I found out recently a stock was replaced on one gun and a friend of mine has the old one. I'm going to look it over in August and if it's different enough, remake the swivels with the new data.
Been working on another boat, a friend just acquired a Mariner 32 which needs some work and a lot of cleaning. Tomorrow (12th) we're towing her to a marina to be hauled.
I ran a test of Pride's controls, and decided I need a tensioning system with some give to it, so I'm thinking of mounting some blocks on springs on the fin trunk and route the loops as shown in the picture. Looking at some other peoples set-ups, this looked like it ought to do what I need.
Rather than spring the blocks to each other, I'll put them on separate springs and mount them on a post. This seems a better idea than springing them together.
I printed two more of the pulleys I used for the idlers, and some slab sides to make proper blocks of them. I also printed a barrel and a prop.
Pride had three barrels forward of the cabin trunk while I was aboard. This model has wood bands and needs iron bands, and a few other details added particular to Pride's barrels.
Since I remove the motor, the prop is only for show. I stuffed epoxy into the shaft tube, and screwed the prop into that so it will freely spin as the boat sails.
In 1981, Pride had three water casks set in front of the cabin trunk, that's what I'm trying to model...
That barrel mentioned before was too big, and modeled with wood bands. In the 3D editor I resized the model, subdued the bands, and covered them with "iron" bands; placed chocks so it would sit on it's side, and in the slicer software, put a drain-hole in it's underside.
They printed great, except that making them smaller made the end walls to thin and they didn't print. I'm thinking of using them as napkin holders.
Trying to fix the 3D model was more effort than starting from scratch, so I did that. I modeled it solid and hollowed it in the slicer, as well as adding a drain hole. I finally got three usable barrels.
On the sail control loops, I installed a block of wood on the fin trunk with a screw eye to mount the tension blocks for the loops. I got 1.5mm braided polyester line which runs through those little brass blocks just fine, so I didn't use the 3D printed ones from the last post. The springs and brass blocks are visible in the hatch to the right of the mast. The blue tape tabs on the loops mark the ends of travel of the loops. The aft winch is perfect, but I have to program the transmitter for the forward winch to do it's full 3.5 revs.
The barrels came out very well and will weigh nothing so thus reducing weight on deck. Not an issue so much with a larger model like this but it all adds up and spoils performance and handling on the water.
I cast some small resin barrels for use on my own models and experimented with paint techniques to achieve a reasonably good wood effect. I primed them, then painted them a flat medium brown (oil based paint). When dry this was over painted with brown ink which ran between the staves highlighting them. The ink could also be manipulated a bit as it dried to create a pretty good grain effect. A second diluted layer can be added when dry to create knots in timber or repairs (some staves can be slightly darker). A coat of matt varnish with a very small amount of flat white paint seals the surface and gives a somewhat bleached effect (salt water and sun shine). Paint the hoops charcoal or gun metal not jet black.
The lower masts are made using the "bird's mouth" method and almost float out of your hand ;) they're very strong though, and almost don't need shrouds.
The guns will be the heaviest things on deck; the servos, the battery, and of course the fin with it's lead bulb are all below the waterline.
The real boat was a wet sailor, with her deck barely 3 feet above the waterline. I'm considering my hatch sealing options since all but the cabin trunk will be flush-deck hatches. I'm probably gonna put in an automatic pump to keep her bilges clear, as water weight could be a problem.
Putting her deck together is a puzzle. I need to at least paint the underside of the sub-deck. The inside of the hull is fully coated in resin. The bare wood beams are all painted with automotive antifreeze (glycol) which permeates the wood and crystalized, displacing water and keeping it from soaking in without shrinkage. Pure glycol is used to conserve wood from shipwrecks. You have to be careful with it, it can get through your skin and crystalize in your brain which will make figuring out these model boat problems even more difficult. The other issue is some sub-deck needs to be permanently attached where the through-deck fairleads are, and I always get nervous permanently putting down a deck, worried that I'll lose access to something I forgot. This sub-deck's been chopped almost to bits so I can fasten down the parts with through-decks with out loosing access.
Once the whole sub-deck and the hatches are in place, the seams puttied and sealed, it'll get a layer of light cloth and resin. Then I'll glue down the 1mm thick bass strips that'll be the finished deck. These will be stained, dipped in glycol and glued down, then coated with polyurethane for floors.
Still working out where control lines will go through the deck, and putting blocking among the deck beams to hold the tubing.
When the heat gets to be too much, I retreat inside and work on 3D models.
One such item is Pride's Roll Bar. I guess there was some concern over the weight of the mains'l and it's spars when lowered and hanging in it's lifts, pulling at the head of that highly raked mast; or maybe it slopped about too much when lowered and the boat under power, probably both? At any rate, sometime late in 1977 she got a steel tube frame work to act as a boom crutch mounted on her taffrail, which because of it's appearance and construction, was always referred to as the "Roll Bar."The little collage picture shows a couple of views of the real one, snips from my plan of the boat showing it, and a rendering of the 3D model I built. I printed one just to check I had the fit right, but it's basically getting tossed and replaced with a more detailed set. I've added more detailed to the 3D model, such as turksheads. If it turns out these resin ones aren't up to the job, ie, I break them too often, I'll make a set from brass rod.
The bitts at the base of the main mast sport a windlass used to cinch up the main stays, hauls the fores'l sheets, and a few other things. I made a set of winch drums for my friend's schooner model a few posts back, but they were a different style, so using photos, I eyeballed a 3D model of Pride's drums with the handles attached, and printed them.
Quite the engineering going on here. That 3D printing has added so much to model making. I've seen various people on hobby forums create everything from 1/144 scale airplane pilots to 1:20 scale 1800s Nevada silver mine buildings for their garden railway trains, & all kinds of functional mechanical parts for operating models.
I just used it to print a gizmo to repair the IR light mount for the head-tracking device I use in gaming (light gray thing, center-right in pic). Broke and repaired all in the same day - 3D printing is great! ;)
I threw the model into the tub and loaded her up with weight down to a centimeter of her waterline. Deducting the weight of her battery, my brute-force calculations say she needs 11kg (25pds) of weight in the bulb on her fin.
I don't have the tools to melt and cast lead, or want to get them for a one-off job, so I was leaning toward either epoxy casting the lead in a mold, or a container. I put 40ish pounds of lead shot into a PVC pipe for Constellation which was safe, clean, cheap, and didn't require any tools I didn't already have. As noted, one tool I do have is a 3D printer, and here it comes to the rescue again...
I made a ball in my Anim8or 3D software (https://www.anim8or.com/), to be the inside surface of my bulb. Stretching and squeezing it turned it into an ellipsoid. Now, how do you calculate the volume of an ellipsoid? You go to a handy-dandy Ellipsoid Calculator (https://www.omnicalculator.com/math/ellipsoid-volume) and play with the numbers until you get the volume you want. Once I had the dimensions to get 60.62 cubic inches of volume, which times .41 (the weight of a cubic inch of lead), gives me 24.9 pounds.
With the inside dimensions settled, I made a copy of the inner surface to make an outer surface, covered the gaps between them making the bulb's walls about 4mm thick. I then added some structure to seat the fin inside and divided the model into quarters so it would fit in the printer, where it'll take 6 hours to print the half of it that'll fit.
When it's printed, I'll bond the quarters to each to left and right halves; each of which I'll fill with lead shot; pour in epoxy to solidify it, then bond the two halves onto the fin. I'll drill a hole through the bulb and the fin for a pin to make sure I don't unexpectedly drop a depth-charge. I'll give the outside a coat of epoxy to toughen it, and it'll all get painted moss green to match the model's bottom.
You don't need any casting equipment to make a lead bulb, just laminate it from lead sheet like a bread and butter hull. Look for lead roof flashing to get suitable sheet, this can be epoxied together before shaping. Lead can be shaped with a plane, I think kerosine is recommended as a lubricant while doing this. Many years ago I made a bulb for a Marblehead yacht and the final shaping was done with a razor plane.
Jim
Lead sheathing is hard to come by here anymore. Besides, I already have 70 pounds of 7.5 shot, and a gallon of epoxy.
Not to mention I'm half way through printing my dodo egg
All four quarters printed, and a pair of each bonded to make two halves, it's time to load 'em up with lead.
I hope, when all is cut and dried that you do not find it too heavy and you have to remove some lead. nemesis
I doubt "too much" will be an issue, I left some leeway to put weight in the hull to trim her about 1/2" below the waterline at the bow, and 1/4" at the stern, since sailing will tend to push her head down.
I sifted the dirt out of my "reclaimed" lead shot and filled the two bulb halves, but it was too cold to pour epoxy. It was supposed to be in the low 60's (f) today, but the resin was too thick to pour into the mixing cup, so I brought it into the house to warm up for another try.
After a day inside, the resin seemed more amenable to pouring, so out in the shop while is was still 60°f (11°c?) out there, and attempt the pour.I mixed a full yogurt cup's full and poured it into each half. I was left with about 1/3 of the cup, so that I poured into the bilge and propped the model up so it would fill in the deadwood area.
I've gotten a few question on how the bulb will be attached to the fin. There's a hole in the fin near it's bottom, and I've drilled matching holes in each half of the bulb, not all the way through. A metal pin will be trapped in these holes when the bulb is epoxied together, so epoxy and this pin will keep the bulb on the fin.
Pride had four boats when I was on her: a lapstrake pulling boat that sat on top of the stern davits the whole time; A double-ended boat that was half whaler and half life-boat and referred to as the "Bequia boat;" and two inflatables, one new gray one, and one scruffy old orange one.
I sort-of 3D modeled the orange one and printed it. It's a very simple model of an inflatable, but I think it gets the point across. I am looking forward to getting asked why my War of 1812 Baltimore Clipper has an inflatable boat on it.
Finally the temperatures and my time have coincided enough that I may finally get closer to getting this ostrich egg finished.
It seems the plastic egg deformed a little from the weight, so the two halves don't lay flat to each other. If I do this again, and for you folks thinking of using this method, I will put ribs inside the bulb to stiffen it, and fashion some sort of cradle to sit it on that supports it so the bulb doesn't try to flatten out as the lead and epoxy set-up.
There were also dry pockets in the bulb that resin hadn't gotten to and I could hear the shot rattling around inside. If there's a next time, I'll place shot and pour resin in layers to ensure the resin gets everywhere it needs to be. What sounded like the biggest of these pockets was behind the flange? I had modeled in for the plate to slide into. I opened the holes here to pour more resin in and hopefully fill this void.
I re-drilled the holes for the pin that will keep the bulb from sliding off the plate, and cut about a 3 inch length of 3/16" brass rod for the pin.
I mixed very fine sawdust from my band-saw with the epoxy to make a paste of it, buttered both sides of the bulb, placed the pin, and plate, and put the other half on.
I used a sliver of wood as a wedge to hold the seam on top, where the plate enters, as close as I could, making something of a gap at the bottom. The epoxy butter filled this in fairly well, but the seam's open almost all the way around, which I'll fill with more epoxy butter.
The bulb also needs some clean-up from epoxy runs and cardboard that stuck to it; and I intend to wrap it in glass cloth as that'll be stronger than the resin alone if the boat should hit a rock or something.
(https://i.postimg.cc/jWrbhh0z/20240522-171132.jpg) (https://postimg.cc/jWrbhh0z) (https://i.postimg.cc/cKMNk80P/20240522_172503.jpg) (https://postimg.cc/cKMNk80P) (https://i.postimg.cc/QF7D5yP8/20240523_130440.jpg) (https://postimg.cc/QF7D5yP8)
The ballast bulb got sanded and epoxied - twice. Sanded and primed - twice. sanded and painted Moss Green (to match the hull) - twice. Finally sanded and clear-coated - twice.For once, it's done.
