Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: tomaka0 on November 01, 2012, 02:24:28 pm
Title: 27 mhz
Post by: tomaka0 on November 01, 2012, 02:24:28 pm
anyone local to me got 27mhz tx with a lot of crystals to find out my boats rx frequency
Title: Re: 27 mhz
Post by: baloo on November 01, 2012, 03:24:55 pm
There should be a number on the crystal ! also you would need to think is it AM or FM !
Title: Re: 27 mhz
Post by: tomaka0 on November 01, 2012, 03:42:21 pm
nope it s a chinese receiver lookin to use a 27 meg tx acoms futaba to find it would need sets of tx crystals
Title: Re: 27 mhz
Post by: baloo on November 01, 2012, 03:57:24 pm
Hi again,i have just spoke to my friend,he has lots of 27meg crystals tx & rx,he will put them in sets tonight,so if you can wait till tomorrow and i will let you know what there is.baloo
Title: Re: 27 mhz
Post by: tomaka0 on November 01, 2012, 04:13:34 pm
i only need tx and a transmitter as i need to keep cruddy chinese rx with built in esc
Title: Re: 27 mhz
Post by: baloo on November 01, 2012, 04:26:53 pm
No probs leave it with me until tomorrow,will sought something out
Title: Re: 27 mhz
Post by: Netleyned on November 01, 2012, 04:54:10 pm
If it is a non crystalled receiver it will most likely be AM and will receive any signal in the frequency band.
You will find that any crystal in a futaba tx will operate it but so will anyone else on 27AM on the lake.
Title: Re: 27 mhz
Post by: tomaka0 on November 01, 2012, 05:10:38 pm
so it looks like im screwed
Title: Re: 27 mhz
Post by: Netleyned on November 01, 2012, 05:15:54 pm
Not completely.
It might help to name and shame the model as there maybe a mayhemmer who has modified the same model.
Title: Re: 27 mhz
Post by: tomaka0 on November 01, 2012, 05:19:30 pm
http://huayuantoys.en.alibaba.com/product/313909723-213028199/1_12_NQD_RC_Boat_RC1005062.html (http://huayuantoys.en.alibaba.com/product/313909723-213028199/1_12_NQD_RC_Boat_RC1005062.html)[/size][/size[/font]
Title: Re: 27 mhz
Post by: baloo on November 01, 2012, 05:58:43 pm
Speak to "howes models" at kidlington oxford.They do NQD models,they might have some spare parts.
Title: Re: 27 mhz
Post by: triumphjon on November 01, 2012, 06:54:10 pm
if its any use ive got the complete radio system that was removed froman nqd tear into boat last year , it is however a 40 mhz system ! pm me if interested , jon
Title: Re: 27 mhz
Post by: baloo on November 01, 2012, 07:55:33 pm
See there is always someone to help out another fellow modeller
Title: Re: 27 mhz
Post by: triumphjon on November 01, 2012, 09:05:51 pm
pm replied to , although the item isnt of use to me another modeller may find it useable !
Title: Re: 27 mhz
Post by: essex2visuvesi on November 02, 2012, 06:59:00 am
I have a 27 Mhz pistol type NQD transmitter from a long dead model.
PM me your address and I'll wack it in the post
Title: Re: 27 mhz
Post by: malcolmfrary on November 02, 2012, 10:43:01 am
<<Full Function Radio Controlled (Control forward , left and right turn, stop)>>
From the "Features" on the link.
From that I would guess that the encoding used is the maker's very own, and nothing like a standard hobby setup, plus very rudimentary control, if control is the right word.
<<Outdoor operating range up to 300 feet away>>
About 100 yards, so neither a high power transmitter nor a sensitive receiver, and from that, probably not selective either, so prone to interference from anybody else.  A working TX might also upset anybody else at the pool due to uncertain tuning.
<<High speed servo for rudder control for great maneuvering capabilities>>
So there is a means of controlling the rudder, probably not proportional.
Depends on your definition.  Unless you chance on a matching TX, it would need a refit, probably along the lines of a 2.4GHz TX and RX set, plus either switchers to work or replace the existing relays which would give the original dodgy control, or ESCs and a mixer to have it go like it shows on the box.  And a servo to work the rudder.
Title: Re: 27 mhz
Post by: tomaka0 on November 02, 2012, 10:57:41 am
now i wish i didnt have it
Title: Re: 27 mhz
Post by: tomaka0 on November 02, 2012, 04:57:24 pm
what a toodo which way to turn
 option 1 replace 3 motors with 1 or two brushless fit servo and 2.4 gear
option 2 crack on with some 27 meg gear and switch on switch off micro switch and two servos
option 3 find large bin
Title: Re: 27 mhz
Post by: triumphjon on November 02, 2012, 08:42:19 pm
id go with option one , at least you will have some reliable equipment , rather than the hit or miss product that it was originally supplied  with !
Title: Re: 27 mhz
Post by: tomaka0 on November 02, 2012, 09:07:50 pm
 2.4 radio 2 servos, 1 rudder, 1 controlling the single central motor via micro switch fitted with staggered cam then it wacks in two motors on outside any comments
