Mess Deck: General Section => Model Boating => Topic started by: MadMax on July 17, 2013, 07:29:59 pm
Title: 85 mil 4 blade props
Post by: MadMax on July 17, 2013, 07:29:59 pm
hi
    can any body give me any links to go to so i can buy ....1 left 1 right four blade props...
    all the sights i have tryed only go up to 75 mill except prop shop and me been a numpty
   on the computer cant work out there sizes
  so if any body can help i would be grate full
        regards
                                                             madmax
Title: Re: 85 mil 4 blade props
Post by: Stavros on July 17, 2013, 07:50:36 pm
Give Steve at Model boat Bits a ring or Ron at Deans Marnie either will be able to help you
Post by: raflaunches on July 17, 2013, 08:37:53 pm
Hi Madmx
I agree with Stavros, give MMB or Ron a ring for a good quality brass prop, but if you after a bronze one then prop shop is very good. Like you say the sizes are a bit odd, it took a little while to work out what they were on about but I think I've worked it out.
The first two numbers are the diameter eg 20 being 2inches
The second two numbers are the pitch eg 22 being 2.2 inches
Prop shop say there are several anomalies with their system and have labelled them under the Product and Services Section of their website.
Hope this helps, I'd just give them ring if possible. :-))
Post by: hmsantrim on July 17, 2013, 08:38:46 pm
 Hi max.
 some here.
http://www.ebay.de/itm/Messing-Schiffsschraube-4-Blatt-70-130mm-Durchmesser-links-rechts-bei-STEBA-/321148060161?pt=RC_Modellbau&var=&hash=item4ac5ea8201 (http://www.ebay.de/itm/Messing-Schiffsschraube-4-Blatt-70-130mm-Durchmesser-links-rechts-bei-STEBA-/321148060161?pt=RC_Modellbau&var=&hash=item4ac5ea8201)
http://www.westbourne-models.com/Model_Shop/Rivabo_Brass_Model_Boat_Propellers.html#a2920 (http://www.westbourne-models.com/Model_Shop/Rivabo_Brass_Model_Boat_Propellers.html#a2920)
Frank.
Post by: Dean's Marine on July 18, 2013, 09:27:25 am
Hi Madmax
we carry props up to 120mm 4 blade
http://www.deansmarine.co.uk/shop/index.php/cPath/35_39_42_61/sort/2a/page/2 (http://www.deansmarine.co.uk/shop/index.php/cPath/35_39_42_61/sort/2a/page/2)
5 different types and styles
http://www.deansmarine.co.uk/shop/index.php/cPath/35_39_42 (http://www.deansmarine.co.uk/shop/index.php/cPath/35_39_42)
Hope it helps
 Deans Marine
